Automatic renamer and file mover - AVS Forum | Home Theater Discussions And Reviews
post #1 of 51 Old 11-01-2011, 03:03 AM - Thread Starter
djdcm0722's Avatar
I'm looking for a program that will rename TV shows based off of IMDB or TVDB and automatically move it to the specific TV show folder. Currently I download the show on my workstation, transfer it to my media server where I use The Renamer to change the file name then I manually move each show to its own folder. My file structure is as follows:
TV SHOW/
TVSHOW - S01E01 - Episode name
TVSHOW - S01E02 - Episode name
I do not have seasons broken down to seperate folders.
I want to set it up so that I download the TV show from the work station but at the same time have the file sent over the network to a transfer's folder on the server (I do not want torrent programs running on the server). Then have a program run automatically on a schedule to search the transfer folder, or even if I have to run it once a week to rename and move the files is fine. Is there anything out there that will do that? I have been unable to find anything like that. I also don't care about getting fan art and the likes. I let XBMC do that for me.
On a side note, are there any good Movie renamer programs out there? I'm looking for something simple that will just add the year at the end of each movie.
djdcm0722 is offline
post #2 of 51 Old 11-01-2011, 03:38 AM
TRaSH-'s Avatar
Sickbeard does that for me.
TRaSH- is offline
post #3 of 51 Old 11-01-2011, 05:35 AM - Thread Starter
djdcm0722's Avatar
Thanks, I'll look in to that.
post #4 of 51 Old 11-01-2011, 04:07 PM
hagur's Avatar
Google "therenamer".
Does exactly what you want.
hagur is offline
post #5 of 51 Old 11-01-2011, 05:29 PM
whiteboy714's Avatar
Sickbeard is awesome. Works the best with usenet.
whiteboy714 is offline
post #6 of 51 Old 11-02-2011, 04:15 AM - Thread Starter
djdcm0722's Avatar
Thats what I was using to rename the files before I moved them, I didnt see an option to automaticaly move the files.
Was messing around with Sickbeard last night. Seems to be what I'm looking for. Thanks for the info. Great program.
post #7 of 51 Old 11-02-2011, 07:03 AM
hagur's Avatar
There is an option to move files in the configuration window of the program. Cannot remember exactly where it is, but I'm using it for that exact purpose. Rename AND move files, works like a charm
See screenshots #5 and #7:
http://www.therenamer.com/screenshots.html
Notice the "Auto move" checkbox at the bottom, next to the Tv and movie archive folder setting.
hagur is offline
post #8 of 51 Old 11-02-2011, 11:40 AM - Thread Starter
djdcm0722's Avatar
Ah ok, there it is. I like the fact that Sickbeard will "watch" the folder and automatically move it.
post #9 of 51 Old 11-02-2011, 01:26 PM
davdev's Avatar
another plus for sickbeard. I used to do it all manually, but sickbeard has changed that completely.
CouchPotato is another program for movies, but I don't like that as much.
davdev is offline
post #10 of 51 Old 11-03-2011, 11:30 PM
rdb4133's Avatar
Are there any easy guides out there for setting up Sickbeard on Windows?
rdb4133 is offline
post #11 of 51 Old 11-04-2011, 03:50 AM
TRaSH-'s Avatar
Just unpack then place a shortcut of the .exe in the startup.
Reboot or run the .exe then open the browser and browse to your sickbeard page.
TRaSH- is offline
post #12 of 51 Old 11-04-2011, 05:55 AM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
Did you install "Python"? What is Python?
I NEVER saw Sickbeard until this thread. What is the prefered way to set it up? I looks like it continually downloads episoided of shows I select. Are the epsiodes in HD (are they full-screen without Ads)?
Do I need to install anything other than Python (or Windows Binaries) to get it working?
CountryBumkin is offline
post #13 of 51 Old 11-04-2011, 07:37 AM
Ignore all that python stuff. Just install the windows binaries or whatever its called. It downloads the shows in the quality you select. Yes there is no ads. Any tv show you download from anywhere worth a crap will have no ads. To use this app though you need to either set it up with torrents or usenet.
It was made for usenet and works better with it. You can sign up for astra for 11 a month. Hopefully I'm not breaking any rules here.
post #14 of 51 Old 11-04-2011, 08:58 AM
Quoted: 214 Post(s)
Liked: 54
Thanks for the feedback. The Slickbeard website has some Usernet recomendations. They say if I download less than 80GB a month it is cheaper to go with Blocknews. Of course I have no idea what (how much) I'll be downloading at this time.
I guess there's one way to find out ....
post #15 of 51 Old 11-04-2011, 10:02 AM
Imo just go with the unlimited plan from astra, unless $11 is too much. You can get as much as you want and never have to worry about how much quota you have.
You need to use this link its not on the main astra page
http://www.news.astraweb.com/specials/kleverig-11.html
Unlimited downloads at full speed always. I download at 1.7mb/s always.
post #16 of 51 Old 11-04-2011, 09:25 PM
rdb4133's Avatar
There is also usenet server & newshosting
rdb4133 is offline
post #17 of 51 Old 05-23-2012, 02:36 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm Using SickBeard w/SABnzbd per the quides and it isn't properly placing the shows in the correct folders. Any help?
Sammy2 is offline
post #18 of 51 Old 05-23-2012, 10:00 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Anyone?
For some reason Boardwalk Empire came out right..
Here's my settings for SABnzdb and SickBeard as well as what I'm getting in explorer (computer):
Sammy2 is offline
post #19 of 51 Old 05-24-2012, 06:15 AM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
Originally Posted by Sammy2 View Post
Anyone?
Check your sick beard pst processing log or manually run a post process.
In search of video bliss...
mariob33 is online now
post #20 of 51 Old 05-24-2012, 08:02 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I tried that and the results were the same but I'll try again. As I also want all TV Shows to automatically end up in my TV Series folder and It's doing post processing there and Media Browser acts up while that's happening. Of course, going forward it probably won't matter too much because I'll only be getting new shows and not building an entire library.
EDIT: I actually tried that but it only does one episode at a time. It would be much better to have this automatic. I can go into explorer and move them into series\\season folders probably faster.
Sammy2 is offline
post #21 of 51 Old 05-24-2012, 10:06 AM
cdru's Avatar
Quoted: 20 Post(s)
I originally used usenet server but switched to astra. Usenet server had more then a few incompletes where astra hasn't had the same problem.
cdru is offline
post #22 of 51 Old 05-24-2012, 11:19 AM
rdb4133's Avatar
I've noticed the same thing as well. I'm actually using one of the 1.1TB block deals from NewsgroupDirect. I have used 304 GB in about 6 1/2 months and I don't have any problems with incompletes, but I'm also only using it for TV current TV shows.
rdb4133 is offline
post #23 of 51 Old 05-24-2012, 11:25 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Wait guys, this thread is about automatic renamer and file movers not newgroups. I use and like astraweb, especially the $8/mo ($96/year special) pricing.
At any rate, I'm wondering if Media Center Master will do this for me?
How does the "Add a T.V. Series" function work?
And what does "Auto Re-name files and folders for all titles" do?
Sammy2 is offline
post #24 of 51 Old 05-24-2012, 01:33 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
In.
Mfusick is offline
post #25 of 51 Old 05-24-2012, 01:37 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
In.
Huh?
Sammy2 is offline
post #26 of 51 Old 05-24-2012, 02:47 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Huh?
I want to get in this thread to follow replies and catch up reading later.
On vacation now. No time now.
Mfusick is offline
post #27 of 51 Old 05-24-2012, 03:01 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Just subscribe to it??
I thought that you started to post something and your boss walked in on you!
Sammy2 is offline
post #28 of 51 Old 05-25-2012, 08:17 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Well Mfusick's in but does anybody have any suggestions?
Sammy2 is offline
post #29 of 51 Old 05-26-2012, 08:46 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Boss would be wife. She want take jetski out for a quick run. In Clearwater FL area
Mfusick is offline
post #30 of 51 Old 05-26-2012, 02:44 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Any help?
Sammy2 is offline
Reply Home Theater Computers
