Audio over HDMI? - AVS Forum | Home Theater Discussions And Reviews
Old 11-02-2011, 12:21 PM - Thread Starter
WaycoolJr's Avatar
I'm building my first HTPC, and I do not have a home stereo receiver unit. I'm just a student in college and all I have is an old computer, (with a PCIe slot) and a TV with HDMI ports. Nothing else. So I'm going to want the sound from the PC, to play out the TV's integrated factory speakers. What is the least expensive video card that will do this? Not all cards support audio over HDMI so I thought that I'd better ask first.
WaycoolJr is offline
Old 11-02-2011, 12:54 PM
Scallica's Avatar
Scallica is offline
Old 11-02-2011, 01:21 PM
Zon2020's Avatar
How does $14.99 after rebate sound?
http://www.newegg.com/Product/Produc...82E16814121444
Zon2020 is offline
Old 11-02-2011, 02:07 PM - Thread Starter
WaycoolJr's Avatar
Thanks for the replies, but I need to make a slight correction to this thread. I have access to a free Nvidia GT-220 video card. My college buddy has one that he says he'll just give me, but its either a 220, or a 240. Anyone know if the 220 supports audio over HDMI?
Old 11-02-2011, 02:49 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
It does if you have it connected to an audio card via the included SPDIF audio cable.
LexInVA is online now
Old 11-02-2011, 06:22 PM - Thread Starter
WaycoolJr's Avatar
So the 240 doesn't have to have the SPDif cable, but the 220 does. Odd.
Old 11-02-2011, 06:45 PM
Davinleeds's Avatar
My gt 210 does out the hdmi and if that gt 220 has hdmi, it supports pcm audio, fine for that tv. If it has dvi, that should work with an hdmi adapter.
"The purpose of diplomacy is to prolong a crisis." Spock, Mark of Gideon, TOS
Davinleeds is offline
Old 11-02-2011, 11:21 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
That's wrong! Every GeForce 210/GT 220/GT 240 has its own HD audio controller that grabs audio stream via PCI Expess bus, interleaves it with video stream in HDMI signal and send it over HDMI (and DVI too, with any DVI-HDMI adapter). The audio formats supported are:
- Multichannel LPCM, up to 8 ch, 24 bit, 192kHz
- DD
- DTS
It does not support TrueHD/DTS-HD. But if you connect it to TV directly, this is enough. So get GT 220 and save your money.
renethx is offline
Old 11-02-2011, 11:45 PM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
rule of thumb for nvidia cards is that all dx10.1 cards and newer support 8 channel pcm.
MlNDBOMB is offline
Old 11-03-2011, 12:17 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The situation is more complex than this. The number of supported audio formats increases in chronological order:
- GeForce 8 Series/9 Series/GT(S/X) 250-280: Stereo PCM, DD, DTS via S/PDIF input
- GeForce 210/GT 220/GT 240/GTX 465-480/GTX 570-590: Multichannel LPCM, DD, DTS
- GeForce GT(S/X) 430-460/GT(X) 520-560 Ti: TrueHD/DD+/DTS-HD MA/HRA, Multichannel LPCM, DD, DTS
renethx is offline
Old 11-03-2011, 01:06 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
- DD
- DTS
The 220 does not have PCI-E audio pass-through. I don't know why you think it does.
Old 11-03-2011, 01:43 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I don't know why you suggest connecting GT 220 to an audio card via the *included* SPDIF audio cable when there is no GT 220 card with S/PDIF in. (Perhaps you haven't used a GT 220 card.)
I am not sure what you mean by "pass-through". If you are thinking of a "cable" connecting a PCI Express slot and the graphics card by analogy with S/PDIF pass-through, there is no such thing in G210/GT 220/GT 240 or every GeForce card released later than that (or every Radeon HD 2000/3000/4000/5000/6000 series card). All of these cards have an audio controller in the graphics chip and grab audio streams from the system memory via PCI Express "bus" (I assume you know how to connect a graphics card to the PCI Express bus [through 32 pins in a PCI Express x16 slot] ). I recommend you to read one of the Radeon HD 2900 XT reviews (the first discrete graphics card with built-in HD audio controller), for example, PC Perspective.
S/PDIF pass-through
System memory -> HD audio controller in the chipset -> HD audio codec (well, just a S/PDIF emitter) -> GPU -> muxed with video stream in TMDS -> HDMI
Built-in audio controller
System memory -> PCI Express controller -> HD audio controller in GPU -> muxed with video stream in TMDS -> HDMI
renethx is offline
Old 11-03-2011, 06:16 AM
scorrpio's Avatar
Why are you even getting a videocard? Just get a mobo with integrated video. A lot of AMD mobos with chipsets like 880G feature an HDMI output. Intel Socket 1156 mobos with H55/H57 chipsets can utilize integrated video of Core i3 Clarkdale CPUs. Socket 1155 mobos with H61/H67 chipset and a lot of mobos with Z68 chipset can utilize integrated video of any Sandy Bridge CPU.
Any of these will send audio via HDMI. Don't recall exactly where AMD stands but Intel integrated solutions handle 8-channel PCM and lossless codec streaming for Blu-Ray playback.
Later, if want to do serious gaming on it, you can add a nice video card.
scorrpio is offline
Old 11-03-2011, 07:23 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Because it's free...? I don't know if he is going to build an entirely new system, or just add a graphics card only, though.
Well, if he is going to build a new system, an Athlon/880G chipset system or an Intel Clarkdale system is pretty pointless. Celeron G530 with a H61/H67 chipset mb is the way to go (in terms of price, performance, features, power consumption, availability).
renethx is offline
Old 11-03-2011, 08:59 AM
Zon2020's Avatar
He did start his first post with "I'm building my first HTPC. . . ."
The H61/H67 motherboard and a Sandy Bridge CPU of some sort (such as the G530) is certainly the way to go.
Zon2020 is offline
Old 11-03-2011, 09:16 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
It could be that "I'm building my first HTPC with spare components...".
renethx is offline
Old 11-03-2011, 11:27 AM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Some of the 9 series can do multichannel LPCM, I believe. I know that my ION based nettop can.
http://www.tomshardware.com/reviews/...htpc,2329.html
fitbrit is offline
Old 11-03-2011, 11:53 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
That's why I always say "discrete". As for "motherboard GPU" (mGPU [NVIDIA's term]),
- GeForce 7 Series: Stereo PCM, DD, DTS
- GeForce 8200/8300: 7.1/stereo LPCM, DD, DTS
- GeForce 9300/9400/ION: Multichannel LPCM
All have its own audio controller. Well, I am a bit tired of explaining all these details...
renethx is offline
Old 11-03-2011, 11:58 AM - Thread Starter
WaycoolJr's Avatar
Yeah I should have been more clear on that. I am using spare components. I'm just a lowly student and I'm low on money. But I do have the spare components on hand to do this. I'm just using an older PC that I have. Its just a random off-the-shelf Gateway with an intel e4300 dual core CPU. But it does have a PCIe slot, and my buddy did say he'd give me his spare GT-220 that he isn't using anymore. As for some people asking why I'm not just using onboard video, I tried that. But as I'm not using a home stereo receiver with speaker system, I can't do it. I am just using the TV's speakers, and as far as I can tell, there is no way to tell the TV to play an audio signal from a different source than the video signal. Unlike with a receiver unit. And the onboard video does not support sound out through it.
Old 11-03-2011, 12:02 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
Sorry for taxing you. You're this forum's Google! I'm sure flattery doesn't even register with you any more.
fitbrit is offline
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 79
the reason i said nvidia cards specifically was to avoid the whole issue of integrated gpus, which for nvidia, have had 8 channel lpcm for ages.
And the reason i said dx10.1 was to avoid the whole gtx 480/470/465/580/570 bitstreaming debacle.
Plus, you can manage without PAP if you have the arcsoft dll for dts and some type of ffmpeg based decoder for truehd.
MlNDBOMB is offline
Old 11-03-2011, 12:18 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
You are right, I missed 10.1.
- GT(S) 250-280: DX 10.0
- 210/GT 220/GT 240: DX 10.1
So my post is just a descriptive version of yours.
renethx is offline
Old 11-03-2011, 12:34 PM
shingouki2002's Avatar
Not to Hijack this thread but I was curious. I have this:
http://www.newegg.com/Product/Produc...82E16814127510
And it has a mini HDMI out. If I connect the Mini HDMI out to my audio receiver, will I get 8Channel PCM/DD/DTS audio?
shingouki2002 is offline
Old 11-03-2011, 12:38 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Yes, as well as TrueHD/DD+/DTS-HD MA/DTS-HD HRA (if your AVR supports them).
renethx is offline
Old 11-03-2011, 12:58 PM
Thanks so much for your reply. I should have asked it earlier as well, but do I need to have a specific motherboard for this to work or will it happen natively?
Old 11-03-2011, 01:02 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
It should work with any motherboard that supports the card.
fitbrit is offline
Old 11-03-2011, 01:11 PM
Thanks again! You both made my day! I''m going to test it when I get home! Thanks so much!
EDIT: One last question! If I can get all those great sound types over HDMI through my Graphics card...is there really a point in getting a sound card for my PC? I was looking at these cards:http://www.newegg.com/Product/Produc...aro+&x=16&y=15
And all sound cards that I see only support Optical outs...which I believe doesnt support any of the True HD or 7.1 Formats...So is there really any point in getting a soundcard if I can just use my HDMI Cable through my graphics card?
Old 11-03-2011, 04:06 PM - Thread Starter
WaycoolJr's Avatar
Yeah I used to have an old Nvidia 9800 card and I thought that it was actually pretty cool of them to make it where you could run that little wire from your SPDif to your card. Seems like a tacked on afterthought, but its certainly a lot better than no sound over video at all.
Old 11-03-2011, 11:12 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Buying an expensive sound card just for S/PDIF is a waste of money (S/PDIF onboard audio is enough). These cards are for people who have a AVR with multichannel analog in but no HDMI. This post.
renethx is offline
Old 11-04-2011, 08:55 AM
chomper87's Avatar
What is the onboard video? Is there an HDMI connection?
the e4300 isn't too ancient -- so if you're Gateway has the Intel G45 Chipset / Integrated Graphics and HDMI connection - I believe this should support some form of HDMI audio. I think even the G35 can do HDMI Audio. If it's pre G35 (9XX) - then I have no idea. And if there's no HDMI connection, it doesn't matter anyway.
chomper87 is offline
