Why when using mkvmerge to remove unwanted audio or subtitles do the files not play? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 11-18-2011, 11:35 AM - Thread Starter
ogormask's Avatar
I sometimes get mkv files that contain foreign to me languages or subtitles that WMC and or wmpc hc tend to play multiple tracks at once or force multiple subtitles. I have a workaround with my remote to turn off the subtitles but I cant seem to get it to always work especially with the audio tracks. But when I use mkvmerge to remove the tracks by unchecking the files I dont want and then making a new mkv file for whatever reason the files dont work then. What can I do?
ogormask is offline
post #2 of 8 Old 11-18-2011, 11:52 AM
tgrinch's Avatar
Quoted: 23 Post(s)
I found that I need to set the compression flag of each track (video and audio) to "none" - physically changing it to that value, that is. Not sure if this is your issue though.
tgrinch is offline
post #3 of 8 Old 11-18-2011, 09:14 PM
elm_sd's Avatar
Any chance your also using global tages, they make files unplayable for my system....
ELM_SD
Quality TV = C-Band
elm_sd is offline
post #4 of 8 Old 11-19-2011, 09:32 AM - Thread Starter
ogormask's Avatar
Well here is what I was doing.
I see the ones listed and then the ones I dont want I uncheck like that and then start muxing. Maybe I am doing it entirely wrong?
ogormask is offline
post #5 of 8 Old 11-19-2011, 09:54 AM
Pagali's Avatar
Quoted: 12 Post(s)
I see 2 problems...
1. You don't have any video or audio tracks checked! You're selecting only one subtitle track, that's all.
2. What is an MKS file? (your output filename) Shouldn't it be MKV?
Pagali is offline
post #6 of 8 Old 11-19-2011, 10:10 AM - Thread Starter
ogormask's Avatar
Sorry that was bad example as it doesnt have english audio for some reason but the rest of the tracks are all foreign to me. And yeah IDK why it says mks but even if its mkv it doesnt play. Normally I just keep english audio and strip the rest but it just wont play after that.
ogormask is offline
post #7 of 8 Old 11-19-2011, 10:13 AM
AMenard's Avatar
You have to keep the video track also. You can't just select the audio track.
Alain Menard
www.lacrimosae.net
AMenard is offline
post #8 of 8 Old 11-19-2011, 10:35 AM
elm_sd's Avatar
You will get mks as an extension because all that is selected for the job is subtitles, same with audio only, is mka file which plays fine in zoom player,subtitles wont show with out video either even in a mka file...
ELM_SD
Quality TV = C-Band
elm_sd is offline
Reply Home Theater Computers
