Re-routing IR Signal Short Distance - AVS Forum | Home Theater Discussions And Reviews
Old 11-22-2011, 05:49 AM - Thread Starter
savaytse66's Avatar
I am looking to pick up an Xbox 360 to tuck away in the closet and use solely as an MCE extender. The closet is behind the wall that the TV is mounted on, so there will be no line of sight. What's the easiest (cheapest!) way to route the IR signal into the closet? I have an RF extender (but no RF remote) with some of those cables that came with my Harmony 890 and Hauppauge Tuner. The cables have a 3.5mm jack at one end and two sticky leads that go on the components' IR receiver at the other. Can I use these somehow; maybe cut one and splice the leads together? I no longer have the Harmony 890, so that's not an option. My current remote is IR-only.
I only have to go about 6 feet, but the wall is in the way. I have access through the wall for my HDMI cable, power cable, etc, so tucking another wire in there is no problem.
savaytse66 is offline
Old 11-22-2011, 09:26 AM
impmonkey's Avatar
Quoted: 13 Post(s)
http://www.amazon.com/Next-Generatio...1979086&sr=8-1
Probably not the cheapest option but people seam to like these.
impmonkey is offline
Old 11-22-2011, 11:08 AM
setabs138's Avatar
I'll recommend this http://www.amazon.com/Cables-Go-Acou.../ref=pd_cp_e_2
Note that it does not like U-Verse boxes and If you have a Plasma TV it will give off IR signals that may flood the controller.
I have my components behind the couch and ran a 50' 3.5mm cable through the wall and plugged it into the IR receiver which is under my tv.
setabs138 is offline
Old 11-22-2011, 12:06 PM - Thread Starter
savaytse66's Avatar
Hmmm. I wanted to go much cheaper and simpler than either of those options. Thanks, though.
Does anyone know if the Logitech RF extender system has in IR receiver on the base unit? I suspect it does not, but I have one, so if I can use it, that would be ideal.
Old 11-22-2011, 12:32 PM
Mac The Knife's Avatar
Liked: 24
Don't forget that Xbox360s have had notorious overheating issues. So if you're going to "tuck one into a closet", you better be really careful that you give it enough fresh air to keep it from dying.
Back to the IR issue...
It's often possible to bounce IR signals off of a wall (or add a mirror if you lose too much signal off of just the wall). But it sounds like in your layout that's not possible. So you'll probably have to chase down an IR-blaster.
Mac The Knife is offline
Old 11-22-2011, 12:38 PM
Derek K.'s Avatar
$40 for the first one seems like a pretty good deal. that harmony one says it is for rf remotes only (it is called the _rf_ extender).
Derek K. is offline
Old 11-23-2011, 08:58 AM
jbilko's Avatar
Is $16 cheap enough for a wired IR Repeater?
Or $21 for a wireless IR Repeater?
jbilko is offline
Old 11-23-2011, 11:56 AM - Thread Starter
savaytse66's Avatar
Thanks, jbilko. I even checked Monoprice, but I must have mistyped my search parameter. Yeah, I can live with $16. I need to place an order there for a few other items anyway, so this works.
