Black Friday 2011 Desktop for HTPC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-24-2011, 08:36 AM - Thread Starter
jpagger1's Avatar
Will any of the Black Friday desktops work as a starting point for an HTPC? I'm looking for something that can run the HD Home Run Prime and has Windows 7.
jpagger1 is offline
post #2 of 5 Old 11-24-2011, 08:44 AM
mayhem13's Avatar
Quoted: 44 Post(s)
Liked: 29
Plenty of i3 desktops out there using intel integrated graphics. You'll still have to do some tweeking and add some software/applications for HD audio over HDMI but doable. These desktops aren't really about the quiet though so be prepared to change some fans. There's a Gateway i3 with BD driver refurbished at Tiger Direct.
mayhem13 is offline
post #3 of 5 Old 11-24-2011, 01:55 PM
tlniec's Avatar
Looks like the HP Pavilion P6-2026 at Staples is a poor HTPC candidate, sadly.
http://h10025.www1.hp.com/ewfrf/wc/d...=5180010#N1310
Specs like i3-2120, 8GB RAM, etc sound promising, but the motherboard hobbles it. H61 chipset, instead of H67 or Z68. No HDMI output. No Toslink/optical audio out. By the time you add in a video card, you're probably spending more than if you'd built yourself (even factoring in the cost of the OS).
tlniec is offline
post #4 of 5 Old 11-24-2011, 02:25 PM - Thread Starter
jpagger1's Avatar
What about the Acer AX1430 from Office Depot. Has HDMI out already. Are the rest of the specs too low to just use it for HTPC functions only? 4GB RAM with an AMD E-450.
Best Buy has an eMachines PC with HDMI out also but for $10 less it seems the specs are quite a bit worse.
jpagger1 is offline
post #5 of 5 Old 11-24-2011, 06:18 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
http://www.newegg.com/Product/Produc...82E16813157173
ASRock G31M-S R2.0 LGA 775 Intel G31 Micro ATX Intel Motherboard $42.99
http://www.newegg.com/Product/Produc...82E16819116389
Intel Pentium D 820 Smithfield 2.8GHz LGA 775 Dual-Core Desktop Processor PD820280775-R $22.99
http://www.newegg.com/Product/Produc...82E16820148414
Crucial Ballistix sport 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Desktop Memory Model BL2KIT25664AA80E $30.99
$25 Case with 420 watt power supply.
http://www.newegg.com/Product/Produc...82E16811144123
http://www.newegg.com/Product/Produc...82E16827106289
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM $16.99
I have a hard drive. OFFICE MAX HAS 2TB SEAGATE FOR 69$
Would this work as a HTPC networked into my system as an extender or stand alone?
Are these parts compatible?
Is this the best value?
Mfusick is offline
Reply Home Theater Computers
