Full SBS 3D MKV to BD-R (.iso) ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-28-2011, 06:10 PM - Thread Starter
thesebastian's Avatar
Hi All,
So the point is...i'm currently playing a TRON 3D Full Bluray with Intel HD 3000 graphics with no problem trough HDMI 1.4 to a Samsung Led 3DTV.
But this is the only 3D BD-R I have, the rest are all "Mkv Full SBS.
> I tried to play MKV full SBS with HDMI 1.4 and the screen goes 100% Black...in 1920x1080@24Hz. (With POWERDVD, WINDVD and TOTAL MEDIA THEATER).
> I tried to use "Stereoscopic Player" with K-Lite codepack Basic, but i couldn't...(I tried Stereoscopig Player with NVIDIA 3D VISION in other computers and i could sucessfully, but with INTEL HD i dont have a "Intel 3D profile in that player".
So now im trying to move (BD-R 3D Authoring) all my FULL SBS MKV to 3D BD-R (Iso image if possible, to not use a BD-R disk). And maybe i don't have a BLACK-SCREEN and plays with no problem like my Tron 3D Bluray..
Do you know a way to do this? i hardly want to play 3D FULL SBS MKV using all my TV 1080P Screen (Not just the...33% of the screen with 66% of Black Borders) and using Intel GPU with HDMI 1.4v.
And (if its possible) using also DXVA because my 1.7Ghz i5 processor is not good enough for a FULL SBS MKV --> 99% CPU Usage. Power DVD doesn't use my CPU at least with TRON 3D Bluray...but it-s not working with FULL SBS MKV.
Best Regards,
Sebastian.
thesebastian is offline
post #2 of 11 Old 11-28-2011, 06:15 PM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
users of the Shark007 codecs use the Stereoscopic player without issue.
More information is posted HERE
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 11 Old 11-28-2011, 06:24 PM - Thread Starter
But, we are talking about INTEL GPU?
Because i don't have any problems with NVIDIA GPU and i think i won't have problems with AMD GPU.
The problems is Intel, it doesn't have 3DVision or AMD 3DHD in STERESCOPIC PLAYER.
>With Nvidia 3D vision, when i switch the player (Stereoscopic player) to fullscreen, the player (the 3D vision really...) FUSION both Image in one 1920x1080@24Hz resolution and the TV detects automatically the 3D Source.
> With intel i can't use 3D Vision and when i go Full Screen, the 3DTV doesn't detect a 3D incoming video...and it shows a 3840x1080 downscaled to 1920x1080@60Hz resolution.
post #4 of 11 Old 12-05-2011, 04:51 PM - Thread Starter
So...any news about this?
I'm still trying to make a 3D-Bluray using my FULL SBS MKVs
post #5 of 11 Old 11-15-2012, 08:22 PM
Pyronaut's Avatar
I was wondering this same thing, since I have the same problem but I'm using an AMD GPU. It plays regular 1080p files fine, but with a full SBS file it goes to 100% cpu and crawls through the file (even using stereoscopic players).
Pyronaut is offline
post #6 of 11 Old 11-15-2012, 08:58 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Which AMD GPU?
Try PowerDVD 12. I don't see any problem with HD 6530D (in Llano quad-core APU), silky smooth, CPU usage ~40%.
renethx is offline
post #7 of 11 Old 11-16-2012, 11:46 AM
Pyronaut's Avatar
I have a Zotac AD02 miniPC, which has a very weak CPU (AMD E350). The GPU is AMD Radeon HD 6310.
I tried PowerDVD 12 and have the same issue. I get like 5FPS when playing a Full SBS file. I also made sure that hardware acceleration was on.
Pyronaut is offline
post #8 of 11 Old 11-16-2012, 01:15 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
CPU and GPU of AMD E350 are underpowered to decode 4K x 1K AVC.
renethx is offline
post #9 of 11 Old 11-16-2012, 02:41 PM
Pyronaut's Avatar
That's what I suspected, which is why I wanted to know if it could be converted into a Blu Ray ISO, so perhaps it would be handled differently by a Blu Ray player software and not be so slow.
At the worst, maybe I could stick it on a USB drive and play it through my Blu Ray player, since it says it supports "AVCHD Disc Format Folder", which I'm guessing is what's used on BR ISOs
Pyronaut is offline
post #10 of 11 Old 11-16-2012, 02:48 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
BR 3D uses a special video codec, called MVC (Multiview Video Codec), that is an extension of the normal AVC (Advanced Video Coded, so-called H.264). I don't know a video converter that converts SBS (Full) to MVC (and then create a BR 3D ISO).
Converting SBS (Full) to SBS (Half) and playing it with E350 may be possible.
renethx is offline
post #11 of 11 Old 11-16-2012, 03:32 PM
Pyronaut's Avatar
It plays half-SBS files fine, but I don't know of any software that can easily convert full SBS to half SBS (i.e. I would need to decode, resize and re-encode), so I guess I'll just have to stick with half SBS files.
Thanks anyway.
Pyronaut is offline
Reply Home Theater Computers
