UNHAPPY - HD HomeRun Prime major issues with Intel DH67CF & DH67GD motherboard NICs - Page 3 - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2013, 03:08 PM
gazebo's Avatar
Quoted: 14 Post(s)
Sorry for being late to the party...
Try this if you have an old 100mbps switch laying around: Connect the mobo to your existing gigabit switch as you do now. Then put a 100mbps switch between the Prime and the gigabit switch.
The hope here is that the two switches can better interoperate than your Intel NIC and the Prime. This trick served me very well when I had interoperability issues between a DSL modem and a gigabit WAN port of a router.
Good luck.
gazebo is offline
Old 02-21-2013, 10:48 AM
TornadoTJ's Avatar
Quoted: 1621 Post(s)
Liked: 510
On the first page he mentions he has tried connecting the Prime to 100mbps and it did not resolve the issue.
Even after installing the very latest NIC drivers direct from Intel, I'm still having pixellation on some channels, especially bad is BBC America. I've made all the changes listed through this thread - disabling EEE, etc.
I have the Intel DH67GDB3 with the 82579V NIC. My other HTPCs with Realtek cards have no pixellation. I'm going to put a stand-alone Realtek card in the main HTPC soon and see if the issues go away.
I'm glad this old thread got pulled back up. I will report back after installing the Realtek and getting some time to make sure everything is working OK.
TornadoTJ is offline
Old 02-21-2013, 10:59 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
All my PC's have realtech NICs and I don't have any issues whatsoever with my Prime or the echo paired with my HTPC either.
Sammy2 is offline
Old 02-21-2013, 11:53 AM
TornadoTJ's Avatar
Liked: 510
OK, I couldn't wait. I work from home so I had the ability to test this right away.
I've installed a Trendnet Gig-E NIC, which uses the Realtek chipset. As stated earlier, BBC America seems to be the worst offender when it comes to pixellation. I just watched 10 minutes of BBC-A and did not see a single pixellation event. Also noticed no audio dropouts or stutters. I'll keep an eye on it and report back.
I am disappointed that this points to Intel being the problem. I would prefer to see Intel fix the problem, I don't want additional heat generating cards in my HTPC.
Old 02-21-2013, 03:36 PM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
+1 here. All Realtek NICs, no problems with HDHR Prime. I get 80-90MB/s uploading large MKVs to my server. I don't have any Echos.
StardogChampion is offline
Old 02-22-2013, 08:04 AM
billdacat's Avatar
Quoted: 17 Post(s)
+3 No problems with Realtek NIC....Is ther a way to check your network stats? You may have a bad network cable.. I am on a managed switch with the ability to monitor performance stastistics. I am able to run all three HTPC's with out a problem. HDHR3-CC and HDHR-Dual.
billdacat is offline
Old 02-22-2013, 10:04 AM
gtgray's Avatar
Quoted: 206 Post(s)
Liked: 136
I have a mixed environment of Intel and Realtek with Trendnet gigabit switches. I don't have any issues with the Ceton or playing very HBR mkvs
4 Tuner Ceton, 2 two tuner HD Homeruns. Lots of PCs, HTPCs and an HP Extender
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
