WinTV-HVR-1950 QAM scan - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-25-2011, 03:19 PM - Thread Starter
soccerpork17's Avatar
I had just bought a hauppauge WinTV-HVR-1950 and the setup was all good. I have my cable cord plugged into my comcast digital cable box and then the cable box is plugged into the device with a separate cable cord. All AV cords and firewire cords are set up fine too. But when I search for clear QAM channels, it can't find any or any other types of channels, please help.
soccerpork17 is offline
post #2 of 5 Old 12-25-2011, 04:56 PM
Zagor's Avatar
If you want clear QAM channels, you must connect the cable cord coming from the wall into the tuner card. Do NOT daisy chain from wall to cable box to tuner card. You need a splitter and split the signal coming from the wall so that one cable goes to the cable box and the other goes to the 1950. Also want software are you using to the scanning?
Zagor is offline
post #3 of 5 Old 12-25-2011, 05:27 PM - Thread Starter
thanks a lot for the help, and im using the standard wintv software do u have a suggestion for a different one?
post #4 of 5 Old 12-26-2011, 12:52 PM
Zagor's Avatar
Well, if you have Win 7, the built in Windows Media Center is A LOT better. It's more like a DVR with a real TV guide and recording options etc...
Zagor is offline
post #5 of 5 Old 12-26-2011, 12:54 PM
Andrew Hornfeck's Avatar
Quoted: 30 Post(s)
WMC for most although if you want a full media center you should consider using the setups in the guides or using MediaPortal.
Andrew Hornfeck is offline
Reply Home Theater Computers
