MKV fast forward and rewind - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-27-2011, 10:36 AM - Thread Starter
SD Vidiot's Avatar
I've ripped a bunch of movies, both BD and DVD, using MakeMKV. I play back the movies in MPC-HC. I can't get the movies to fast forward or rewind. I can skip chapters forward and back, however. I have the latest versions of these programs running on Win7 32bit. Is there some setting I need to adjust or is this just how it works?
HB
Bear's Lair Home Theater
Howie: "I think my screen may be TOO big."
Norm: "Screens are like breast implants..."
SD Vidiot is offline
post #2 of 8 Old 12-27-2011, 10:40 AM
ogormask's Avatar
You can make the forward and back buttons skip ahead in the settings. You cant fast forward though.
ogormask is offline
post #3 of 8 Old 12-27-2011, 12:20 PM
whiteboy714's Avatar
You can select the amount of time the buttons will jump ahead. I have mine set for 10 second jumps on the next track button, and 5 minutes on the ffwd button.
whiteboy714 is offline
post #4 of 8 Old 12-27-2011, 03:30 PM - Thread Starter
SD Vidiot's Avatar
Where do you make the setting to have the FF button "skip ahead 10seconds"?
HB
post #5 of 8 Old 12-27-2011, 06:52 PM
jim2100's Avatar
Liked: 34
To set the amount of skip:
View / Options / Tweaks / Jump distances (small medium, large in ms)
To set the keys for the skip:
View / Options / Keys / Command: Jump Forward, Backward (small,medium,large)
You can set the keystrokes and the "App Command" (which corresponds to WMC remote buttons)
jim2100 is offline
post #6 of 8 Old 12-28-2011, 10:41 AM - Thread Starter
SD Vidiot's Avatar
This is in the MPC-HC menu?
HB
post #7 of 8 Old 12-28-2011, 11:00 AM
mephiska's Avatar
You can fastforward using the "increase rate" command, but I don't see anything that does a rewind unfortunately.
mephiska is offline
post #8 of 8 Old 12-28-2011, 04:40 PM
In the options menu.
Reply Home Theater Computers
