Skype through a HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-27-2011, 07:22 PM - Thread Starter
paulsiu's Avatar
Has anyone attempted to hook a Skype camera on top of their HDTV to via their HTPC for video conferencing? I am curious to know what sort of hardware is needed. Some of the webcam for example have built in HD encoding to reduce cpu usage, but I notice that even those camera recommend at least a 1.8 Ghz dual core. This probably mean an older machine cannot be used?
I also notice some of the TV and blueray also have a camera connection, since their cpu are likely to be rather limited, how is it they can stream skype without a core 2 duo?
Paul
paulsiu is offline
post #2 of 4 Old 12-27-2011, 08:36 PM
Scallica's Avatar
I recommend the Logitech Webcam Pro 9000. I have it sitting on the top of my HDTV connected to my HTPC. The picture quality is great.
http://www.logitech.com/en-us/webcam...s/devices/6333
HTPC Enthusiast
Scallica is offline
post #3 of 4 Old 12-28-2011, 09:55 AM
Quoted: 49 Post(s)
Liked: 37
Logitech Orbit AF, by the tv on the stem attachment; matches perfectly the video eye level on the 50 inch tv. Has perfect angle to cover the room on minimum zoom, or zoom on the couch only, or pan around the room onto the kids showing their tricks to the grandparents. 4x2.5GHz phenom is powerful enough to encode the video; but as my bottleneck is the upload speed, it probably never had to encode HD. Microphone does not get any complaints.
The greatest problem for me is the pan and zoom control, I have not found a way besides clicking with the mouse on a panel on the screen (using the remote would be perfect, but I have no time to play with 3rd party remote control applications).
Roussi is offline
post #4 of 4 Old 12-28-2011, 05:22 PM
Tyborg's Avatar
Quoted: 13 Post(s)
I also use the Logitech Orbit AF. I am using Eventghost and so I'm able to use my remote to chase the kids around the room as they show off there tricks and zoom in on things they want to show grandpa and grandma. Also using SkypeMCEAnswer to answer calls from within media center.
Tyborg is offline
Reply Home Theater Computers
