Star Wars Blu-Ray makeMKV and subtitles... Anyone have a definitive solution??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 12-29-2011, 01:17 AM - Thread Starter
jeff lam's Avatar
So I got the Star Wars Complete Saga on Blu Ray for Christmas and thought I would rip them to my HTPC using makeMKV like I have been with my other movies. I ripped the 1st title (angle 1), the DTS MA track, and the 1st english and forced subtitles.
Well, I found out the alien subtitles are not on the forced track. After doing some reading and searching on this I still have not found a definitive solution to getting the subtitles in. There were people saying how they used MKVmerge and handbrake to make their own "burned in" subtitles. and some others muxing/demuxing the video, etc... but I have not used or know how to use the tools needed to do this.
What is the simplest and most effective way to get the english alien subtitles in the MKV file while preserving the full bitrate video and HD audio? "Burned in" sounds like a good solution.
I usually use MakeMKV and playback with MPC-HC with MadVR and Cuvid with Lav filters.
jeff lam is offline
post #2 of 27 Old 12-29-2011, 07:09 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Read this thread regarding the forced subs in Star Wars:
http://www.avsforum.com/avs-vb/showt...176923&page=12
For mkv I prefer using Clown_BD + BDSup2Sub + MKVMerge:
http://www.mediasmartserver.net/2010...n_bd-mkvmerge/
Or just stick with folder rips using Clown_BD
Cheers,
Damian
MSS.net blog (contributing editor) - http://www.mediasmartserver.net
Windows Entertainment and Connected Home MVP 2010-2012
dbone1026 is offline
post #3 of 27 Old 12-29-2011, 05:37 PM - Thread Starter
jeff lam's Avatar
After finding a list of which subtitle tracks are for alien speech I re ripped the discs including the proper subtitle track (its not a forced one). Mkvmerge allows me to remux the file with that subtitle track making it default: default and forced: yes. Seems to load properly and automatically with mpc-hc. No other programs needed. I'll stick with this for now.
jeff lam is offline
post #4 of 27 Old 02-07-2012, 09:42 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I have this post going in the MakeMKV is endless thread but thought maybe I should re-post it here as it is more appropriate..
So which is the correct English subtitle track to grab?
And what about the correct angle?
I'm getting some artifact of a multithreading dialog box or BD-Java in the lower right hand corner of the screen too. (not subtitle related but related to conversion to mkv).
Thanks..
Sammy2 is offline
post #5 of 27 Old 02-07-2012, 03:20 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Just wondering... Is there any further information about these multiple angles and subtitle files on this disc?
(Or call it a shameless bump if you wish)
Sammy2 is offline
post #6 of 27 Old 02-08-2012, 02:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm guessing nobody knows.. or cares?
Sammy2 is offline
post #7 of 27 Old 02-08-2012, 03:56 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I just went with the first angle and grabbed the forced subs as mentioned in my link to the forced subs thread. No issues here
Cheers,
Damian
post #8 of 27 Old 02-08-2012, 04:26 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You didn't get a bit of a pop up window in the lower right hand corner? This was on Episode 6, and I haven't had time to do any more work on it and won't again until next weekend.
Is it the same forced subs track for each movie?
Sammy2 is offline
post #9 of 27 Old 02-08-2012, 04:53 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
No issues from when I checked.
Not all of the movies have forced subs, see this thread and spreadsheet
Cheers,
Damian
post #10 of 27 Old 02-08-2012, 04:57 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Sweet.. Thanks. I guess that spreadsheet is being updated then?
Maybe that thread should be a sticky thread?
Mods what do you think?
Sammy2 is offline
post #11 of 27 Old 02-08-2012, 04:58 PM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
I assume it gets updated periodically, It is open for the community to update
Cheers,
Damian
post #12 of 27 Old 02-10-2012, 12:48 AM - Thread Starter
jeff lam's Avatar
Thanks..
Hi, Sorry it took me a couple days to get back.
I dont remember where I got the info but I spent a couple hours researching this set to get the subs right.
For star wars blu ray box set I got this from another site (can't remember where):
For forced English subs only (alien speech) we found the following with MakeMKV:
Episode I: 6th English subtitle track (not the forced but the regular english one)
Episode II: 6th English subtitle track (not the forced one)
Episode III: None
Episode IV: 2nd English subtitle track (not the forced one)
Episode V: None
Episode VI: 6th English subtitle track (Not the forced one)
What you need to do is rip the video and audio obviously but also the subtitle track I mentioned above.
The settings in MKVMerge when you select the subtitle track you just ripped will be:
Default track flag: Default
Forced track flag: Yes
Then Mux it. It should force that english subtitle track and the alien speech will show up just like a forced subtitle track.
It works for my setup using Lav and MPC-HC.
P.S. Ohh and angle 1 (first one) is the english one. From what I read, the various angles are different laguages for the opening words/pre story...
jeff lam is offline
post #13 of 27 Old 02-10-2012, 08:20 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thanks for the information. Did you get this information from the spreadsheet in the "Movies with forced subtitles" thread?
EDIT: I use MakeMKV rather than MKVMerge but it allows the selection of the subtitle tracks; it just doesn't ID the track number. I still think I can figure it out.
Sammy2 is offline
post #14 of 27 Old 02-10-2012, 12:24 PM - Thread Starter
jeff lam's Avatar
I didn't check the spreadsheet in the other thread.
I also use makemkv. MKVmerge does not rip. It is needed in this case to mark the English subtitle track as forced. MKVmerge can also be used to merge 2 mkv files together (useful for the lord of the rings 2 disc movies to make them one mkv).
So you still use makemkv like you normally do, but after you rip it you need to use MKVmerge to change the forced flag on that English subtitle track.
jeff lam is offline
post #15 of 27 Old 02-10-2012, 04:18 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay, otherwise one needs to manually turn it on in MPC-HC then?
Sammy2 is offline
post #16 of 27 Old 02-11-2012, 12:42 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Episode III: None
Episode V: None
Okay. After downloading MKVMerge and working with that a bit I muxed it and got a great first shot at The Phantom Menace (Episode 1).
I set subtitle track ID6 to:
I set the remaining English tracts to:
Default track flag: No
Forced track flag: No
During play back in MPC-HC with subtitles set to "Enable" and "Default" I am getting the complete English Subtitles and the translated alien speech. I was hoping to have it so that the complete English Subtitles would be toggled on or off as needed but have the forced subs always on for alien speech. If I toggle off Enable or Default I don't get any subs at all.
What did I do wrong?
Or is this just the way it is?
Sammy2 is offline
post #17 of 27 Old 02-11-2012, 02:57 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
You didnt extract the forced subs. See my Clown_BD / MKVMerge guide here (note the BDSup2Sub section)
Cheers,
Damian
post #18 of 27 Old 02-12-2012, 12:02 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thanks, Damian. That tutorial is awesome.
Now I see what I've been missing.
I'll report back my results when I'm done.
Sammy2 is offline
post #19 of 27 Old 02-20-2012, 10:32 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Okay, a few days back I did it per our guide, Damian, but the audio is way out of sync with the video. I haven't tried again but did I miss something?
Sammy2 is offline
post #20 of 27 Old 02-21-2012, 06:37 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Hmmm.... no issues with audio for me. You made an mkv with mkvmerge, correct? I believe Star Wars is h264, did you lock the framerate at 23.976 in mkvmerge?
Cheers,
Damian
post #21 of 27 Old 02-21-2012, 07:03 AM
Blues In Thirds
javry's Avatar
I don't think you missed anything. MKV just does that sometimes.
javry is offline
post #22 of 27 Old 02-21-2012, 07:19 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
This I the first time an MKV has done this for me. Either way, I need to re-remux so I'll verify that the frame rate is locked th 23.976fps in MKVMerge and have at it again.
Sammy2 is offline
post #23 of 27 Old 02-21-2012, 07:23 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
Yeah, you only have to lock in 23.976 if the video is h264 (you will get a message popup in mkvmerge when this is the case).
Cheers,
Damian
post #24 of 27 Old 02-21-2012, 07:48 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I think if I got that message I would have selected "yes" but you never know when it is midnight or something and I've been up since 4am!
Sammy2 is offline
post #25 of 27 Old 02-21-2012, 07:50 AM
dbone1026's Avatar
Quoted: 216 Post(s)
Liked: 110
The message just advises you of the problem. You still have to manually set the fps (if you look at my guide the second screenshot under the MKVMerge section talks about this and how to set the fps)
Cheers,
Damian
post #26 of 27 Old 02-21-2012, 07:53 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Thanks!! I'll check the guide again. Don't remember seeing that.
Sammy2 is offline
post #27 of 27 Old 04-22-2012, 09:09 AM
andyd2k's Avatar
Hi. Sorry to bump this up but I'm hoping someone can help me with this. I have identified the proper subs in bdsub and have limited my subs to only the forced subs
I took that sub file (also tried converting it to idx) into mkvmerge along with my mkv. I then set it to default / forced. Still, regardless of player the movie will not play the subs unless subs are enabled. Shouldn't forced subs play automatically regardless of sub setting?
VLC
MPC
XBMC branch that has forced subs playback enabled
None of the players show the subs
andyd2k is offline
Reply Home Theater Computers
