On the fly AC3/DTS encoding for games? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-29-2011, 10:31 PM - Thread Starter
cryolithic's Avatar
Is there any method to force games to output in ac3 or dts? Something to encode them before sending out over hdmi?
cryolithic is offline
post #2 of 7 Old 12-29-2011, 10:47 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 710
If you have HDMI, why use DD or DTS? Just send 5.1 as native PCM.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
post #3 of 7 Old 12-29-2011, 11:02 PM - Thread Starter
cryolithic's Avatar
HDMI goes to the tv, then output via toslink to a receiver.
From the googling I've been doing, it doesn't look like it's possible. I may just have to buy a new receiver...
post #4 of 7 Old 12-30-2011, 03:25 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
There are several sound cards that support Dolby Digital Live (a real-time DD encoder; part of Dolby Home Theater) and/or DTS Interactive (a real-time DTS encoder; part of DTS Connect). The cheapest one (apart from onboard audio of several GIGABYTE mb that supports Dolby Home Theater) is DIAMOND XtremeSound XS71DDL, ~$26.
renethx is offline
post #5 of 7 Old 12-30-2011, 01:07 PM - Thread Starter
cryolithic's Avatar
Right, but that would require using toslink to the receiver from the PC, correct? Currently I have toslink from the TV, and HDMI from the PC to the TV.
post #6 of 7 Old 12-30-2011, 02:01 PM
ericbsmith's Avatar
Quoted: 13 Post(s)
Yes, you'd need to run a toslink from the computer to the Receiver; or from the computer to the TV, assuming that 1) the TV can assign the optical in to the HDMI, 2) the TV will then passthru the S/PDIF signal to the receiver without decoding it and downmixing it to stereo; or run analog outs from the computer to the receiver, assuming the receiver has 5.1 analog inputs.
Your only other choice is to buy a receiver that can accept HDMI. The sound card would be cheaper; is there some reason you don't want to run another toslink from the computer to the Receiver?
Eric B. Smith
The future keeps telling us what the past was about. You make the past mean different things by what you do with the time that comes after.
ericbsmith is offline
post #7 of 7 Old 01-02-2012, 07:15 PM - Thread Starter
cryolithic's Avatar
The receiver only has one optical in, and the tv doesn't have any, and I use three devices with it. I'll just pick up a new receiver soon.
Reply Home Theater Computers
