Alternative to MakeMKV? - AVS Forum | Home Theater Discussions And Reviews
Old 12-31-2011, 03:17 PM - Thread Starter
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
Is there an alternative to MakeMKV for turning BDMV file structures into MKV files?
I have AnyDVD HD so I rip the blu-ray to the HDD as a BDMV, then I stuff it into MakeMKV to rip out everything except for the main feature and HD audio tracks.
Since AnyDVD HD does a better job of.. ahem.. allowing me to rip in the first place... I'd rather not buy MakeMKV. Is there a free application that will let me pick and choose the bits to keep like MakeMKV does?
sebberry is offline
Old 12-31-2011, 03:18 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
Makemkv is free. You can renew it for free every month legitimately.
assassin is online now
Old 12-31-2011, 04:04 PM
Rico66's Avatar
You can use clown_bd (gui for eac3to) + mkvtoolnix/mkmerge. It's a 2 step process, hence a bit more complex (but also more powerful) than makemkv. But it's all you need if you have Anydvd.
Rico66 is offline
Old 12-31-2011, 04:34 PM
Pagali's Avatar
Quoted: 12 Post(s)
Also all you need, with AnyDVD HD: Ripbot264. Get the all-in-one installer here: http://www.mediafire.com/?t6l3sji36zxvc
Pagali is offline
Old 12-31-2011, 05:25 PM - Thread Starter
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
That's what I thought too, except the key stopped working and they have yet to issue a new one. I've been monitoring their forum.
sebberry is offline
Old 12-31-2011, 07:19 PM
whiteboy714's Avatar
Ripbot264 is for encoding into x264. I think the OP is looking to simply remux into an mkv.
whiteboy714 is offline
Old 12-31-2011, 08:04 PM - Thread Starter
sebberry's Avatar
Quoted: 26 Post(s)
Liked: 30
Yep, that's all. I don't want to re-encode anything.
sebberry is offline
Old 12-31-2011, 09:23 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
BluRip, a front end of eac3to, mkvmerge, and x264 (you can ignore x264 of course). The only all-in-one BD-to-MKV ripping application, except for MakeMKV, that is often better than MakeMKV (detecting the correct main title with seamless branching).
renethx is offline
Old 01-01-2012, 12:47 AM
digital desire's Avatar
Just need to re-download another copy of makemkv.
Lot's of low rent stuff stacked up into a medium rent pile.
digital desire is offline
Old 01-01-2012, 10:37 AM
Thanks Rene hadn't heard of that one.
Old 01-04-2012, 02:45 PM
riverhawk79's Avatar
Yea I had never heard of it either, but I just played with it and while I like the UI, it doesn't seem to support .mpls playlists, only single mt2s files. So that's out.
riverhawk79 is offline
Old 01-04-2012, 04:10 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Trying to load a .mpls file directly is not the intended usage. Insert a BD disc (with AnyDVD HD running in the background) and let the program detect the available titles (then select the title you want and rip it). As this is just a GUI of eac3to, the result of detecting the titles is the same as other GUI of eac3to such as Clown_BD (the difference is that BluRip uses mkvmerge to merge ripped streams to MKV, while Clown_BD uses tsMuxer to merge them to M2TS or create a BD folder/ISO).
renethx is offline
Old 01-04-2012, 04:14 PM
Yes I understand. My complaint is that it does not present the mpls playlists as selectable titles.
My test disc was spartacus blood and sand. You need the entire mpls, which contains 2 mt2s files in order to get the "previously on spartacus" + the actual episode.
Old 01-04-2012, 04:26 PM
Bojangles139's Avatar
ya, that happens once or twice a year where he won't update right away. give it a couple of days and work again. kinda annoying, but hey, its free and its awesome program.
Bojangles139 is offline
Old 01-04-2012, 04:33 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The program does not use "mpls" but "M2TS" somehow to list the available titles (each of which may consist of multiple M2TS files) in "Title selection". But the end result is the same as other eac3to UIs.
If you think the program can't detect the correct main title, perhaps it's eac3to that is to be blamed. Or other UIs (e.g. HD DVD/Blu-ray Stream Extractor, Another EAC3to GUI Plus, Clown_BD) work correctly?
renethx is offline
Old 01-04-2012, 04:53 PM
So for each episode on the disc, there are two mpls entries. One with the "previously" thing, and the other without. AnotherEac3ToGui shows both and allows you to rip either way.
Old 01-04-2012, 05:56 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
If Another EAC3to GUI Plus works, then BluRip should work as both uses eac3to to detect the main titles. Remember that both are just GUI of eac3to. The development of Another EAC3to GUI Plus stopped before the author adds PGS subtitle support.
renethx is offline
Old 01-04-2012, 07:35 PM
I know, that's why I'd like to find an alternative to AnotherEac3ToGui, since it's broken now with the latest version of mkvmerge. I'd prefer that it be based on eac3to, since it seems that's still more trusted than makemkv.
