how to make mediabrowser/mediacenter quick - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 01-01-2012, 10:36 PM - Thread Starter
cchrono's Avatar
I have a I7 2700k and 16gb ram.
I have media browser setup to how I visually want. I am using the chocolate theme. Right now I only have about 200 movies loaded into it. The experience is super slow moving from one movie to the next takes a couple seconds and then when I select a movie it can take up to ten seconds. Same thing with wmc everything about it is just slow and laggy. What can I do to increase my speeds. Ive thought about going to xbmc but just didn't like it and find it much more difficult to set up. Also I have a ceton tuner and use for TV. Any help would be appreciated. I have watched assassins YouTube video and his mediabrowser is so quick.
cchrono is offline
post #2 of 17 Old 01-01-2012, 11:38 PM
MikeEby's Avatar
Something is badly wrong...My HTPCs ranges from an AMD E-350, Intel E6600 & Q6600 and all move around Media Center/MB rather zippy and I have over 800 BD rips on my server and my network is only 100/mb. I use MPC-HC to launched from MediaBrowser and an MKV will load and start in maybe 2 seconds. What are your rips? I could see mounting an ISO could perhaps take longer.
Mike
MikeEby is offline
post #3 of 17 Old 01-02-2012, 12:20 AM - Thread Starter
cchrono's Avatar
They are all mkvs that I have made from make mkv I have also tried ramdisk and I have a Samsung 830 ssd and its still slow and choppy
cchrono is offline
post #4 of 17 Old 01-02-2012, 02:23 AM
MikeEby's Avatar
I assume your using the latest video driver and not trying to run a low refresh rate like 24Hz?
Mike
MikeEby is offline
post #5 of 17 Old 01-02-2012, 05:10 AM
Shark007's Avatar
Quoted: 80 Post(s)
Liked: 73
Improperly installed and/or configured codecs can cause this too.
My guess as to which codec? uninstall, unregister DirectVobSub (vsfilter.dll)
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #6 of 17 Old 01-02-2012, 05:12 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
You know it!!!
assassin is offline
post #7 of 17 Old 01-02-2012, 07:18 AM - Thread Starter
cchrono's Avatar
The videos play fine with audio and video working flawless. Drivers are up to date and refresh rate is normal at 60hz. Its the navigation of the library don't see how that would be a codec issue.
cchrono is offline
post #8 of 17 Old 01-02-2012, 10:18 AM - Thread Starter
cchrono's Avatar
Originally Posted by assassin View Post
You know it!!!
So Whats the secret???
cchrono is offline
post #9 of 17 Old 01-02-2012, 10:24 AM
hhb97ba's Avatar
Hi
I had similar issue as you, but not as cool hardware as you. I have a onboard nvidia 9300, E8500 cpu and a SSD.
I used the poster view and I showed 8x3 poster at a time. All my posters was retrieved from themoviedb.org and wasn't changed. The size of the poster 700-800 pixels high. I solved my performance issue by reducing the poster size to 400 pixels high and now it works great.
hhb97ba is offline
post #10 of 17 Old 01-02-2012, 11:13 AM - Thread Starter
cchrono's Avatar
Would this make a difference even though i use coverflow. My issues just arent with media browser they are with wmc itself just going into settings and changing things can take up to five-ten seconds to respond
cchrono is offline
post #11 of 17 Old 01-02-2012, 11:17 AM
chuga's Avatar
cchrono...I have been having the same issue. It did not used to be like this either..just recently slowed down.
Some things to try - delete all cache/images and rebuild. Try coverflow or another view...I have the worse problems with poster view. Try a different theme...and do "reset default" settings on your themes.
I still can't explain why wmc is so slow...as you mention just browsing the menu in WMC is very laggy.
I just ordered a GT430 and plan on doing a fresh install when I put the 430 in (replacing integrated ATI 4200). Hope that fixes things for me.
good luck!
chuga is offline
post #12 of 17 Old 01-02-2012, 12:52 PM
ogormask's Avatar
yeah its buggy as hell for me. When I go to use it I almost always have to restart media center. Then when I enter media browser it can take several minutes to even let me do anything and if I press the button too fast it crashes itself. Then it takes way too long to open once I actually enter my main movies folder. Then the cover art refuses to load most of the time. I have emptied the cache several times and forced it to update again but it often crashes in this stage as well. Its something with the last few builds but it sucks. Maybe I have too many movies for it to handle but it sucks. I wish it still had the database thing or something to make it load faster.
ogormask is offline
post #13 of 17 Old 01-03-2012, 10:39 AM
hhb97ba's Avatar
I had missed that you also had problems in wmc. Changing the picture size will not help you.
I have never had problems with wmc/7mc being slow in the menues.
hhb97ba is offline
post #14 of 17 Old 01-03-2012, 03:58 PM - Thread Starter
cchrono's Avatar
Well I decided to do a clean install of operating sysytem and all applications and now its flying like it should be. Who knows what was causing the issues but I didn't have patience to troubleshoot
cchrono is offline
post #15 of 17 Old 01-03-2012, 05:27 PM
xfett's Avatar
Have you tried this ....http://www.hack7mc.com/2009/08/speed...ash-drive.html
"Man, I told you we shouldn't have shot Niedermeyer"
xfett is offline
post #16 of 17 Old 01-03-2012, 07:21 PM - Thread Starter
cchrono's Avatar
solved with a clean windows install
cchrono is offline
post #17 of 17 Old 01-03-2012, 10:10 PM
jeff lam's Avatar
Use restore points this time. Sometimes you can run into issues when you install software, programs, or codecs. It's easier then a complete reinstall if the issue can be resolved by a previous restore.
jeff lam is offline
Reply Home Theater Computers
