HTPC for current living room setup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-04-2012, 09:15 AM - Thread Starter
ktm250rider's Avatar
Quoted: 18 Post(s)
Im in the planning stages of my HT and would love to have some sort of media storage system. Im guessing that this can be done with an HTPC. My current setup uses a Mitsubishi 65" RPTV with no HDMI inputs. Would it be worth building the HTPC now and using an HDMI to component converter. IM looking at a good year until the theater is done. My goal is superbowl next year.
ktm250rider is offline
post #2 of 3 Old 01-04-2012, 09:26 AM
pittsoccer33's Avatar
Quoted: 649 Post(s)
Liked: 427
there are video cards that can output component, though they are becoming less common. typically the feature is called HDTV out, and uses a small pigtail to go from the card to three component jacks.
are you planning on a new television?
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 3 Old 01-06-2012, 06:23 PM - Thread Starter
Quoted: 18 Post(s)
yes this will eventually be moved to the home theater which is also under construction.
Reply Home Theater Computers
