core 2- E6550. LGA 775 HTPC build??? 1155 mobo??? - AVS Forum | Home Theater Discussions And Reviews
Old 01-04-2012, 10:38 PM - Thread Starter
coffeeman101's Avatar
so I want to build a htpc, and I have an old cpu chip laying around.
but I want to make sure that this will fit a motherboard which will let me upgrade into the future. when I want to move up to i3 if need be.
as this is a socket 775 chip cpu, will a 1155 socket mother board be able to run the E6650? or do I have to buy a motherboard which is 775 socket?
thanks..
coffeeman101 is offline
Old 01-04-2012, 11:40 PM
Micromain's Avatar
You will need a socket 775 motherboard. The E6650 won't work, or even fit, in a socket 1155 m/b.
Micromain is offline
