Blu-Ray Discs Not Recognized - AVS Forum | Home Theater Discussions And Reviews
post #1 of 44 Old 01-05-2012, 07:41 AM - Thread Starter
JMGNYC's Avatar
I have a LG GCC-H20L BD/HD DCD Combo drive with firmware 1.07. I'm running Win 7 64-bit and have the latest driver from 2006.
Lately it cannot read more and more BD disks from Netflix. By "cannot read" I mean that it won't even show up in Explorer as there being a disk in the drive. It still reads old BDs fine.
Is this a driver problem? firmware? Some other software compatability problem?
JMGNYC is offline
post #2 of 44 Old 01-05-2012, 08:07 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
are you running some sort of software like anydvd? I would try turning it off if you are.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 44 Old 01-05-2012, 08:11 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
LG Drives are known to have issues with some bluray discs.
http://www.newegg.com/Product/Produc...scrollFullInfo
assassin is online now
post #4 of 44 Old 01-05-2012, 09:18 AM - Thread Starter
JMGNYC's Avatar
I've tried with AnyDVD both on and off with the same results. New disks have a problem but all my old ones that I've already ripped are fine. I'm thinking it's something new in how disks are being authored/manufactured.
JMGNYC is offline
post #5 of 44 Old 01-05-2012, 09:19 AM - Thread Starter
JMGNYC's Avatar
Care to recommend a new blu-ray drive? I don't need HD-DVD functionality that this one has.
JMGNYC is offline
post #6 of 44 Old 01-05-2012, 10:29 AM
CountryBumkin's Avatar
Quoted: 214 Post(s)
Liked: 54
Try Lite-On. http://www.newegg.com/Product/Produc...82E16827106451
or for a few dollars more ... a BD burner. http://www.newegg.com/Product/Produc...1&name=Lite-On
CountryBumkin is offline
post #7 of 44 Old 01-05-2012, 11:11 AM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 242
I already have. They are in my sticky thread.
post #8 of 44 Old 01-05-2012, 11:14 AM
Postmoderndesign's Avatar
Quoted: 218 Post(s)
Liked: 85
I had the problem of my two year old copy of "The Bank Job" not being recognized by my realitively new Liteon iHBS212 manufactured in March 2011. My PS3 did not recognize a disc was present either. I noticed the disc seemed to have a lot of little marks under the top coat and thought that perhaps Lions Gate had an early run of some badly manufactured Blu-ray discs. Or maybe the life span of blu-ray discs is much shorter than I thought.
Anál nathrach, orth’ bháis’s bethad, do chél dénmha
Postmoderndesign is offline
post #9 of 44 Old 01-05-2012, 11:22 AM - Thread Starter
JMGNYC's Avatar
Doh! Of course - lol.
JMGNYC is offline
post #10 of 44 Old 01-05-2012, 06:59 PM - Thread Starter
JMGNYC's Avatar
I swear, they're just trying to make rental disks not work on PCs - lol. My brand new LOTR BDs work fine in the drive, but none of my latest Netflix rentals do.
After years of fighting with disk playback on a PC this was the straw that broke the camel's back and I gave up and bought a BD player.
I had wanted to get a decent streaming box that could do high quality Netflix, Amazon and Vudu. HTPCs are simply inadequate for any of these. I was considering a Roku (no Vudu though) as and add on to my HTPC. This prompted me to look at BD players and found the CNET's editors choice (for just $30 more than a Roku) had all three streaming options (plus a host of others) and would play back BDs and upscale DVDs and do it all at the correct fps with bitstreamed audio for disks and 5.1 audio with HD video for the streaming options I wanted.
I'll still use my HTPC (Media Browser with mpc-hc and PDVD11) but only to play back my ripped content.
My dream of an all in one solution has been permanently dashed though. So it's my DVR for live TV, a BD player for disks and internet streaming, and my HTPC for local ripped content.
JMGNYC is offline
post #11 of 44 Old 01-05-2012, 09:39 PM
Quoted: 218 Post(s)
Liked: 85
Liteon iHBS212 internal Blu-ray disc writer plays Netflix rentals fine.
In my experience I consider these drives consumables with a life span.
post #12 of 44 Old 01-05-2012, 10:13 PM
Zon2020's Avatar
Why do you say this? Ok, I understand Netflix hamstrings its PC implementation (I don't use Netflix but that's what I've read here), but there is nothing wrong with Amazon on an HTPC. In what way is an HTPC "inadequate" for Amazon?
Zon2020 is offline
post #13 of 44 Old 01-05-2012, 10:32 PM - Thread Starter
JMGNYC's Avatar
There's no good 10 foot interface on the PC for streaming, prime or rental or purchase. It is OK with Media Center if you're willing to download in advance though. There's also tons of stuff available in HD 5.1 on Amazon but only on devices, not the PC.
JMGNYC is offline
post #14 of 44 Old 01-06-2012, 01:01 PM
protovision's Avatar
fwiw, I just started having the same problem with my LG GCC-H20L BD/HD, and a fresh install of Win7 x64. I put a blu ray in, and it doesn't recognize it, just sits there scanning the disk over and over again.
I dual booted back to my older, non-fresh Win7 x64, and it works fine with the drive. I can't figure out what's different between them yet. Since the drive works, it has to be a drivers issue in the new Win7 install.
protovision is offline
post #15 of 44 Old 01-12-2012, 07:01 AM
Quoted: 218 Post(s)
Liked: 85
Netflix version of The Proposition will play on my PS3 but is not recognizedby PowerDVD in my computer's optical drive. Eac3to does not see the disc. AnyDVD sees the disc and reports a region 0 designation. AnyDVD cannot read some sectors and cannot create an .iso which can be played.
post #16 of 44 Old 01-12-2012, 09:05 AM - Thread Starter
JMGNYC's Avatar
So far I've had the problem with 4 movies from Netflix were the OS doesn't even think there's anything in the drive and neither does any software of course. Yet, the last 3 discs I got from Netflix (all new releases) are fine. I'm pretty sure it's an authoring or DRM issue and not hardware going bad.
JMGNYC is offline
post #17 of 44 Old 01-12-2012, 10:18 AM
walford's Avatar
Did you check the LG website for a more recent driver?
walford is offline
post #18 of 44 Old 01-12-2012, 11:29 AM
Quoted: 218 Post(s)
Liked: 85
Unlike JMGNYC I am using a Liteon drive. Windows determined that the driver is up to date.
post #19 of 44 Old 01-12-2012, 12:04 PM - Thread Starter
JMGNYC's Avatar
Yes, I've got the latest driver (it's from 2006) and firmware. I just don't think they're updating it.
JMGNYC is offline
post #20 of 44 Old 01-12-2012, 12:10 PM
Quoted: 218 Post(s)
Liked: 85
While it might be a drive problem, AnyDVD could see the disk in the drive and write more than half to an image file before it had a problem reading sectors. The argument against it being an authoring problem is that the PS3 could recognize the disc and play it.
post #21 of 44 Old 01-12-2012, 12:30 PM
Hamilcar Barca's Avatar
Obviously, it's possible to build an anemic, underpowered HTPC, but ...
Streaming boxes don't have the power of an Intel i7, i5, or even possibly i3. Not
only would a system built on one of these processors be adequate, it would
be overkill for streaming video.
Hamilcar Barca is offline
post #22 of 44 Old 01-12-2012, 01:31 PM - Thread Starter
JMGNYC's Avatar
I don't think HTPCs are inadequate for streaming because of processor power. Even with the latest i7 processor you still would get stuttering on Netflix with Silverlight and you still wouldn't have the HD options from Netflix, Amazon, or Vudu on an HTPC because they're blocked. Compare the list of HD titles from Netflix available on a streaming box vs. a PC. It's more than double. Vudu doesn't even offer HDX streams on PCs.
JMGNYC is offline
post #23 of 44 Old 01-12-2012, 01:43 PM
Zon2020's Avatar
Where does it say anything about being blocked? Everything on Amazon's website says you can get HD on a PC. For example:
"Watch Now Technical Requirements
Here are the computer system requirements for Amazon Instant Video:
Computer Hardware:
PCs: Intel Pentium 4 2.33GHz processor or equivalent. Macs: PowerPC G5 1.8GHz or faster or Intel Core Duo 1.33 GHz or faster.
Computer Hardware for HD:Most Duo Core 2.00GHz Macs and PCs or faster.
Browser:Internet Explorer 6.0 or above, Firefox 1.5 or above, or Safari 2.0 or above.
Browser Plug-ins:The most recent versions of JavaScript and Adobe Flash Player.
Internet Connection:Broadband Internet connection with minimum recommended connection speed of 450 Kbits/sec.
Internet Connection for HD:Broadband Internet connection with minimum recommended connection speed of 3,500 Kbits/sec."
EDIT - I just went on and tried it. No problem streaming HD content on Amazon Prime VOD (other than the slowness of my internet connection here).
Zon2020 is offline
post #24 of 44 Old 01-12-2012, 03:17 PM - Thread Starter
JMGNYC's Avatar
Computer Hardware:
Yes, there's plenty on Prime that is in HD on both PC and device. However, there are rentals that are only available in HD on devices and I imagine even on Prime, like Netflix, there is some stuff available in HD only on devices.
For example check out Rise of the Planet of The Apes. SD streaming only on PC however "Also available in HD with Amazon Instant Video on Your TV" meaning devices. PC download is probably HD though but not streaming.
JMGNYC is offline
post #25 of 44 Old 01-12-2012, 04:06 PM
CZ Eddie's Avatar
Quoted: 54 Post(s)
Liked: 32
I hated both of my BD LG players.
"The boom is dead, long live the bass"
CZ Eddie is offline
post #26 of 44 Old 01-12-2012, 08:28 PM
walford's Avatar
Many periphereal hardware vendors never pay Microsoft to test new drivers and release them to Win Updaste. Therefore many drivers at MS are the origional drivers that were on the disk when the product was first released.
It is for this reason that I sugested that the OP check the manufacturers website for the latest drivers. It is strange that the origional 2006 drivers are still the most recent ones available.
walford is offline
post #27 of 44 Old 01-12-2012, 10:04 PM
Quoted: 218 Post(s)
Liked: 85
Yes, liteon has a program called smartpack that updates firmware. I am looking for Liteon's drive update.
post #28 of 44 Old 01-12-2012, 10:09 PM - Thread Starter
JMGNYC's Avatar
Unfortunately LG doesn't even have drivers on their support site. They only have firmware for XP and Vista not even Win 7.
JMGNYC is offline
post #29 of 44 Old 01-12-2012, 10:38 PM
mcantu1's Avatar
are you sure thats the right model #? i see the GGC-H20L (which is the drive i have) on their site but not the GCC-H20L
mcantu1 is offline
post #30 of 44 Old 01-13-2012, 07:44 AM
Quoted: 218 Post(s)
Liked: 85
Liteon uses Windows 7 drivers and does not have its own. Windows 7 says the drivers are up to date.
Reply Home Theater Computers
