win7 default audio keeps changing... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-05-2012, 09:40 PM - Thread Starter
bulls's Avatar
Quoted: 73 Post(s)
Liked: 33
for some reason the default audio output i set up in windows7 Sound config keeps changing to something else every time i reboot...
why aint it sticking and how can i make it stick to what i want !?!
edit: i'll just try this: i disabled everything else but spdif out lets see what else its going to switch to ...lol
bulls is offline
post #2 of 2 Old 01-05-2012, 09:44 PM
scoobydenon's Avatar
This happen to me last year. You need to reinstall or update the audio driver, it's that easy. I assume you have onboard audio (realtek?) I'd go to the motherboards website and download the latest. If you are upto date, uninstall then reinstall. Hope this helps, Good luck. Thanks
Tony
scoobydenon is offline
Reply Home Theater Computers
