Why do i have black bars on all 4 sides? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-09-2012, 05:25 AM - Thread Starter
lvisneau's Avatar
I have a hp pavillion dm3 laptop connected to my denon 3808ci then to my epson 1080ub. All output has black bars on 4 sides. Is this my video card?
Is there some setting i may be missing? All other media (ps3, xbox, hddvd player, cable box) work fine. It's like i'm watching a "mini" version on my screen.
Sorry guys but i'm a newbie at htpc.
My sono build
Psn Id- lvisneau or lvizzzy
Xbl- chief vizzy
lvisneau is offline
post #2 of 11 Old 01-09-2012, 06:04 AM
tman247's Avatar
Quoted: 57 Post(s)
Liked: 51
Black bars all round sounds like an underscan issue. You can usually fix this using the advanced driver settings for the GPU (certainly can on ATI cards).
tman247 is offline
post #3 of 11 Old 01-09-2012, 06:29 AM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 336
There could be two reasons why you have black bars on all sides. One has already been identified as underscan. This occurs when the video output does not extend to the outer edges of the display. Depending on the type of GPU your HTPC has, there may be a way to expand the image to fill the screen using the utilities that were installed along with the GPU drivers.
A second possibility is that you're watching a standard definition image that's letterboxed in a 4:3 image area. This is easily remedied by using the zoom feature on your TV.
captain_video is offline
post #4 of 11 Old 01-09-2012, 07:30 AM
Speqtre's Avatar
Since you said "all output", I'd concur it's an underscan issue.
If everything else was working fine but 7MC, I'd tell you you have to run the Setup wizard in 7MC, as it seems to like to do its own thing separately.
Speqtre is offline
post #5 of 11 Old 01-09-2012, 08:06 AM
Quoted: 511 Post(s)
Liked: 336
I guess it helps to read all the words in the post. Definitely an underscan issue.
post #6 of 11 Old 01-10-2012, 04:45 AM - Thread Starter
lvisneau's Avatar
Thanks for the replies.
What is 7mc and where would i find it?
Edit: doh! windows 7 media center.
Ok, how do i do a setup and what do i change in my situation?
My sono build
Xbl- chief vizzy
lvisneau is offline
post #7 of 11 Old 01-10-2012, 05:45 AM
flocko's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=1302559
Come on guy's ! Use the guide . The free stuff is really great but the paid "stuff" is wicked awesome and will save you weeks of frustration.
flocko is offline
post #8 of 11 Old 01-10-2012, 08:49 AM
cdru's Avatar
Quoted: 20 Post(s)
And it will only take you several months to read through the nearly 32,000 posts between Assassin's Simple/Beginner HTPC Buying Guide, Guide to Building a HD HTPC, and Windows 7 Media Center : Setup Guide, Knowledge Base & Support. All of which mention over/under scanning among about 10k other various topics.
cdru is offline
post #9 of 11 Old 01-10-2012, 09:56 AM
idividebyzero's Avatar
Quoted: 34 Post(s)
did you set the resolution to 1920x1080? My tv underscans if I set the resolution to anything other than 1080 or 720
idividebyzero is offline
post #10 of 11 Old 01-11-2012, 05:27 AM - Thread Starter
lvisneau's Avatar
You know if you would have asked something in a forum that i frequent daily (diy subs, ht gaming, projectors) I would have answered your question in order to help you and possibly save you some time. but thats cool, I'll see if i can find the answer somewhere in that thread.
My sono build
Xbl- chief vizzy
lvisneau is offline
post #11 of 11 Old 01-16-2012, 12:43 PM - Thread Starter
lvisneau's Avatar
I finally figured it out. I had to set my projector's video scaling to 92%. Now there's a head scratcher for ya! 92% huh? who woulda thunk it?
My sono build
Xbl- chief vizzy
lvisneau is offline
Reply Home Theater Computers
