Official Ceton Echo Extender Info Thread - Page 145 - AVS Forum | Home Theater Discussions And Reviews
post #4321 of 7721 Old 12-13-2012, 06:09 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Originally Posted by rdb4133 View Post
So I've had my Echo from Newegg boxed up for a bit over a week now and figured I would wait until things have settled down which it looks like they have.
I unboxed my Echo for the first time tonight, hooked up HDMI, Ethernet & USB/Power connection, CETON logo comes on in the front but no video at all. I have tried the following:
1. Tried on two different TV's with two different HDMI & Ethernet cables.
2. The remote does seem to be responding because I can press the power off button and the CETON logo on the front turns off.
I looked through Ceton's knowledge base and such but didn't really see anything for this issue.
Any advice out there for what to try? I'm going to go ahead and submit a ticket to Ceton as well.
edit/update: I have 360 slim extenders at these same locations working perfectly fine if that matters at all.
If you wait a few minutes and nothing happens, you have a doa unit. Quite a few ppl got this. Return it.
Foxbat121 is offline
post #4322 of 7721 Old 12-13-2012, 07:05 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Originally Posted by Munkee Boy View Post
So how long until this update hits the beta channel so us poor saps who were unlucky enough to miss the beta program can finally get some smooth playback?
I think it will probably hit today. The pq is very good now for me and mine ran very smooth for a couple hours last night before I needed to get some sleep and after initial hiccups installing the update. Thank god for the self recovery mechanism built into the echo.
Sammy2 is offline
post #4323 of 7721 Old 12-13-2012, 07:11 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Before returning it, take a look at the front of the echo. If you see litte red LED's, it is going through recovery which can take more than just a few minutes but if it lasts more than 30 minutes you have issues.
Also, is the echo showing up on your network in your router configuration page? If it is open a ticket with ceton and they can access it remotely and hopefully jump start it.
Sammy2 is offline
post #4324 of 7721 Old 12-13-2012, 08:29 AM
radams927's Avatar
i've moved on to testing the echo with HTPC #3. it's a very clean build, the haali splitter is the only thing installed on it. still freezes up after a few minutes of use - just like HTPC #1 and HTPC #2. working with ceton to resolve, but it's getting old.
radams927 is offline
post #4325 of 7721 Old 12-13-2012, 08:52 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Originally Posted by shortcut3d View Post
Not yet an Xbox 360 replacement. HBR playback is still questionable.
I'm on 1206 firmware, not the latest one that fixes 1080i. But HBR mkvs work fine for me now. HBR m2ts files are still broken. So is WMV.
post #4326 of 7721 Old 12-13-2012, 09:05 AM
xnappo's Avatar
Quoted: 87 Post(s)
Liked: 85
What splitter are you using? Also - sometimes the issue seems like a network problem. That doesn't make much sense to me, because the volume of data in the TV streams is much higher than the MKVs that give me trouble - but perhaps there is something with the large peaks of data in MKVs that is a strain on the network?
xnappo
xnappo is offline
post #4327 of 7721 Old 12-13-2012, 09:21 AM
rdb4133's Avatar
Thanks Sammy2 & Foxbat,
I started the recovery process this morning before heading off to work, I still didn't see anything on the screen but pressing the number sequence for "recovery" did make it light up in the front, when I get home later on I'll check it out and see what happened smile.gif
rdb4133 is offline
post #4328 of 7721 Old 12-13-2012, 10:29 AM
erickotz's Avatar
Liked: 30
Please open a support ticket before returning the unit. There are many reasons that could cause this behavior, and we can probably help you out without an RMA.
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #4329 of 7721 Old 12-13-2012, 11:15 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
F/W 2012.1212.1449 (OMEGA) should be available to all on the beta channel now. Here's the change log:
1.Improve playback quality of interlaced content
2.Stability fixes
3.Add 'Native' resolution setting to playback content at its original resolution
4.Make device webpage more functional
5.Detect missed HDMI unplugs
Sammy2 is offline
post #4330 of 7721 Old 12-13-2012, 11:25 AM
skybolt's Avatar
Liked: 24
2.Stability fixes
Sammy2, How did you get the latest FW? I am still on 1720, or something. nothing was available this morning?
skybolt is offline
post #4331 of 7721 Old 12-13-2012, 11:29 AM
bdraw's Avatar
Quoted: 161 Post(s)
Liked: 70
Are you going to update your review?
Yes, once the update is out of beta.
Ben
How good could it be if it isn't HD?
No longer contributing to Engadget HD
bdraw is offline
post #4332 of 7721 Old 12-13-2012, 11:30 AM
bdraw's Avatar
Quoted: 161 Post(s)
Liked: 70
If you go to the About page in settings and set it to beta, you'll be able to download the update -- it just got upgraded from omega to beta.
Ben
bdraw is offline
post #4333 of 7721 Old 12-13-2012, 11:33 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
It just pushed about 20 minutes ago per michael on the ceton beta forum. Put your echo in the beta channel in the About section. It may take a little while to get to you but check in 15 to 30 minutes.
I should add that the green screen issue still remains but that was in the previous beta f/w so ceton is pushing this one now for the jittery video fix.
Sammy2 is offline
post #4334 of 7721 Old 12-13-2012, 11:33 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Ben, that is awesome. It shoud be a much better review now.
Sammy2 is offline
post #4335 of 7721 Old 12-13-2012, 11:50 AM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Does the resolution changing work for movies too via media browser? Any chance it outputs the native refresh rate too?
lockdown571 is offline
post #4336 of 7721 Old 12-13-2012, 11:56 AM
tlniec's Avatar
I've been quietly following this thread, and I have to say I'm pretty excited to read the news of this latest FW update too. I am really hoping to get the cable STB out of my bedroom, but WAF won't allow for an XBox 360 there. And sadly, having the HTPC in the room directly connected to the TV just didn't make the grade either. So, I've been anxiously awaiting the Echo pretty much ever since the initial announcement. If it gets to the point where it can play back full Blu-Ray bitrate MKVs through WMC via MediaBrowser (when served via a HTPC with the LAV codec pack installed), I'll be all over the Echo. Heck, even if that doesn't come, I might have to go for it anyway! biggrin.gif
tlniec is offline
post #4337 of 7721 Old 12-13-2012, 12:09 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Not yet in limited testing.
Sammy2 is offline
post #4338 of 7721 Old 12-13-2012, 12:13 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Just a head's up. It may show as 2012.1213.1022 as ceton did a minor tweak before putting it on the beta channel.
Sammy2 is offline
post #4339 of 7721 Old 12-13-2012, 12:27 PM
Ken.F's Avatar
Quoted: 1471 Post(s)
Liked: 1255
It came through as 2012.1212.1449 here. I tried all of the video settings and still have some judder.
Ken.F is offline
post #4340 of 7721 Old 12-13-2012, 12:37 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
Send a message via Skype™ to mariob33
Let me add that you can now type in the local ip address of your echo in your browser and configure settings there using a GUI too.
only thing I don't like about this is the there is no sleep or standby option so the echo must be on to do this today.
In search of video bliss...
mariob33 is online now
post #4341 of 7721 Old 12-13-2012, 12:43 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
At the power usage level of the echo I don't see this as a problem, though. I leave my PC and HTPC on all the time and they use way more power. I'm going to look into sleeping my HTPC but that could be an issue with PLEX, the companion and / or the echo as well as remote sessions from my PC and HDHR Prime tuner. I don't know if I have the time to go down that path just yet.
Sammy2 is offline
post #4342 of 7721 Old 12-13-2012, 12:58 PM
khubo's Avatar
Completely agree. That is why I am excited for the Echo and its WOL feature.
khubo is offline
post #4343 of 7721 Old 12-13-2012, 01:01 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
there is a newer one 2012.1213.1022 under beta
post #4344 of 7721 Old 12-13-2012, 01:03 PM
mariob33's Avatar
Quoted: 88 Post(s)
Liked: 66
im being picky as I don't like that bright CETON logo. Im hoping they allow dimming real soon.
post #4345 of 7721 Old 12-13-2012, 01:05 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
True. It is WOL for the other things I listed that concerns me. Not for this thread though.
Sammy2 is offline
post #4346 of 7721 Old 12-13-2012, 01:06 PM
skybolt's Avatar
Liked: 24
Yes until that happens the Echo MUST be turned off ...
skybolt is offline
post #4347 of 7721 Old 12-13-2012, 01:06 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
That will probably cut the energy usage of the echo by 90%!! LOL. Seriously though, it is obnoxious. I have mine in an enclosed cabinet with solid doors and that light leaks out. Maybe now that a big hurdle is or is close to being crossed some of this little stuff can be tweaked in future f/w.
Sammy2 is offline
post #4348 of 7721 Old 12-13-2012, 01:12 PM
erickotz's Avatar
Liked: 30
The lighting is software controllable - we just need to add a UI for it. We plan to do that.
erickotz is offline
post #4349 of 7721 Old 12-13-2012, 01:25 PM
Ken.F's Avatar
Liked: 1255
Got it, thanks.
Ken.F is offline
post #4350 of 7721 Old 12-13-2012, 01:34 PM
Ken.F's Avatar
Liked: 1255
I don't mind the ceton logo being lighted but it sure is bright. I thought about putting a piece of window tinting film over it. I won't bother now that I know there's something planned.
Thanks for all the hard work you guys have been doing in getting these firmware updates out.
Ken.F is offline
Closed Thread Home Theater Computers
Blu Ray Players
