Official Ceton Echo Extender Info Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
post #1081 of 7721 Old 08-08-2012, 06:14 AM
tkole's Avatar
Originally Posted by potts.mike View Post
Fingers crossed this means a well documented IP control interface.
The ability to plug in a usb ir receiver would be great. I run a bunch of those to my htpcs already over cat5 and it works so much better than an ir repeater.
tkole is offline
post #1082 of 7721 Old 08-08-2012, 07:57 AM
pnkflyd51's Avatar
Location: Hopkinton, MA (originally from Bloomington, IN)
Hi everyone-
A question on WMC Extenders- in order to watch a "live" channel on an Extender, does a tuner have to be semi-permanently dedicated to that extender?
I have a Ceton InfiniTV 4 tuner USB on my HTPC. In order to watch live TV on another Win7 PC, I have to dedicate a tuner to the other PC through the Ceton settings. Is this not the case for Extenders? I hope not...
I'm trying to decide if I should wait for the Echo, instead of buying WD Live Streaming devices that play back .wtv files via DLNA... The WD devices won't let me watch live channels of course- and I'm also having trouble fast forwarding via my current WD Live Hub (3/4s the time after I press play to stop fast forwarding, the video stops and I get kicked back out to the list of files- so basically I can't do commercial skips- yuck!)
The Echo will be more expensive, but being able to watch channels live, and to have working fast forwarding will make them worthwhile (I'm thinking of buying three when they come out...)
At $179, they'll pay for themselves in ~2 years compared to $8 rental per HD box from my cable company...
pnkflyd51 is offline
post #1083 of 7721 Old 08-08-2012, 08:01 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Originally Posted by pnkflyd51 View Post
Hi everyone-
No need to. WMC automatically manages tuner pool quite well. If you have two extenders watch the same channel, you will all share the same tunner, instead of two, but different live buffers so that you can individually pause and rewind.
That's the limitation on Ceton network sharing. Other tuners like SiliconDust HDHomeRun Prime don't have this limitation. But with multiple PCs, you can't share the tuners like you can with one PC and multiple extenders.
Foxbat121 is online now
post #1084 of 7721 Old 08-08-2012, 08:10 AM
pnkflyd51's Avatar
Thanks for the info. It's too bad the 2nd PC's WMC can't act "as an extender" itself so that a tuner doesn't have to be dedicated!
Anyway, with that news, it sounds like it's worth it to me to wait 3-5 more months for the Echo and pay more- so that I'll get to watch HD channels live on my other TVs. Right now on my three other TVs I only get basic cable in SD via a "DTA" box and I have to flip a switch on them to watch local channels in HD. This is annoying... (I'm not willing to pay comcast $8/tv for all my TVs...)
Hopefully the Echo beta testing goes well and these things go on sale sooner rather than later!
I just moved into my new house- where I had two Cat 6 jacks put into all the bedrooms and other main rooms of the house- so I have plenty of network capacity! Can't wait to start using it for HD video! I just plugged in a new 16 port gigabit ethernet switch last night.
post #1085 of 7721 Old 08-08-2012, 09:13 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm going to try the Echo beta wirelessly with a bridge going from a wirelessN/gig router in my office to a bridge in my kitchen which is about 15 feet. I have the HDHR Prime as a tuner but SiliconDust doesn't have an extender. Of course I am also going to try it via ethernet. I too hope the beta goes well.
Sammy2 is offline
post #1086 of 7721 Old 08-08-2012, 10:51 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
I'm not seeing mkv listed on preliminary specification sheet?
Sammy2 is offline
post #1087 of 7721 Old 08-08-2012, 11:01 AM
perpetual98's Avatar
Quoted: 69 Post(s)
Liked: 46
WTV also isn't listed.
perpetual98 is offline
post #1088 of 7721 Old 08-08-2012, 11:04 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Ceton has publicly stated it is a dvr extender so it has to handle wtv so maybe they overlooked mkv as a format it can handle? Maybe Eric will chime in on this or maybe I wait a few more weeks to find out for sure.
Sammy2 is offline
post #1089 of 7721 Old 08-08-2012, 11:08 AM
Derek K.'s Avatar
the echo spec sheet looks like a cut and paste job from any of the other standalone media center extenders spec sheets. probably explains the wtv omission.
Sammy2 likes this.
Derek K. is offline
post #1090 of 7721 Old 08-08-2012, 11:19 AM
hub1's Avatar
That's an old spec sheet.
http://cetoncorp.com/products/echo/
This is the current one on their website
hub1 is offline
post #1091 of 7721 Old 08-08-2012, 11:24 AM
whiteboy714's Avatar
I still think it's not complete. Doesn't even show ac3 audio.
whiteboy714 is offline
post #1092 of 7721 Old 08-08-2012, 11:40 AM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
We'll know for sure in a few weeks...
Sammy2 is offline
post #1093 of 7721 Old 08-08-2012, 11:51 AM
hub1's Avatar
hub1 is offline
post #1094 of 7721 Old 08-08-2012, 11:57 AM
Derek K.'s Avatar
Originally Posted by hub1 View Post
why? media streamers don't need gigabit ethernet.
Derek K. is offline
post #1095 of 7721 Old 08-08-2012, 12:00 PM
hub1's Avatar
To eliminate the buffer issue of the XBox 100mb when connected to a gigabit switch....
hub1 is offline
post #1096 of 7721 Old 08-08-2012, 12:20 PM
Derek K.'s Avatar
that is a problem with the implementation, not because of the speed of the network link. sage extenders work just fine streaming full bit rate bd rips over 100 mbps. no buffering problems.
Derek K. is offline
post #1097 of 7721 Old 08-08-2012, 12:29 PM
hub1's Avatar
"Implementing" the echo in place of the xbox should make me happy biggrin.gif
hub1 is offline
post #1098 of 7721 Old 08-08-2012, 03:03 PM
motz2k1's Avatar
Originally Posted by blueiedgod View Post
Depending on the size of the kitchen, even a 19" may be too small. We have a 260 ft² kitchen, and the stock speakers in most TV's can't cut through the noise generally generated in the kitchen during cooking. I ended up putting up a shelf above the TV with a set of Dell computer speakers with a sub, and put the Linksys DMA2100 there too. Now the TV can be clearly heard by the stove from the other side of the room $over 10 feet)
My entire apartment is only 500 sqft frown.gif although I do have a 55" panasonic plasma, basically dominates the room smile.gif
Looking for a 120V LCD TV with an HDMI input. Because it will be used with the Echo it won't need a DVD player, tuner or radio, which gets me thinking, maybe all I need is an HDMI monitor with speakers or audio out.
yeah HDMI monitor would work great with it.
The spec sheet will be updated completely when we announce the final specs. So stay tuned.
Software Developer on My Media Center -> Ceton Corp.
motz2k1 is offline
post #1099 of 7721 Old 08-08-2012, 03:11 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
With wall cabinets and all a 55" plasma definitely won't fit!!
Yeah, I have a few things I want to test with the Echo. A kitchen TV connected wirelessly is one of them. If that doesn't work I won't blame the Echo but wire it up. I'm also going to test it with my primary system too and hopefully get my H 900 programed to work with it.. And my Rii N7 keyboard will hopefully connect to it too if there's a USB port to connect the RF receiver. Then there's android but I may have to wait on that. A HTML5 web interface would be slick because that would permit use across platforms (similar to the upcoming mobile AVSForum website).
Thanks for your response. It is much appreciated to get a resonse from the developer!!
Sammy2 is offline
post #1100 of 7721 Old 08-08-2012, 03:30 PM
Quoted: 69 Post(s)
Liked: 46
I was hoping that there would be a VGA output on it, but figured there wouldn't be. Thought it would open a market where people could plop an Echo onto extra LCD monitors that they had laying around. My projector in the basement doesn't have HDMI either where I would really be excited to try it out, but I can use it in the bedroom where that TV has HDMI.
post #1101 of 7721 Old 08-08-2012, 03:47 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
VGA = no content protection which cannot happen for CableTV.
Sammy2 is offline
post #1102 of 7721 Old 08-08-2012, 04:21 PM
Quoted: 69 Post(s)
Liked: 46
Fair enough. Do HTPCs with Cable Card tuners in them somehow disable the VGA output? I don't have a CC tuner, so I don't know. The only TV my HTPC does is via an OTA antenna and an HDHomerun and a couple of Pinnacle USB sticks.
post #1103 of 7721 Old 08-08-2012, 04:25 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Yes. No signal will go across the VGA but this is controlled by WMC itself, AFAIK.
Sammy2 is offline
post #1104 of 7721 Old 08-08-2012, 04:51 PM
mcturkey's Avatar
Liked: 43
Actually, that's not technically correct. I was using the VGA output on my HTPC for quite awhile without issue, even for protected content. HDCP is actually bypassed when using VGA, surprisingly enough. Full 1080P and all.
mcturkey is offline
post #1105 of 7721 Old 08-08-2012, 05:19 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
You are correct.
Come to think of it, my monitor at my desk at home is VGA and LiveTV works fine even for CopyOnce flagged content.
Sammy2 is offline
post #1106 of 7721 Old 08-08-2012, 10:56 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Now this has me thinking. Will a VGA to HDMI converter work? If yes then I'm taking the 19" monitor with speakers off my desk and putting it in the kitchen with the Echo and getting a larger monitor for my desk. Sounds like a good plan, yes?
Sammy2 is offline
post #1107 of 7721 Old 08-08-2012, 11:02 PM
mcturkey's Avatar
Liked: 43
No way to go from VGA to HDMI without using a powered adapter of some sort, since it has to convert between digital and analog. I've never actually seen an adapter for that, though.
mcturkey is offline
post #1108 of 7721 Old 08-08-2012, 11:13 PM
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Sammy2 is offline
post #1109 of 7721 Old 08-09-2012, 06:05 AM
Paw Paw's Avatar
If you are trying to convert the HDMI output from the Echo to VGA make sure the converter is HDCP compliant. Otherwise you will not be able to watch any of the channels that are marked "copy once". I did not see HDCP mentioned on the Newegg page but the manufacturer's page may document that it is compliant.
Paw Paw is online now
post #1110 of 7721 Old 08-09-2012, 07:07 AM
Quoted: 69 Post(s)
Liked: 46
Check this guy out at monoprice. Claims HDCP compliance.
Closed Thread Home Theater Computers
Blu Ray Players
