Official Ceton Echo Extender Info Thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2012, 07:54 AM
Liked: 651
Originally Posted by erickotz View Post
Except other tuners may require services, libraries, COM objects, and other things that have been stripped out of the embedded install - there's just too many unknowns to officially support this. I'm not saying we are going to intentionally block it, but I can't see this ever being a supported feature.
As far as I remember, it has digital audio out - where did you see that it does not?
Let me ask this - what do you guys want as far as "backdoors" - I can't make any promises, but if you tell me what you're looking for, I'll see what I can do.
All I saw was a mini jack for audio, didn't see an optical port. If it's coax digital out from there, that's fine.
The backdoor I'm thinking of could be a simple 'advanced mode' setting (either hidden or not), which would enable tuners and WMC plugins to be installed. This would definitely be unsupported by Ceton.
slowbiscuit is offline
Old 01-16-2012, 08:24 AM
pman555's Avatar
Quoted: 42 Post(s)
Holy crap, this is exactly what I was looking for.
So, this will be able to play live tv from my HTPC (if i add a ceton tuner) as well as play recorded material from said HTPC, right?
If so, it might help me make the jump to get rid of those cable boxes!
pman555 is offline
Old 01-16-2012, 09:43 AM
hogues's Avatar
Quoted: 73 Post(s)
Liked: 51
Originally Posted by stanger89 View Post
Way OT, but Jeff has said they're still working on SageTV at Google, and the guide data's guaranteed date has been extended to the end of 2012.
Excellent, that's good news. Thanks for the info.
My only point is "successful" and "mainstream" are not necessarily the same thing. Many of the best products are most certainly not mainstream.
Agreed. As I said, It's a balancing act for Ceton or any company that caters to our crowd.
Ok, that's enough OT for me!
hogues is offline
Old 01-16-2012, 12:22 PM
ProAm500's Avatar
All i want is an extender that has support for as many codecs, formats, extensions, or whatever natively without transcoding as possible. Anything after that is a bonus for me.
ProAm500 is offline
Old 01-16-2012, 12:55 PM
qz3fwd's Avatar
Quoted: 319 Post(s)
Liked: 135
So is this thing going to be locked down, and only allowed to run binaries signed by Ceton/MS?
In other words, say I innovate and develop a super fancy new app for it which provides functionality neither Ceton nor MS provides.
Will I be able to compile, install, and run the executable / driver on this box? Somehow I highly doubt it.
I can tell you that I for one would like to be able to use my HDHR ATSC tuners on this box, which would require installing the SD drivers.
Maybe also a NFS server since SMD does not always cut it.
qz3fwd is offline
Old 01-16-2012, 01:43 PM
S1DIMMER's Avatar
Quoted: 21 Post(s)
Here's a video from thedigitallifestyle.com with a cool demo of the units:
http://thedigitallifestyle.com/w/ind...indows-8-apps/
Can't wait for these to come out.
S1DIMMER is offline
Old 01-16-2012, 02:59 PM
cybrsage's Avatar
Liked: 154
I would like to have a link on the Echo into my MediaBrowser on my HTPC, so I can play my DVD and BR rips on the Echo. If I cannot, it really does me no good.
cybrsage is offline
Old 01-16-2012, 03:21 PM
stanger89's Avatar
Quoted: 2693 Post(s)
Liked: 1377
Eric/Ceton,
It's probably too late in the design phase, but one thing a lot of SageTV Extender customers requested from SageTV was a port on the extender to run an external IR reciever, so that you could mount the extender out of the way (eg on the back of the TV) and just run the reciever out into the room so you reduce clutter.
The HDMI CEC would work for those with newer HDMI sets (assuming it works and I've heard very mixed reports on how well that works) but not for those with older sets.
stanger89 is offline
Old 01-16-2012, 03:52 PM
stanger89's Avatar
Liked: 1377
That looks pretty sweet, here's hoping they come up with a solution for us Cable-haters (aka D* subscribers)
Old 01-16-2012, 04:06 PM
werd's Avatar
Thanks for the link, looks great.
werd is offline
Old 01-16-2012, 06:21 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Eric/Ceton,
That's actually solved quite easily. An IR extender "eye". It has an eye on one end and a stick on emitter on the other end. Just stick the emitter on to the Echo's IR front (on top of the glass works just dandy), and extend theeye whereever you want. It can go up to almost 300ft.
Kinda like how the Harmony RF extender works.
kapone is offline
Old 01-16-2012, 07:29 PM
stanger89's Avatar
Liked: 1377
Except last time I looked at IR extender systems they were quite costly (on the order of an extender's cost) if they were any good, and way, way overkill for just one device.
Old 01-16-2012, 08:28 PM
Gregory's Avatar
Agreed.........nice demo!
For me to get the Q it will have to either, have an integrated ATSC tuner or support for an external tuner(s). I have cable, but every time I look at that damn bill I get disgusted. I want ATSC to use as the primary due to its better image quality and cable when I run out of OTA tuners or can't get the channel on OTA.
I sure would hate to have a cable only box, which would become worthless as a DVR if I decide to cut cable. If the Q won't cut it then it will be a PC and hopefully, the Echo.
What I need:
- ATSC support
- good format support from the Echo
Maybe Silicon Dust or others will come out with their own stuff!
Gregory is offline
Old 01-17-2012, 05:22 AM
Artslinger's Avatar
I agree I need to play my DVD/BR rips, if it can do this I'm in.
Artslinger is offline
Old 01-17-2012, 06:28 AM
Derek K.'s Avatar
+1. the remote ir receiver is great on the hd-300.
another wish along the same lines would be the ability to turn off all the leds. I have to put electrical tape over the leds on the sage extenders because they light up the room. the flashing ethernet activity light was especially annoying...
Derek K. is offline
Old 01-17-2012, 06:42 AM
HDvids4all's Avatar
I wonder if you could get away with just using a standard Windows ir receiver that connects via USB? The Q has USB ports (not sure about the Echo, can't seem to find a pic of the back), so all they would need to do is include the basic MS driver.
On a similar note, it would be nice if the Echo had VESA mounting holes on the bottom for easy installation behind a TV.
HDvids4all is offline
Old 01-17-2012, 07:14 AM
S1DIMMER's Avatar
Quoted: 21 Post(s)
Basic extender support plus the ability to play DVD/Blu-ray rips would be killer. I wonder if MyMovies plugin is going to work or even media browser. Hopefully adding Echos to my setup won't require hours of work on the back end making everything compatible.
Currently I use a Linksys DMA 2100 Extender on one of the TV's in my house. It's ridiculously slow but it's quiet and I velcroded it to the back of a wall mounted TV with the unit peaking out just a bit on the bottom. It's mostly hidden and the IR works fine. It does lockup and freeze on occasion requiring the power cable to be pulled, then it works fine again. It will be so nice to have some more modern tech in an extender. I've tried my old XBOX 360 which works better as an extender but sure won't velcro to the back of the TV and it's too loud. Looking forward to the Echo's release.
I tried the tuner sharing too but I don't like to dedicate a tuner to lets say the office computer. I'm not in the office a whole lot but it is nice to have live TV in there once in a while without tying up a tuner all the time. I'd definitely be in for 2 Echos but I can think of at least 2-3 more places in my house that could use additional Echos.
S1DIMMER is offline
Old 01-17-2012, 07:55 AM
Jobber8742's Avatar
This.
Jobber8742 is offline
Old 01-17-2012, 08:23 AM
ShoutingMan's Avatar
Quoted: 242 Post(s)
Liked: 46
Can you elaborate on this? I'm looking into an HTPC build, with a 360 extender for now (but interested in the Echo).
To use live TV with an extender, doyou have to pre-assign a tuner from the main unit to it? I thought you could just "grab" one on the fly when using the extender?
ShoutingMan is offline
Old 01-17-2012, 08:25 AM - Thread Starter
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
you have to pre-assign ceton tuners to various PCs on the network. so if you had your ceton inside the living room pc, but also wanted to be able to pull in live tv on your office pc, you would have to dedicate one of the four tuners to the office computer.
the remaining three would be up for grabs between living room and extenders.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Old 01-17-2012, 08:31 AM
HDvids4all's Avatar
No, you are correct, extenders will just grab an available tuner not currently in use, then automatically release that tuner if you're not watching live TV.
Dedicating networked tuners are for PCs only.
Old 01-17-2012, 10:37 AM
S1DIMMER's Avatar
Quoted: 21 Post(s)
I had originally setup my office PC to share one tuner from my HTPC in the family room. I didn't like losing the use of that tuner in the family room when the office PC wasn't being used. The extender model is much better. Grabbing the tuner with an extender temporarily for the couple of minutes or hours I'm in the office would be ideal. This way when not in use in the office the tuner could record shows in the family room where most of the TV watching happens.
I don't see why another PC couldn't be used as an extender for live TV rather than having to dedicate a tuner to it? I can see Ceton creating an extender application for us to use on our PCs to avoid the dedicated tuner issue. Would be even better if it was a media center plugin. All it would have to do is stream live TV since I have no issues with streaming any other media to my other PCs in the house. The only issue is a dedicated tuner vs extender borrowing a tuner model.
And for those of us early adopters it would be nice to get a little future product discount coupon from Ceton for paying the early adopter premium on the InfiniTV cards. The price dropped to $300 pretty quickly after I received my 2 cards at $400 each.
That said I still love Ceton - they're listening to us and doing the best they can to bring our community what we want while still working with the restrictions placed on them by other sources. I'm confident they'll get there. They should be admired in the industry. It's rare to find a company that listens. Thank you Ceton Corp!
S1DIMMER is offline
Old 01-17-2012, 10:53 AM - Thread Starter
Quoted: 648 Post(s)
Liked: 426
the silicon dust tuners are assigned to a computer only when they are used. after that they are up for grabs by any computer
Old 01-17-2012, 11:15 AM
stanger89's Avatar
Liked: 1377
Sort of, but, well lets just say I'm not comfortable with the HDHR's conflict arbitration. The way I understand it works is every configured app/computer thinks they are always available. Tuners are doled out in a first come, first serve basis.
This means that if, using S1's example of a PC in the office, if you start watching something live on that PC, that tuner is now locked and can't be overridden. This could cause a missed recording because the main HTPC can't override. It seems up to the app how to deal with that, and I don't know of any DVR app that's really set up to deal with HDHR's built in locking well. So you'd have no indication that another box wanted to do a scheduled recording.
I suppose it's better than the way it originally was where I think whoever asked last won.
Old 01-17-2012, 02:36 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Sigh...Softsled...where art thou??
kapone is offline
Old 01-17-2012, 03:09 PM
jhoff80's Avatar
Quoted: 380 Post(s)
Liked: 334
I doubt this will be possible, but since it supports MoCA, it might be nice to reconfigure the Ethernet port to a bridge mode, to be able to connect Internet to a newer TV or gaming console. Wishful thinking though, I'm sure.
XBL/Steam: JHoff80
jhoff80 is offline
Old 01-17-2012, 03:29 PM
Mike7143's Avatar
Pretty stoked about the news of this Echo device. I've got a PC running the InfiniTV 4 with 2 extenders (Xbox) in the house. I've been absolutely thrilled with it but the Echo could make it so much better!
Dear Ceton,
If the Echo can:
1. Allow me to do Netflix/Hulu/Youtube
2. Natively support MKVs and many other formats
3. Pop a blu-ray into the host PC's blu-ray drive and stream it to the Echo
I'd buy one for every TV in the house and every TV in all my friends', families', coworkers', and strangers' houses.
Mike
I think that 1 and 2 would be simple enough? 3 would be great but I'm not sure if it'd be possible. I just want to play a DVD/Blu-ray from the host's drive on my extender! I refuse to pay for Live Gold to do Netflix currently since I don't game. I've also tried a few Netflix plugins but they don't seem to work anymore; same with youtube plugins. Regardless of what the outcome is of the Echo, it'll hopefully ignite the media center platform and help propel it past it's previous state.
Mike7143 is offline
Old 01-17-2012, 04:35 PM
werd's Avatar
Suggestions - Focus big on support like netflix, hulu, MLB.TV / Sunday Ticket on the go(ps3 has it) NBA NHL etc etc.
werd is offline
Old 01-17-2012, 04:50 PM
Micromain's Avatar
Based on the demo video that was posted previously, the ethernet port and MoCA adapter are modular components that are swapped out of the same location. So you can have one or the other but not both at the same time, at least on the extender.
Micromain is offline
Old 01-17-2012, 05:13 PM
Quoted: 242 Post(s)
Liked: 46
Thanks for the explanation.
Blu Ray Players
