Official Ceton Echo Extender Info Thread - Page 85 - AVS Forum | Home Theater Discussions And Reviews
post #2521 of 7721 Old 11-01-2012, 07:40 AM
gsr
Oppo Beta Group
gsr's Avatar
Quoted: 1206 Post(s)
Liked: 1247
Originally Posted by Anastasis View Post
ship date 10/31, delivery date 11/6? WTF?
fedex to texas
If it's FedEx Ground, that sounds about right as they don't deliver to residential addresses on Mondays (they deliver Tuesday - Saturday).
gsr is online now
post #2522 of 7721 Old 11-01-2012, 07:48 AM
Warpster's Avatar
FEDEX Ground to Nebraska
FedEx Ground delivers Monday through Friday,
FedEx Home delivery only delivers Tuesday through Saturday.
Warpster is offline
post #2523 of 7721 Old 11-01-2012, 09:10 AM
Haba's Avatar
Originally Posted by Sammy2 View Post
I don't have anything in XVID. All my stuff is in mkv which looks like must be split on the host machine like any other container. The extender is basically a special RDP session and doesn't do any processing itself, so to speak.
I must admit I am not on top on all the different codecs/container issues so feel free to correct me, I find it all very confusing. I think what you are stating may be true with MKV files left in the MKV format forcing the HTPC to transcode the file to the Echo Extender since it doesn't natively support MKV. Transcoding utilizes a lot of HTPC cpu. I want to be able to watch a movie or live tv on all the Extenders and HTPC at the same time without issue so I am trying to stay away from transcoding all together. I did some research on the Xbox 360 which shows what it is capable of playing without transcoding or issues. I tried doing some re-encoding but it takes way too to long. I use Xmedia Recode 3.1.1.8 to remux or change the container from MKV to MP4. The Xbox 360 is very limited on the bitrate and it is different depending upon the codec/container used. I have stayed away from really high bit rate rips (Blu-ray) since the Extenders are so limited. Xmedia can also re-encode the audio if needed or re-encode the video if you are not able to remux the file. I am really hoping Ceton can get the Echo to handle everything I can throw at the Xbox 360 without transcoding.
Some good info if you have the Xbox is at Media Browser's site.
Xbox 360 Media Playback problems?
Configure Xbox 360 Valid Extensions
Xmedia Recode
psuKinger likes this.
Haba is offline
post #2524 of 7721 Old 11-01-2012, 09:27 AM
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
There is no transcoding. Only opening the mkv container on the HTPC and sending the video (AVC or VC-1) and the audio (AAC right now, AC-3 forthcoming) to the Echo via ethernet for it to move along the chain via HDMI to the AVR (where it is output as sound on the AVR's speakers and video moved along to the HDTV via HDMI), or directly to the HDTV for both sound and picture if there is no AVR in the HDMI chain. CPU utilization is very low. Thus far I have had very good success with mkv's that are under 6kpbs with low CPU utilization (<20% on my i3-550). As the Echo f/w is improved I expect this will improve too.
Sammy2 is offline
post #2525 of 7721 Old 11-01-2012, 09:29 AM
caeguy's Avatar
Still no invoice...the good news that it should happen by Friday, 11:59PM wink.gif
Roginator likes this.
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
post #2526 of 7721 Old 11-01-2012, 09:36 AM
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
Originally Posted by fox1541 View Post
How does it handle XVID files?
My Linksys DMAs play them, but they buffer for about 5-10 seconds before they play.. when it does start, the seek bar is at the end.. I then press pause and play and the seek bar goes to where it should be.
Skipping forward and back is spotty.. some videos don't even skip.
Is there a chance that this will get the ability to play video on its own? (without using Media Center)
I'd like to play MKV files without having to use a splitter on the Media Center.. early on, it sounded like it would natively play them.
I did a little bit of googling and found this:
Originally Posted by wikipedia.org
Xvid is not a video format – it is a program (codec) for compressing and decompressing to the MPEG-4 ASP format. Since Xvid uses MPEG-4 Advanced Simple Profile (ASP) compression, any video that is encoded with it is termed "MPEG-4 ASP video" – not "Xvid video" – and can therefore be decoded with all MPEG-4 ASP compliant decoders. This includes a large number of media players and decoders, in particular all the ones based on the free/open source libavcodec library from FFmpeg (for example, MPlayer, VLC, ffdshow or Perian).
http://en.wikipedia.org/wiki/Xvid
So as long as you have the right splitter it should play. I would think that LAV would take care of this on the host machine just like it does mkv's.
Sammy2 is offline
post #2527 of 7721 Old 11-01-2012, 10:14 AM
skybolt's Avatar
Liked: 24
The thing with XVID is that most files are in .AVI format and will play with a Divx codec installed. xvid.org has good codecs as well. Most are based on DirectShow however.
skybolt is offline
post #2528 of 7721 Old 11-01-2012, 10:24 AM
fox1541's Avatar
the reason I ask is that the experience is supposedly very smooth on the Xbox so I'm not sure if its due to the speed of the Xbox vs the Linksys DMAs or if it's due to the way it connects.
Can someone from Ceton answer if there is any possibility that it will be able to play videos skipping Media Center.. ie: a standalone DLNA, uPNP, etc.. player ?
55LW5600 (mfg date 3/11)
Official LG 47LW5600/55LW5600 "Passive 3D" Owners Thread
Pioneer VSX-45
fox1541 is offline
post #2529 of 7721 Old 11-01-2012, 10:36 AM
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
A dual boot mode is a possibility, the probability of it is unkown at this time as it hasn't been mentioned or discussed by ceton. In other words, extenders, once in the RDP with the HTPC, cannot do anything that is not available in WMC on the HTPC; but I don't think there's limitations to what it can do if it were allowed to boot into a DLNA / uPNP type environment, aka streamer.
Sammy2 is offline
post #2530 of 7721 Old 11-01-2012, 10:39 AM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Send a message via Skype™ to mariob33
I have a few AVI/XVID files compressed using dvdFab and the echo plays them fine. These are all 720p AC-3 which is supported by the echo. I use this more for archival of kids movies where the original is not key. Spongbob looks ok even overly compressed.
In search of video bliss...
mariob33 is offline
post #2531 of 7721 Old 11-01-2012, 10:41 AM
skybolt's Avatar
Liked: 24
I am not answering for Ceton, but Right now the Echo is a dedicated MCX. period. However it does play AVI's without an issue. Mine are not 1080 though.
We all would like the Echo t be able to bypass wmc at this point to be able to do more ...
skybolt is offline
post #2532 of 7721 Old 11-01-2012, 10:43 AM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
To be clear AC-3 is already supported.
mariob33 is offline
post #2533 of 7721 Old 11-01-2012, 10:44 AM
skybolt's Avatar
Liked: 24
Ceton could do what HP did with there x280n. That would work just fine I would think, for most anyway.
skybolt is offline
post #2534 of 7721 Old 11-01-2012, 10:51 AM
psuKinger's Avatar
Quoted: 811 Post(s)
Liked: 239
Xmedia Recode
Very interesting regarding the the 360. I just started ripping to MKV (using Assassin's guide), and ran into all kinds of problems with playback on my 360.
psuKinger is offline
post #2535 of 7721 Old 11-01-2012, 10:55 AM
skybolt's Avatar
Liked: 24
The xbox will choke on ~>20mbps, so most uncompressed ripped BD's will choke for th emost part. BTW, excellant guide from Assassin.
skybolt is offline
post #2536 of 7721 Old 11-01-2012, 10:57 AM
gsr
Oppo Beta Group
gsr's Avatar
Liked: 1247
FedEx Ground is to commercial addresses, FedEx Home is to residential addresses. Depending on the address, there are cases where you can pick either one, but when filling out a shipping label on the FedEx site, the address verifier typically figures out which type of address it is and picks Ground or Home accordingly - I'm pretty sure both of these are operated out of the same depots and the delivery speed is basically the same for both. FedEx Overnight, 2nd Day, and 3rd day fall under the "FedEx Express" umbrella and, at least in my area, use different depots.
gsr is online now
post #2537 of 7721 Old 11-01-2012, 11:26 AM
Sammy2's Avatar
Quoted: 522 Post(s)
Liked: 254
Sort of off subject but it doesn't seem efficient to me. UPS runs every thing through the same hubs and even the same trucks. Fedex has all these different delivery carriers depending on the service type covering the same geographical area.
Sammy2 is offline
post #2538 of 7721 Old 11-01-2012, 11:34 AM
jeonunh's Avatar
Quoted: 31 Post(s)
Liked: 31
Fedex has always been weird. Up until a few years ago every package had to go through their hub in Tennessee. At least they stopped that madness.
jeonunh is online now
post #2539 of 7721 Old 11-01-2012, 11:35 AM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Quick question for those with extenders echo/non-echo. Does anybody know if the echo supports http://www.recordedtvhd.com? I'm thinking of trying it as I have read good things but only if its supported.
mariob33 is offline
post #2540 of 7721 Old 11-01-2012, 11:40 AM
Warpster's Avatar
Well whatever the situation is all I know is MINE is showing up Monday smile.gif
Warpster is offline
post #2541 of 7721 Old 11-01-2012, 11:40 AM
drtdiver's Avatar
Give it a shot they have a free trial. I hope it works with the echo I love the recorded TV HD interface.
Sent from my Nexus S 4G using Tapatalk 2
drtdiver is online now
post #2542 of 7721 Old 11-01-2012, 11:43 AM
gcw07's Avatar
While I don't have an echo yet, Recorded TV works fine on a older 360. Don't see any reason it wouldn't work even better on the echo. You can try it for something like 14 days before buying.
gcw07 is offline
post #2543 of 7721 Old 11-01-2012, 06:25 PM
Haba's Avatar
Read the FAQ
Haba is offline
post #2544 of 7721 Old 11-01-2012, 06:38 PM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Read the FAQ
Yeah and a nickel will get me a cup coffee. I was looking fr real world experience. Thanks rolleyes.gif, I think.
mariob33 is offline
post #2545 of 7721 Old 11-01-2012, 06:42 PM
Haba's Avatar
Read the FAQ
Wrong link above ^^^ this forum is not allowing me to change it.
Try this link instead
Haba is offline
post #2546 of 7721 Old 11-01-2012, 06:50 PM
Haba's Avatar
Excuse me for trying to post some helpful info. Perhaps, it would have been a good idea to insert real world experience in your original question?
Haba is offline
post #2547 of 7721 Old 11-01-2012, 06:58 PM
skybolt's Avatar
Liked: 24
Wow, this is a tough crowd. - not you so much, but dam.
I use Recorded TV HD exclusivly, so much so I removed the standard TV from the main menu with reset toolbox, also movies, and use Media Browser.
The remote supports the guide, so I don't need it as a men item. I could ot would not use MC without these plugins. And a few more as well.
skybolt is offline
post #2548 of 7721 Old 11-01-2012, 07:23 PM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
I use MB now but not all themes render well via the echo. Is recordedtv smooth scrolling on the echo? I know your in the beta any problems with the plugin?
I try to avoid installing any problematic WMC plugins or extras. .
mariob33 is offline
post #2549 of 7721 Old 11-01-2012, 07:25 PM
mariob33's Avatar
Quoted: 94 Post(s)
Liked: 74
Read the FAQ
I was responding based on original link you posted. Thanks for the second link smile.gif
mariob33 is offline
post #2550 of 7721 Old 11-01-2012, 07:47 PM
skybolt's Avatar
Liked: 24
It is much smoother then MB. Its well worth the 15 bucks. Like I said, I removed the tv menu item all together.
I have to admit, I really can't use the Echo much at this point. Too much doesn't work for me. I can only test the fixes at this point.
I am not trying give a dig to Ceton, as this is still a beta. This is just where I am at. I am sure they will figure it out soon.
Edit: yeah, themes are not supported at this point, which is strange since the session is basically RDP.
skybolt is offline
Closed Thread Home Theater Computers
Blu Ray Players
