Crucial M4 SSD Frimware Update Available Now for 5000 hour problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 01-13-2012, 04:18 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
assassin is online now
post #2 of 24 Old 01-13-2012, 10:05 PM
PartyRunner's Avatar
Thanks for posting this. Now the fun of updating two of my systems with the M4.
PartyRunner is offline
post #3 of 24 Old 01-14-2012, 06:59 AM
ckensto's Avatar
Pretty quick and easy.
ckensto is offline
post #4 of 24 Old 01-14-2012, 11:38 AM
Whats a good program to use to burn ISO's to USB? The one I tried doesn't appear to be working properly.
Edit: Found the proper way to do this. http://www.storagereview.com/how_upg...l_ssd_firmware
post #5 of 24 Old 01-14-2012, 11:48 AM
wiggindude's Avatar
For some reason, I'm not able to do the update. I downloaded the CT064M4SSD2 firmware. Extracted the ISO file, burned it to a CD but when I tried to boot the pc from the cd I get a message saying 'disk boot failure, insert system disk and press enter'. I checked the BIOS and it's in the IDE mode. Wonder what I'm doing wrong.
I'm using Toast Titanium (mac) and burned a Data CD.
wiggindude is offline
post #6 of 24 Old 01-14-2012, 04:27 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 556
ImgBurn works well and is free.
bryansj is online now
post #7 of 24 Old 01-14-2012, 05:49 PM
ddiehl's Avatar
Quoted: 18 Post(s)
I double clicked on the iso, which opened Windows Disk Image Burner.. Worked like a charm..
Did the update with AHCI too..
ddiehl is offline
post #8 of 24 Old 01-14-2012, 05:54 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
How long did the entire process take you?
Might be some fantastic deals on these Crucial drives due to this "problem" that scares some away.
post #9 of 24 Old 01-14-2012, 06:03 PM
ddiehl's Avatar
Quoted: 18 Post(s)
Took a few minutes each to burn the iso, and apply the update..
ddiehl is offline
post #10 of 24 Old 01-14-2012, 06:07 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
That's what I thought.
Hopefully we can see these drop in price due to this little scare and spend 5 minutes to fix the issue.
post #11 of 24 Old 01-14-2012, 06:23 PM
Josh3693's Avatar
You need to burn the disc image not as a data disc. Do not extract the iso. Not sure about Mac, but I'm pretty sure most modern burning software will give you the option to burn the .iso image to disk.
Josh3693 is offline
post #12 of 24 Old 01-15-2012, 06:24 PM
digital desire's Avatar
Just did this using the usb stick method. With the gigabyte Z68 motherboard, did not have to change anything in the bios other than boot sequence.
Lot's of low rent stuff stacked up into a medium rent pile.
digital desire is offline
post #13 of 24 Old 01-15-2012, 08:03 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
I have a new HTPC and I'll be installing windows, drivers tomorrow. If I understand you correctly I should first install the original version, then upgrade to this one?
Dropkick Murphy is offline
post #14 of 24 Old 01-15-2012, 10:29 PM
pippipseed's Avatar
What version ?
just initialize your ssd "did it with an external dock" then upgrade to the new firmware
as a new disk without any data it will only take a few seconds , and voila
pippipseed is offline
post #15 of 24 Old 01-16-2012, 02:51 AM
703
703's Avatar
Did the upgrade. Working fine so far, update took about 40secs.
As I leave my PC on, 5000 hours won't take that long to reach!
Founder | BullsEye Calibration | www.bullseyecal.co.nz
703 is offline
post #16 of 24 Old 01-16-2012, 04:29 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Just around 208 days.
Nevcairiel is offline
post #17 of 24 Old 01-16-2012, 10:14 AM
GuyLR's Avatar
Thanks for the tip Assassin. The upgrade went in with no problem and the M4 is flying along as good as ever. I was really happy when the new firmware was announced because I sure didn't want to give up on the performance that it gave my HTPC. Before I installed the M4 last Summer I was just about to give up on having a HTPC because WMC was so sluggish but it was just the thing to make my system come together and work like I wanted.
GuyLR is offline
post #18 of 24 Old 01-16-2012, 10:56 AM
JDLIVE's Avatar
Quoted: 95 Post(s)
Liked: 51
Send a message via Yahoo to JDLIVE
thanks for posting this, wasn't even aware of the issue and would have been blissfully ignorant. Had to change the port to IDE to get it to see the drive, other than that no issues.
JDLIVE is offline
post #19 of 24 Old 01-16-2012, 08:19 PM - Thread Starter
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
A buddy just bought a M4 for the build that I am helping him with.
Looks like a firmware update is in my future!
post #20 of 24 Old 01-16-2012, 09:23 PM
kegobeer's Avatar
My M4 gets here tomorrow, and the first thing I'm doing is applying the firmware update.
kegobeer is offline
post #21 of 24 Old 01-17-2012, 06:00 AM
mandophish's Avatar
Total time from firmware download to actually installing it took less than five minutes. Everything seems to be working fine.
mandophish is offline
post #22 of 24 Old 02-06-2012, 07:53 PM
Quoted: 71 Post(s)
Liked: 89
I'm a little "fuzzy" on this. The install guide says..
Crucial® m4 SSD Firmware Revision 0309
Boot from CD update guide (Update from Rev 0001, Rev 0002, or Rev 0009 to Rev 0309)
But the driver in my system doesn't match up with the literature. I just bought this thing in the last 60 days. Am I just not looking in the right place?
In my device manager I clicked on SSD/properties and the driver is listed as
Driver Date: 6/21/2006
Driver Version: 6.1.7600.16385
I really don't want to screw this thing up because I've spent the last few weeks tinkering and tweaking to get things the way I want them. Anyone have advice?
post #23 of 24 Old 02-06-2012, 09:42 PM
tomandbeth's Avatar
I believe that is the WINDOWS driver. You want to verify that A) you have a Crucial C4 SSD, and then use a bootable CD or USB stick and flash the firmware on the SSD itself. Somebody mentioned they flashed another SSD and toasted it so VERIFY you have the Crucial C4.
tomandbeth is offline
post #24 of 24 Old 02-07-2012, 07:40 AM
jbilliel's Avatar
I bought this as well about 30 days ago and will be doing this update this weekend. Looks pretty self explainatory
jbilliel is offline
Reply Home Theater Computers
