HTPC Audio Lag/Sync Issues -- Audio After Video - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-14-2012, 11:01 AM - Thread Starter
nickman789's Avatar
I am running an HTPC, but for some reason, there is an about 1 second lag on the audio. In other words, the audio is about 1 second after the video. I have tried updating the video drivers with no luck. Same with swapping out the TVs and the HDMI cord; no luck. Tried uninstalling and reinstalling codecs (tried Shark 007 and CCCP); didn't work.
I am running:
Windows 7 64-bit (SP1)
Intel i3-2100 @ 3.10
4 GB RAM
SSD
2nd Spinning HD for Data
ATI Radeon HD 3600
Windows Media Center
Ceton 4-tuner card
Shark 007 codecs
Videos are saved to a second (spinning) hard drive. But the problem occurs even when I run videos off the SSD boot drive.
The problem occurs whether I play through WMC or another video player (e.g., Hulu, Youtube). The HTPC is connected via an HDMI cord to a Sharp 60 in (LC-60e79u).
In my ATI settings, I can increase the audio lag, but not decrease it. About a month ago, I installed an SSD. On the prior set up (same hardware, just a regular HD), I was not having the issue. The SSD and a new install of Windows are the only things that have changed.
Any ideas are greatly appreciated.
nickman789 is offline
post #2 of 4 Old 01-15-2012, 07:55 PM - Thread Starter
nickman789's Avatar
Any help would be great. Thanks.
post #3 of 4 Old 02-04-2012, 03:53 PM
charlievoviii's Avatar
does your TV have AV sync ? if yes u can delay the audio
charlievoviii is offline
post #4 of 4 Old 02-04-2012, 03:56 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
The x64Components addon installs a 64bit Settings Application which controls playback in Media Center.
On the SWAP TAB of the 64bit app, try disabling the Microsoft Audio decoder.
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
Reply Home Theater Computers
