HBO Choppy (ceton infinitv) - AVS | Home Theater Discussions And Reviews
post #1 of 3 Old 01-16-2012, 07:23 AM - Thread Starter
natas777's Avatar
Hey Guys,
I have the ceton infinitv 4 and everything has been working fine with one exception.
Every once in a while HBO channels will run really choppy. This only happens with HBO. If i reboot the machine HBO runs fine.
Any ideas on what would cause this? My SNR is fine along with everything else
natas777 is offline
post #2 of 3 Old 01-16-2012, 10:57 AM
HDvids4all's Avatar
What GPU are you running? I had the same problem the first time I installed my InfiniTV4. On an AMD GPU, the solution was to uncheck de-noise (actually, uncheck all the settings in the same section) in CCC.
HDvids4all is offline
post #3 of 3 Old 01-16-2012, 11:18 AM
ProAm500's Avatar
i actually have the same problem... also on the discoveries with certain problems too...i guess its the 29/59 bug? I have the 6570
ProAm500 is offline
Reply Home Theater Computers
