Will Banned XBOX360 work as W7 Media Center Extender - AVS Forum | Home Theater Discussions And Reviews
Old 01-16-2012, 11:38 AM - Thread Starter
rockcola's Avatar
I keep seeing conflicting reports on this. I saw MS originally disabled extender abilities if the Xbox 360was banned. Is this true or not. I need a second XBOX 360 only to act as an extender to my W7 Media Center (Stream Live TV from my Tuners). I have one and it works great.
Any help before I buy a banned 360 on the cheap??
rockcola is offline
Old 01-16-2012, 11:42 AM
Zon2020's Avatar
Zon2020 is offline
Old 01-16-2012, 12:58 PM - Thread Starter
rockcola's Avatar
Thanks but this is an old story, and I know the April 2010 update re-enbles the Hard Drive. Is Media Center Extender functionality still blocked???
rockcola is offline
Old 01-16-2012, 04:11 PM
bryansj's Avatar
Quoted: 1136 Post(s)
Liked: 561
Yes, a banned console will work. Just use a removable USB drive with the latest update on it to upgrade to the newest dashboard.
If the console isn't a Slim you might want to reconsider since the Phats are too noisy IMO to be used as an extender.
bryansj is offline
Old 11-29-2012, 12:18 PM
JOHNBON00007's Avatar
Which remote control is good and I can used for the TV and the Media Center Xbox,,??
JOHNBON00007 is offline
Old 11-29-2012, 02:46 PM
JGFreeh's Avatar
Lots of options for remotes. There's an xbox-branded media remote, a windows-branded media center remote will work, as well as the logitech harmony remotes.
JGFreeh is offline
