XBMC+MythTV or WMC7 for Live TV recordings? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 34 Old 01-17-2012, 08:04 AM - Thread Starter
Norsican's Avatar
Scenario:
DVD/BRD rips will be stored on the HTPC
HTPC will also have pictures and Music as well as home movies on it as well.
HTPC will have a Tunercard.
HTPC will be Wired to a network
HTPC output will be through an AVR and ultimately a Tv via HDMI
Will be Running Win7
Kids need to be able to run this thing. We're talking grade school kids here.
My question is this:
Which would be the "better" solution? Knowing "better" is subjective, What I'm looking for is ease of use, "One stop shop" if you will.
I would like the family to be able to open one application and open any of the media.
What would be the easiest solution for them? Set up and Maintenance is not an issue. (of course, Less is preferrable, it's not a sticking point)
What I want to avoid:
Having them open WMC for recorded TV, and XBMC for everyhting else.
Opinions are welcomed here folks.
THERE IS NO NORSICAN, THERE IS ONLY ZUUL
Norsican is offline
post #2 of 34 Old 01-17-2012, 08:57 AM
tdavis's Avatar
I just got a pre-eden version of xbmc from OpenElec.tv running with MythBox and MythTV 0.24
I found you'll need a NVidia video GPU with mythtv at this time; most of the VA stuff isn't totally working at this time..
tdavis is offline
post #3 of 34 Old 01-17-2012, 09:04 AM - Thread Starter
Norsican's Avatar
What does a totally working VA translate into with regards to playback?
Norsican is offline
post #4 of 34 Old 01-17-2012, 09:04 AM - Thread Starter
Norsican's Avatar
Also, I'm open to solutions involving Media Browser as well.
Norsican is offline
post #5 of 34 Old 01-17-2012, 09:11 AM
Nick_W's Avatar
Hi,
Seriously, the only solution that fits what you need is WMC. I like XBMC, but it's not ready as a DVR yet.
HTH,
Nick.
Nick_W is offline
post #6 of 34 Old 01-17-2012, 09:15 AM - Thread Starter
Norsican's Avatar
Originally Posted by Nick_W View Post
Hi,
HTH,
Nick.
Kind what I was thinking but wanted to check the brain trust here on the forums before making a call on it either way.
Norsican is offline
post #7 of 34 Old 01-17-2012, 09:20 AM
tdavis's Avatar
The issue is MythTV stores the video in raw, mpeg2 encoded files. The last pre-eden beta, with PVR functionality, had playback issues. Under Openelec, the VA support is still a work in progress (as I understand it).
You could try MythTV eden + PVR from here: http://forum.xbmc.org/showthread.php?t=110694
This supports full live TV, and recording built into XBMC - but it's not in any XBMC distro by default.
I found this: http://forum.xbmc.org/showthread.php?t=43115 but to make it work with MythTV 0.24, you really need a pre-Eden version of XBMC; so, instead of fighting that, I'm trying a OpenElec.tv daily build of pre-Eden, MythBox, and 0.24, and it's pretty slick in my mind; it also makes the system boot blindingly fast straight into XBMC, and the WAF is very high.
tdavis is offline
post #8 of 34 Old 01-17-2012, 09:42 AM
genro's Avatar
Can't speak to XMBC,
But I've been running WMC (2 Prime tuners) + Mediabrowser and I am very happy on the whole. You need the technical skill to setup codecs if you want to play things like MKVs, but other than that it's relatively straight forward and simple to use. The latest Mediabrowser also improved stability/speed for me as well.
genro is offline
post #9 of 34 Old 01-17-2012, 09:46 AM
chaoconnor's Avatar
What are your capture cards? Reason I ask is, I'm using HDHomeRuns & an HDHomeRun Prime. Also, the OpenElec daily includes the PVR portion from the thread you linked to?
chaoconnor is offline
post #10 of 34 Old 01-17-2012, 11:06 AM - Thread Starter
Norsican's Avatar
Tell me more. =)
I can set up Codecs.
I plan to rip all blurays to MKVs ( still kinda new to it but I'm assuming this is the preferred method)
To no one in particular:
I would LOVE to be able to play Lossless audio instead of Mp3 audio. What Do I need to do to WMC to do this?
Norsican is offline
post #11 of 34 Old 01-17-2012, 11:10 AM
pkscout's Avatar
I used WMC until I moved to NY. One of the stations caused WMC to crash everytime I tried to record something on it. So I switched to XMBC + SageTV (which isn't available commercially anymore). Given what you've outlined, I'd go with WMC. I like what I've ended up with on XBMC, but it requires tender loving care and some periodic tweaks to keep it running correctly.
pkscout is offline
post #12 of 34 Old 01-17-2012, 11:19 AM
genro's Avatar
Tell me more. =)
Let's see it pretty much works fine
I went with Intel 2100T and use software playback (ffdshow) for h.264/MKVs (~20-30% cpu usage for 1080p material). Might try the new intel quicksync work from egur but haven't felt like it yet.
WMC works great for live/recorded TV, can use it for pictures and music as well. Although I prefer Mediabrowser's music plugin myself for that. I have 3 HTPCs (plus a desktop) with data served from an Unraid machine. All can now watch Live/RecordedTV as well as any movies/tv shows from the Unraid via Mediabrowser. Latest Mediabrowser (Apollo) seems to have sped up things and so far improved some stability issues I had (I have a relatively large collection (~800-1000 movies, dozens of TV series ~ 10TB total).
There are various "tricks/quirks" with WMC that I have learned about over the years (fixing overscanning requires a registry change and an odd setting in WMC see http://www.missingremote.com/guide/m...7-media-center, If necessary set windows to 2 channel sound and MCE to 5.1 if audio looping occurs, etc). You can play back audio files with FLAC in WMC but you need to install a plugin (various ways but I use http://bmproductions.fixnum.org/wmptagplus successfully).
Also for TV/Guide, I recommend installing My Channel Logos 2, Tuner salad (if more than 4 tuners needed), and Remote Potato (let's you view recorded shows/music from your phone/tablet/etc if your PC has enough power for the transcoding, but I mainly use it for being able to remotely record something when I forget).
If you care about playing back TrueHD or DTS-HD in MKVs then using the WMC player may not work (I haven't tried it in a long time and have had mixed results, probably depending on which version/configuration of the codecs I had at the time).
But overall its rather wife/family friendly. I have every HTPC with a harmony remote to make it basically one touch to turn on the TV etc. I have decided to just leave on all my HTPCs (they're pretty low power) instead of dealing with putting them to sleep/wake. Though I have had no major issues using S3 sleep in the past with WMC and recording TV. But it does get trickier if you are dealing with multiple HTPCs and one of them is the primary recorder. Speaking of that I do most of my recordings on one HTPC and nightly move the recordings a shared drive on my desktop that the other HTPCs can access. Various ways to do this but I have a nightly task created that runs a .bat file that using robocopy to do this.
But I digress ...let me know if you had any other particular questions.
genro is offline
post #13 of 34 Old 01-17-2012, 02:40 PM
utee05's Avatar
Quoted: 44 Post(s)
I have a similar setup as genro. I use WMC7 with HDHomerunPrime and use it along with my Logitech Harmony remote via usb IR receiver and it is wife friendly. My whole goal was to make it as similar to a cable box interaction as possible and what I have is much better. I use MediaBrowser to view all of my movies/tv shows on my Freenas server. I then use MPC-HC to play my ripped blu-rays. With MPC-HC I have it setup to handle all of the HD audio formats with madVR and lavcuvid.
I let WMC handle everything else.
Genro, thanks for the info on My Channels logo. I'll need to try this out.
BTW, how are you able to copy over content to a shared folder? I don't think I'm able to do this since I have TWC and they copy-protect everything you record.
utee05 is offline
post #14 of 34 Old 01-17-2012, 02:46 PM - Thread Starter
Norsican's Avatar
I have the Harmony remote etc.
Is there no single solution? Will I have to open up a separate instance of the MPC-HC to play x, Then WMC7 to play Y, then MB to play z?
Norsican is offline
post #15 of 34 Old 01-17-2012, 02:58 PM
genro's Avatar
Fortunately I have Fios
genro is offline
post #16 of 34 Old 01-17-2012, 03:00 PM
genro's Avatar
What do you mean exactly? To play what kind of files? I can play everything I want in WMC player (I don't do blurays), but it's not easy (if possible at all) to get HD audio through WMC player if that's what you mean. But it plays regular Dolby/DTS fine.
genro is offline
post #17 of 34 Old 01-17-2012, 03:08 PM
assassin's Avatar
Quoted: 170 Post(s)
Liked: 275
Sure it is.
assassin is offline
post #18 of 34 Old 01-17-2012, 03:11 PM - Thread Starter
Norsican's Avatar
Apologies, I should be more specific:
I would like as few apps as possible (or Apps that integrate into a front end such as MB, WMC, XBMC) that will play the following:
DVD rips/disc
BRD rips Discs
Currently, I run PCM through the AVR for discs via A bluray player so whatever is on the disc comes out of the speakers.
I'd like to be able to play from the HTPC eventually.
Lossless audio (I will be re ripping my audio to lossless for this)
home movies, The bulk of which are in Dolby Digital 2ch (AC-3 2ch) for audio
video is AVCHD
I'm not scurred of a little tweaking. I would just like it to work under as few roofs as possible.
Norsican is offline
post #19 of 34 Old 01-17-2012, 03:47 PM
bazfletch3's Avatar
Just to throw a little extra into the mix, have you looked at Mediaportal.
I dont pretend to be terribly knoweldegable compared to the gurus on here, but I have it working very happily (with just a couple of quirks - which is kinda a requirment for a HTPC anyway).
I use it as a single front-end for:
PVR functionality
DVD/Blu ray rips (with HD audio)
Music
Actualy playing CD's & DVD's
Actualy playing Blu Ray's - this is the only bit that is a slight work around; a mediaportal menu selection opens Arcsoft TMT5 in full screen to give you full Blu ray functionality, when you finish you just drop back to Mediportal
The wife loves it and finds it easy to use and shes certainly not very technical....
I really cant comment on WMC7/Mediabrowser and XBMC, only on my own Mediaportal experience. When i was originaly looking at which option to take (about 12 months ago) I ruled out XBMC because of the lack of built in PVR support and it just came down to WMC7/Mediabrowser v's Mediportal.
To me, Mediaportal looks prettier.... having said that, the support community for WMC7/Mediabrowser (led on here by assasin) seems pretty amazing; I struggle sometimes to get answers for my Mediaportal issues; particulaly on here but also in Mediaportal's own forums.
Anyway thats just my 2 cents worth....Mediaportal doesnt get enough love on AVS as I think it should!!
bazfletch3 is offline
post #20 of 34 Old 01-17-2012, 04:47 PM
tdavis's Avatar
I have two HDHomerun's setup for OTA. You don't need the PVR version to use MythBox; just a eden-beta of XBMC.
Mythbox let's you watch live tv, pause, rewind, etc.. The XBMC PVR doesn't let you do that - yet. It can almost everything else.
tdavis is offline
post #21 of 34 Old 01-17-2012, 06:25 PM - Thread Starter
Norsican's Avatar
PVR functionality
Music
Thanks for this. I'll check it out.
Norsican is offline
post #22 of 34 Old 01-18-2012, 03:36 AM
woodylobster's Avatar
I was in the same boat as you and ended up using wmc for live tv and xbmc for movies and tv shows and with the xbmc wmc plugin it makes it easy to switch between both.
woodylobster is offline
post #23 of 34 Old 01-18-2012, 07:28 AM - Thread Starter
Norsican's Avatar
While this is a solution, it's something I want to try to avoid if possible.
Norsican is offline
post #24 of 34 Old 01-18-2012, 07:49 AM
utee05's Avatar
Quoted: 44 Post(s)
In my scenario everything runs through WMC7. I use WMC7 to view livetv and recordings. Then I go to the MediaBrowser link in WMC7 to view my tv shows and blu-ray movie rips that I have on my freenas. I have setup Mediabrowser to launch for mpc-hc for any mkv file. This then opens up mpc-hc and when I hit stop or the movie ends it takes me directly back to mediabrowser. The one reason I use mpc-hc is so I can use lavcuvid and madvr for better quality video and HD audio format. Mediasmartserver.net has a tutorial on how to setup ffdshow and other codecs to use the built-in WMC7 player to handle HD formats.
This is a pretty straightforward solution and seems very wife friendly.
The one downside to using WMC7 is that the netflix application doesn't handle DD 5.1, only HD. I use my xbox whenever possible to play netflix as the recently allowed for HD and DD 5.1.
I think this should cover
utee05 is offline
post #25 of 34 Old 01-18-2012, 07:53 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
Tell me more. =)
Here is what is needed to play FLAC files - http://www.hack7mc.com/2009/01/playi...ia-center.html
"You’re KILLIN’ ME Smalls! "
Sony 55EX500 Settings
cburbs is offline
post #26 of 34 Old 01-18-2012, 07:55 AM
cburbs's Avatar
Quoted: 94 Post(s)
Liked: 29
This is true but try it before you cross it off the list. Right now I am in a testing phase and I have wmc running with mediabrowser and xbmc plugins. Similiar to what the utee05 said.
cburbs is offline
post #27 of 34 Old 01-18-2012, 08:03 AM
genro's Avatar
Originally Posted by assassin View Post
Sure it is.
I can't speak to it now, I know early on (sometime last year or so) I had intermittent success with it. I should clarify I mean w/o disabling Windows Media Foundation (which IIRC is needed if you have a cable card tuner) while using Gabest/Haali. Maybe I'm wrong as I haven't tried it in quite a while and maybe its easier with LAV, but I need to use Gabest/Haali for Media Control.
genro is offline
post #28 of 34 Old 01-18-2012, 08:46 AM - Thread Starter
Norsican's Avatar
Nothing is off the list, but the WMC7+MB+MPC-HC solution may be the first I try.
Norsican is offline
post #29 of 34 Old 01-18-2012, 12:42 PM
chaoconnor's Avatar
I put up the latest version of Mythbuntu on my ESXi box last night, configured my HDHomeRun Primes - Check
Downloaded the Eden beta, installed Mythbox - Check
Tuned into Live TV from Mythbox (XBMC) - CHECK!!!
So Eden fixed what was broken in pre-Eden. The latest MythTV (MythBuntu) is needed for HDHomeRun Prime, but that same version didn't work with the new XBMC protocol (as I remember reading it). Regardless, it all works now.
HOLY COW!!! WMC is officially GONE!!!
Mind I'm still happy using SageTV... but as those days are numbered, it's nice to know I have options!
post #30 of 34 Old 06-24-2012, 01:04 PM
Deihmos's Avatar
Quoted: 46 Post(s)
I just got a TV tuner and was struggling with this for the past few weeks. I wanted to use one program for everything so I installed Media Browser and host of other programs. In the end I felt XBMC works a hell of a lot better for videos than WMC. I will have to settle with WMC for TV and XBMC for videos.
I found an app by the name of XBMC integration which adds a launch icon in Windows Media Center for XBMC. It will close WMC to launch XBMC. When XBMC is closed it launches XBMC. If I could only find a way to map it to my harmony remote it would be perfect.
Deihmos is offline
Reply Home Theater Computers
