Help me choose a router please for my hpme theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 01-22-2012, 01:39 AM - Thread Starter
Holiday121's Avatar
Quoted: 543 Post(s)
Liked: 147
Here are so many routers to choose from
From what I read the linkage e4200 is good.
I had my new home all prewired with eithernet connections in every room.
Wireless is not a concern so do i still have to buy a high end routed to stream movies via Netflix or htpc? Bluray quality etc.
Or are most of those routers expensive because of the good wireless
Holiday121 is offline
post #2 of 16 Old 01-22-2012, 04:24 AM
erickotz's Avatar
Liked: 30
Something with a lot of RAM and a fast CPU that runs DD-WRT
Personally, I like the ActionTech FiOS routers for DD-WRT - good specs and cheap
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #3 of 16 Old 01-22-2012, 05:34 AM
C17chief's Avatar
Liked: 24
Does DD-WRT do anything about the small NAT table on those routers? I have FiOS and said router, but since moving to cablecard tuner/htpc/extenders that particular router isn't needed any longer as I dont need the MoCa for cable boxes anymore, and WAN is ethernet on my setup. I'm still running it right now, though not with DD-WRT. I did look at that once in the past, but seemed like it wasnt a good fit as some stuff didnt work with that router. I have had half the mind to replace it with an Asus N16 or something to not only take care of the small NAT table, but gain wireless N, gigabit lan, etc. I admit the N and gigabit isnt necessity for me, but I have had issues due to the small NAT table however. If that is a software function that DD-WRT would fix vs a hardware limitation, then I will give that a shot.
C17chief is offline
post #4 of 16 Old 01-22-2012, 06:34 AM
gregzoll's Avatar
Liked: 33
A box running either pfsense or smoothwall on it.
gregzoll is offline
post #5 of 16 Old 01-22-2012, 11:23 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
B4r u even looking for a router, better know what carrier u be using. They may give u a free gateway (modem+router combo) then all u would need is a switch.
MrBobb is offline
post #6 of 16 Old 01-22-2012, 12:57 PM
Somewhatlost's Avatar
Quoted: 20 Post(s)
Liked: 25
I prefer Bosch for routers... also have a Hatchi 1/2" that is pretty good too...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Somewhatlost is offline
post #7 of 16 Old 01-22-2012, 01:13 PM - Thread Starter
Holiday121's Avatar
Quoted: 543 Post(s)
Liked: 147
I will be using time Warner for provider .
I never heard of any of the routers you were talking about lol. I guess I might be in over my head. No linkage or netgear?
post #8 of 16 Old 01-22-2012, 03:02 PM
SUBCOB's Avatar
I believe that was a joke and he was talking about the tool.
SUBCOB is offline
post #9 of 16 Old 01-22-2012, 04:14 PM
Rthoreau's Avatar
I would have to agree with GregZoll, you also have to remember that IPV6 is here, and many carriers will be switching to it soon. The last thing you need is to buy an expensive router, and not have it IPV6 capable.
If you use pfsense, or smoothwall you problem is solved, you also get a nice firewall with pfsense. If you desire you can get some really good tech support as well, I know of no other software outside carrier grade stuff that will do it.
Rthoreau is offline
post #10 of 16 Old 01-23-2012, 12:43 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
and is linkSYS not linkage.
MrBobb is offline
post #11 of 16 Old 01-23-2012, 01:57 AM
Xylon's Avatar
You can not stream blu-ray files with the current technology.
You can stream most everything else as long as the bitrates are not very high.
Xylon is offline
post #12 of 16 Old 01-23-2012, 03:07 AM - Thread Starter
Holiday121's Avatar
Quoted: 543 Post(s)
Liked: 147
Thanks for the replys and sorry about the spelling
post #13 of 16 Old 01-23-2012, 10:00 AM
boomhower's Avatar
Quoted: 76 Post(s)
Liked: 47
His home is wired and you certainly can.
OP: I would suggest two pieces of hardware, a router and a switch. If your entire house is hardwired it's likely your going to have more connections that a consumer router is going to support.
If your not worried about wireless at all pretty much the only concern you have for your router spec is that it has gigabit lan. As long as the lan ports are listed as 10/100/1000 it will work. All it's going to do is connect your house to the internet. The switch will do all the real work. I like Netgear switches for the money and have green features as well. Click me. For a router I prefer Linksys but for your uses it's not really that important and DD-WRT is even less so, it really thrives in managing wireless.
boomhower is offline
post #14 of 16 Old 01-23-2012, 10:12 AM - Thread Starter
Holiday121's Avatar
Quoted: 543 Post(s)
Liked: 147
Wow finally good news . Yes the whole house is hard wired.
Time Warner is telling me there modem has up to 4 hard wired connections. If this is true then I won't need a router or switch. If it only supports 2 then i would have to buy a router and switch or just a switch?
post #15 of 16 Old 01-23-2012, 12:41 PM
Xylon's Avatar
I thought he was talking about wireless.
If your devices is wired Gigabit or standard you certainly can stream blu-ray files without stuttering. I have been doing this for years.
Xylon is offline
post #16 of 16 Old 01-23-2012, 12:42 PM
Xylon's Avatar
A switch will suffice. A 4 port type is about $25.
Xylon is offline
Reply Home Theater Computers
