Set color on htpc - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-22-2012, 04:57 PM - Thread Starter
jlenz's Avatar
I am running a jvc rs1 projector that is calibrated for directv and bluray. Whe I switch to my htpc the colors are not accurate.
What is the best way to set accurate color on the htpc when using a projector? I am running an amd 6980 with 11.2 drivers. Thanks. Jim
jlenz is offline
post #2 of 2 Old 01-22-2012, 11:31 PM
C17chief's Avatar
Liked: 24
you want to change your settings to match the following:
16-235 for color range/level/whatever you want to call it
6500k (or D65) color temp
2.2 gamma
709 color space
C17chief is offline
Reply Home Theater Computers
