Plex Discussion Thread - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 87Likes
post #1351 of 1955 Old 02-21-2016, 12:59 PM
Ken.F's Avatar
Quoted: 1542 Post(s)
Liked: 1336
Originally Posted by bryansj View Post
That's the Kodi audio settings.
It's kind of a pain to switch back and forth from Kodi to PlexBMC to make an audio change when you can just do it from inside PlexBMC.
Ken.F is offline
post #1352 of 1955 Old 02-21-2016, 01:11 PM
bryansj's Avatar
Quoted: 1196 Post(s)
Liked: 586
That doesn't make sense. PleXBMC is just a Kodi add-on. The PleXBMC add-on settings have a playback settings screen where you set transcoder properties. The audio passthru settings are Kodi with or without PleXBMC. There is no need to switch back and forth (I assume you mean Go Plex and Go Kodi menu options).
I'm using Amber skin so maybe your layout is different. However, if you disable PleXBMC the pass thru settings are still under System / Audio Output.
All that can be done in PleXBMC settings is for him to ensure the transcoding options are set correctly for his device.
bryansj is online now
post #1353 of 1955 Old 02-21-2016, 02:17 PM
Ken.F's Avatar
Liked: 1336
Yes, I meant it isn't necessary to Go Kodi to make audio changes then Go Plex again to test.
Ken.F is offline
post #1354 of 1955 Old 02-21-2016, 05:41 PM
michaelp2005's Avatar
Quoted: 22 Post(s)
I don't even have a DTS capable receiver but your question got me curious so I started digging around. It appears the RPi2 can only pass through the DTS 5.1 core contained in DTS-HD MA audio over HDMI. RasPlex version 1.0.2 added support to decode DTS-HD MA to 8 channel LPCM.
https://forums.plex.tv/discussion/16...passthrough/p1
https://forums.plex.tv/discussion/20...splex-1-0-2/p1
many thanks. that explains it, so at least I understand what is happening now. Haven't tried the LPCM route yet, as this is not something that's a major concern, but I was definitely curious
Update: Tried the 8 Ch PCM route, and it operated as advertised....
michaelp2005 is offline
post #1355 of 1955 Old 02-24-2016, 10:15 AM
K_Thompson's Avatar
Quoted: 98 Post(s)
Liked: 35
Originally Posted by K_Thompson View Post
How to adjust audio in Plex Home Theater question.
I'm trying to stream Blu-ray rips to a laptop and just using the internal speakers for playback, but I'm not getting any sound (video is fine). All my rips are done using MakeMKV and have both the HD audio track and the standard Dolby Digital or DTS track. Regardless of which track I select for playback I get no sound. I have the audio set to analog and WASAPI, but I'm unsure of what those arrows at the end of each field mean - one pointing up and to the right and the other pointing down and to the left. I've tried the DirectSound option, but that doesn't make any difference. The Audio Configuration Guide at the Plex support forums is not much help. Any suggestions would be appreciated. This is a local network attached laptop if that makes any difference.
Update: I installed Plex Home Theater on another computer as a test. Audio (and video) played just fine so I know the problem is not in the movie or my network. Audio settings are the same as the laptop except I had to use DirectSound as WASAPI did not work. There is no add on audio processing equipment on this PC - just the on board RealTek audio processor.
Bump. No one has any suggestions? Maybe my laptop just can't decode DD or DTS?
K_Thompson is offline
post #1356 of 1955 Old 02-24-2016, 03:24 PM
TornadoTJ's Avatar
Quoted: 1692 Post(s)
Liked: 534
The client is supposed to tell the server what it supports, then the server will decode if needed and send it to the client.
Do you have Plex configured to say your laptop supports DTS/DD? What about Windows?
TornadoTJ is offline
post #1357 of 1955 Old 02-25-2016, 01:55 PM
K_Thompson's Avatar
Quoted: 98 Post(s)
Liked: 35
Thanks for the suggestions. The DD and DTS settings are grayed out in PHT when audio is set to analog, which is the required setting when listening through the builtin speakers and not connected to an AVR. The sound settings in Windows 10 just show info about the built-in hardware and driver info - nothing about DD or DTS decoding.
post #1358 of 1955 Old 03-06-2016, 06:55 PM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
It hasn't been more than a few weeks that I've been singing the praises of Plex / PHT and its ability to pass through ATMOS and DTS:X and now all of a sudden i can't get it to work on the two different systems that it was working on. The trick in the past was to just make sure that Direct Play was checked off for local play. For some reason it wasn't for local but was for remote (go figure).
The other day we took a power hit that corrupted the BIOS on one of the systems which I believe I got resolved (the system was on a UPS) but can't get it to work on that system no matter what. Well ok I think maybe it is something to do with the system so I moved on to the other system which is an Intel NUC that also worked fine before, I go to play even a regular Blu Ray rip and it just stutters / no audio. I go in and verify the Audio Settings and they are fine. So now I am suspecting that it might be something to do with the Plex Server but don't have a clue what it could be.
This kind of stuff drives me insane / works today but not tomorrow and no matter what you do you can't get it to work again
Denon AVR-X7200 - Klipsch RF-82 II Fronts, RC-62 II Center, RS-52 II Surrounds & R-112SW & Four CDT-5800-C II Ceilings for an Atmos 5.1.4 Setup.
funhouse69 is offline
post #1359 of 1955 Old 03-07-2016, 08:52 AM
TornadoTJ's Avatar
Liked: 534
I wouldn't think it would be the Plex server software, but maybe something is wrong with the server itself or the network?
post #1360 of 1955 Old 03-08-2016, 06:45 PM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
Well I am even more confused - Maybe my Plex server was just having one of those days? I tried it several times and it didn't work. I the PHT Setting off of Direct Play to 10mb/sec and it was still doing it. I changed it back to direct play and its been working ever since
post #1361 of 1955 Old 03-19-2016, 01:29 AM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
It there any way to limit the amount of bandwidth a remote connection can take from the server itself? I thought I saw this somewhere but a family member installed PHT on one of their systems and it defaults to direct play which is taking a ton of bandwidth (30+Mb/sec).
I know I have to walk them through changing the settings but wonder if here is a way to do it on my end / prevent someone from taking that kind of bandwidth?
post #1362 of 1955 Old 03-19-2016, 06:12 AM
bryansj's Avatar
Liked: 586
Nope. That is a common complaint about Plex. Emby has this feature. Every remote Plex client has to be adjusted manually.
post #1363 of 1955 Old 03-19-2016, 07:43 AM
Aero 1's Avatar
Quoted: 336 Post(s)
Liked: 169
its coming, they made a mistake and made the option visible a few versions ago but it wasnt finished. its gone now but it has been acknowledged that its coming this year.
https://forums.plex.tv/discussion/19...-what-i-see/p1
Cord Cutter | OTA - NYC DMA - 6 TB TiVo Roamio - 3 TiVo Mini's | Plex Pass | Netflix | Hulu | Amazon Prime | MLB.tv & MLS Live with No Blackouts!
Aero 1 is offline
post #1364 of 1955 Old 03-19-2016, 08:06 AM
Ken.F's Avatar
Liked: 1336
FYI - I had to trim the /p1 off the end of your link to get it to work.
Ken.F is offline
post #1365 of 1955 Old 03-21-2016, 06:54 AM
MrZoid's Avatar
Quoted: 43 Post(s)
Liked: 46
Has anyone else had an issue of their database corrupting?
On my file server where Plex Server resides the database up and corrupted itself.
I ran a repair and it worked for a day, then corrupted again.
Last night I blew the profile away and rebuilt from scratch.
Mr Zoid
A GF that bought me a PS3 and a HD-A2? I'm a lucky man!
MrZoid is offline
post #1366 of 1955 Old 03-21-2016, 02:48 PM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
Mr Zoid
I haven't heard of this being common place, maybe there is an issue with the system / hard drive that it is stored on?
post #1367 of 1955 Old 03-22-2016, 05:37 PM
david8613's Avatar
Quoted: 215 Post(s)
Liked: 52
I'm new to plex and learning. I have it working when I try to stream to my phone. But I am having a problem and it happened twice now. Yesterday when I click on plex nothing happens, I tried rebooting samething so I deleted it, and reinstalled it, and it was working fine. Today same thing is happening, I click on it nothing happens. My computer is a Dell 7010 small form factor, i5 windows 10. Any help would be appreciated.
david8613 is offline
post #1368 of 1955 Old 03-22-2016, 06:09 PM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
Does it happen with the same movie / video? Does one play better than another? Start your Task Manager and see what the system resources are doing on the system running Plex.
You should see the resources go really high for a few seconds but calm down after that if they stay pinned at 80 - 90% the whole time you might be overloading the system.. This could also have to do with other applications running on the system.
Do you have another computer / something else you can run Plex on to see if you are having the same issue?
I am not sure which phone you have but my iPhone will play "Direct Play" most movies which puts very little load on the Plex Server System.
This could also be a wireless issue, Plex does Buffer you might poke around the settings and see if you can increase the play buffer to see if that helps.
post #1369 of 1955 Old 03-22-2016, 07:19 PM
garnuts's Avatar
Quoted: 83 Post(s)
Liked: 60
Don't know what your problem may be, but you could check the Plex Forums where there is a lot to read and probably more specific help for your issue:
https://forums.plex.tv/categories
garnuts is offline
post #1370 of 1955 Old 03-24-2016, 04:09 AM
Liked: 0
Another Plex question, I just purchased Roku 4 and getting away from the HTPC. would it be better to have the Plex on a dedicated machine, (i7 3770, 16gb ram) or can I get away with combining it with my workstation, the same CPU but with 32gb ram. I use my workstation to convert my movies to the MP4 format then moving to my plex server.
hope this is the right place to ask.
lone_wolf is offline
post #1371 of 1955 Old 03-24-2016, 04:26 AM
funhouse69's Avatar
Quoted: 483 Post(s)
Liked: 153
The answer is it depends - How much will you be using the Workstation System? How CPU Intensive will what you are doing with it be? How many Streams / Clients will you be serving with Plex? All of these are factors.
This will also depend on the content, you said that you convert movies to MP4 but are compressing them?
If you are using it to compress the movies (which can be very CPU Intensive) and using it as a Plex server at the same time you might run in to some issues if Plex has to Transcode the media, if it doesn't you probably won't have any issues at all.
Also keep in mind that Plex is NOT in any way Memory Intensive, you don't need much memory at all. I have plex running on a Windows 7 Virtual Machine and it is taking less than 2GB of memory. Plex is / can be very CPU Intensive so more memory is just a waste of money.
post #1372 of 1955 Old 03-24-2016, 06:36 AM
Liked: 0
I am using makemkv to pull them from the blu ray, then handbrake to encode to mp4. once that is done I then use media center master for the metadata. after all of that I move them to the plex server. so at times the workstation is pretty busy.
also thinking of moving all of my personal files to this plex server as well, and just using it as a home server. I'm just trying to cut expenses where ever I can.
the current plex is my htpc/plex server, but as mentioned I just got a roku 4 last night and going to move my plex box into another location. my daughters thought it would be good to surf facebook, install games on the plex server and I am scared of any malicious activities happening on that.
post #1373 of 1955 Old 03-24-2016, 06:37 AM
Liked: 0
I also just picked up a 5tb external to backup my movies, then I have another 3tb external handling my TV shows.
post #1374 of 1955 Old 03-24-2016, 07:03 AM
Ken.F's Avatar
Liked: 1336
I'm curious why you use Media Center Master. The Plex server can download all of the art and program information without the help of any external programs. I'm not saying you shouldn't use it if you want to, I just haven't found it to be useful with Plex.
Ken.F is offline
post #1375 of 1955 Old 03-24-2016, 09:07 AM
Liked: 0
Honestly I started using it when I was using my htpc with media browser as my htpc would not find any data, I guess I have just been doing the routine. I will definitely stop using it now that I know I don't need it. that will save a little bit of time!
maybe that is why I am having issues with Plex not naming some of my TV shows...it does pull in the synopsis but it leaves the name of the shows "Season 01 Episode 01"
post #1376 of 1955 Old 03-24-2016, 09:10 AM
TornadoTJ's Avatar
Liked: 534
They must exactly match what is in here:
http://thetvdb.com/
post #1377 of 1955 Old 03-24-2016, 11:20 AM
Ken.F's Avatar
Liked: 1336
http://thetvdb.com/
If it gets the correct synopsis then it's getting matched correctly.
Ken.F is offline
post #1378 of 1955 Old 03-24-2016, 11:22 AM
Ken.F's Avatar
Liked: 1336
That's one of the reasons I switched to Plex from Media Browser. I still have Media Center Master but I haven't run it in a very long time. I wonder if it still works.
Ken.F is offline
post #1379 of 1955 Old 03-24-2016, 12:45 PM
bryansj's Avatar
Liked: 586
I had MetaBrowser. I hadn't ran that since Plex and Emby. Is there even much of a reason for it since both Emby and Plex scrape their own data?
post #1380 of 1955 Old 03-24-2016, 01:21 PM
david8613's Avatar
Quoted: 215 Post(s)
Liked: 52
I'm getting a little fustrated, is there anyone here in the north new jersey area that can help me set up this htpc correctly, I would compensate of course?
Reply Home Theater Computers
