Network problems? - AVS Forum | Home Theater Discussions And Reviews
Old 01-23-2012, 05:55 AM - Thread Starter
kxed's Avatar
Quoted: 27 Post(s)
Im not sure if I have a network problem or something else? My htpc has been working great for over a year. I only use it for sd dvd rips over my network with xbmc. One day it just started to freeze on playback I switched out my Verizon fios router for my older Netgear router. It plays better but I still get some stuttering and some lines across the screen and the lower 1/8 of the screen seems blurry.
kxed is offline
Old 01-23-2012, 05:22 PM - Thread Starter
kxed's Avatar
Quoted: 27 Post(s)
Does anyone have any ideas?
kxed is offline
Old 01-23-2012, 05:34 PM
Brad Horstkotte's Avatar
Liked: 68
Sounds more like a video card / configuration problem to me - "tearing"? Did you make any video card driver or XBMC configuration settings recently?
Brad Horstkotte is offline
Old 01-23-2012, 06:24 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Network problem? unlikely. But of course you switched out the cable(s) right? There is not much in between the two boxes.
MrBobb is offline
Old 01-24-2012, 04:55 AM - Thread Starter
kxed's Avatar
Quoted: 27 Post(s)
I'm using an ATI card and there was an update but I think it worked ok after the update. if it was the update then why would it run smoother after the router change?
kxed is offline
Old 01-26-2012, 05:40 AM - Thread Starter
kxed's Avatar
Quoted: 27 Post(s)
I backed up the driver and I still Have the problem is there something I'm over looking?
kxed is offline
Old 01-26-2012, 05:52 AM
gregzoll's Avatar
Liked: 33
What happens if you go back to the Fios router? Why did you switch in the first place? A lot of unanswered questions here.
gregzoll is offline
Old 01-27-2012, 04:53 AM - Thread Starter
kxed's Avatar
Quoted: 27 Post(s)
the reason I swapped out the fios router is the movie would just freeze after i replaced it the movie would play but I'm getting those lines and blurry look at the bottom of the screen
kxed is offline
