Can i build a 200 dollar htpc and do the following? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 71 Old 01-24-2012, 01:37 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I am primarly a dune user and use it for streaming hd media and blu-ray stored on my hard drive.
However i would like to add xmbc and build a htpc to stream web content (youtube, icefilms, veehd, ect..) I just want something that can stream 1080p or 720p content, i hope it can be done at this price point.
And secondly to bitstream flac and display folder.jpg art
Thats about all im asking.
I dont want to spend much because my goal is to build a larger server soon.
I was looking at just getting a zotac nd22, but i cant find them anywhere anymore.
Is there anyone who can tell me if this can be done at this price point, and possibly recommend me some products to look at, im very new to this.
Murilo is offline
post #2 of 71 Old 01-24-2012, 02:49 AM
CountryBumkin's Avatar
Quoted: 218 Post(s)
Liked: 55
Not for $200 unless you already have some hardware you can reuse. Do you have an Operating System? Are you reusing any of your HDs?
CountryBumkin is offline
post #3 of 71 Old 01-24-2012, 02:49 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I should also mention i dont need any storage if i can possibly just a ssd card, or usb drive to boot xbmc live or openlec.
Murilo is offline
post #4 of 71 Old 01-24-2012, 02:57 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I was hoping since it was just to be used with xmbc i did not need one other then xmbc live or openelec.
I also dont know if i need any hard drives at least that i can think of, i have a 12 terabyte windows server im using, and dont plan on storing anything really other then xmbc plugins on the machine itself. Its used simply for web streaming, and music, and my music is stored on my pc as well.
I dont know how shares could be set up between xmbc live/openelec and my windows 7 pc/server.
Murilo is offline
post #5 of 71 Old 01-24-2012, 03:02 AM
NewOrlnsDukie's Avatar
Liked: 29
$200?
Lolololol
NewOrlnsDukie is offline
post #6 of 71 Old 01-24-2012, 03:17 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
Is that hard to imagine?
Just to stream web content? No dolby true hd, no dts master. Dune handles that.
I also have a server already, i am not storing anything on it.
All i want is stream web content and play music.
by the way that zotac i mentioned retailed for a little over 200 and users on xbmc forum use it.
You also may want to look here before you laugh anymore.
http://forum.xbmc.org/showthread.php...972#post841972
Murilo is offline
post #7 of 71 Old 01-24-2012, 03:25 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I was actually looking at just getting apple tv 2 to do this, but another user said i need to build an htpc.
Murilo is offline
post #8 of 71 Old 01-24-2012, 04:49 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I believe XBMC runs on the Apple TV, so that may be an option for you.
I would double check however if it also works on the ATV2. I know it works on the first version, dont know about the second.
There may also be other pre-built mini-HTPCs that can do what you want.
Building a full custom HTPC will probably at least get you to 350-400, even if you pick all the low-end parts.
I already paid over 200 just for PSU and the case i'm building with, but i'm never happy with "just good enough", so that may be different.
Nevcairiel is offline
post #9 of 71 Old 01-24-2012, 04:58 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
Thanks for the reply.
From what i read atv2 does work with xbmc, but some stuttering issues exist.
Just to summarize what I want this for.
1.480,720p, 1080p webcontent, from youtube, hulu ect... so no dts ma, no true hd, my dune is for that. That is about the only requirement.
2.Stream 2ch flac and show album art.
Thats it.
I have a server already, dont need storage, i have a blu-ray burner elsewhere, i have a dune prime for blu-ray and hd content stored on my server. Incase people are not familiar it plays blu-ray discs or streamed with menus and hd audio at 1080p.
I basically just need a bare bones htpc that can handle streaming web content and music.
Murilo is offline
post #10 of 71 Old 01-24-2012, 05:28 AM
C17chief's Avatar
Quoted: 12 Post(s)
Liked: 24
If you have a hard drive laying around to use with it, and already have your own copy of windows or use free software like linux, then yeah, you could put together an ITX G620 machine for right at $200, nevermind stuff like atom or fusion. If you need to buy hard drive as well, then you arent putting together anything for $200 as a hard drive alone, even a small one, will take nearly half that budget or more.
C17chief is offline
post #11 of 71 Old 01-24-2012, 05:35 AM
psubsee2002's Avatar
I was in a similar boat a short time ago. I did a larger scale HTPC build for my main TV and I was looking around to see if I could build a small system for another room that could stream content from the main system, but I was having trouble getting in under $300, so $200 might be pushing it. I ended up bagging it and am patiently waiting to see the pricing for the Ceton Echo and/or a good deal on an XBox 360.
You have to figure just the mobo, processor, and RAM is going to run you at least $100 (probably more if you want decent integrated graphics and/or an discrete GPU), an SSD drive is $50 to $100, and a case and PSU could be $50-$100 unless you are flexible on the form factor and size. Since you are thinking of XBMC Live, you might be able to skip the SSD and boot from a flash drive to save some $$$, but you are still cutting it close at that price point.
psubsee2002 is offline
post #12 of 71 Old 01-24-2012, 05:38 AM
captain_video's Avatar
Quoted: 524 Post(s)
Liked: 341
I built a system using an ASRock E350M1/USB3 mini-ITX motherboard, 4GB G.SKILL RAM, and an Apex MI-008 case for about $192 a few months ago. I already had a spare hard drive and an extra Win 7 license. The Apex case holds a standard optical drive so I added a DVD-R drive for about another $20. Note that some of these items were on sale from Newegg at the time so current prices may differ.
captain_video is offline
post #13 of 71 Old 01-24-2012, 06:58 AM
GreenEyez's Avatar
You could use OpenELEC (much better than Live, IMHO) and boot/run from an USB Flash drive, so that saves you the money on the HDD. For the rest of the hardware, the cheapest Atom/ION combo should work, since DTS-HD or TrueHD isn`t a requirement.
GreenEyez is offline
post #14 of 71 Old 01-24-2012, 07:29 AM
zrdb's Avatar
I built my htpc for less than $200-but then I already had a Quad 2 Duo E6750 cpu and a 2 gig WD green hdd-the case, mother board, 4 gigs of DDR3 ram, video card and power supply set me back less than $180 and I was able to barter an old pata dvd burner I had for 2 sata dvd ram drives of which I used one in the htpc-I'm very happy with my htpc so far-and I used a copy of XP corporate for the os.
zrdb is offline
post #15 of 71 Old 01-24-2012, 07:48 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
I was looking at this but someone said it does not play nice with linux which is a huge disappointment because i wanted to use openelec, maybe someone can clarify.
I should also clarify again the only hard drive i need is a boot drive, and room for plugins, i assume if im running openelec an 8gb ssd card would suffice or a simple fast usb drive?
I have a 12 tb case currently for my storage. I plan to add a larger norco unraid case later this year.
I would stick with apple tv because its cheap and simple if i could find out if streaming 720p over youtube, or hulu works, i keep hearing conflicting reports, some saying its stutters. If it does not it is perfect, if it stutters its a paper weight then.
Thanks for all the input!
Murilo is offline
post #16 of 71 Old 01-24-2012, 07:52 AM
GreenEyez's Avatar
OpenELEC has support for the AMD Zacate platform, and they are improving it with the release of XBMC 11 Eden by adding XVBA (which is the Ati API for hardware acceleration) support instead of VAAPI (which is a generic API created by Linux developers for all hardware). I have an AMD E350 and the latest OpenELEC build (1.02) worked ok for the 15 minutes i tested it.
2GB is enough for OpenELEC unless your library is 500+ Movies (but since you need it for youtube and hulu, this isn`t an issue), 8GB is plenty.
post #17 of 71 Old 01-24-2012, 08:02 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
No idea how well XBMC works with the E-350 but I did see this in my email today for $110 w/ free shipping. You'd need memory and storage.
http://www.newegg.com/Product/Produc...82E16856119058
StardogChampion is offline
post #18 of 71 Old 01-24-2012, 08:15 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
This is the direction i will go unless i can find out if apple tv can reliably stream web content from hulu, youtube, ect... at 720p i keep hearing conflicting stories and am still not sure.
Murilo is offline
post #19 of 71 Old 01-24-2012, 08:17 AM - Thread Starter
Murilo's Avatar
Quoted: 137 Post(s)
Liked: 33
wow that looks good as well.
Murilo is offline
post #20 of 71 Old 01-24-2012, 09:21 AM
scl23enn4m3's Avatar
I would go with this, 4gb of ram and XBMC Live:
http://www.newegg.com/Product/Produc...82E16859324008
In my previous setup I had an original ION with a dual core atom (2gb ram) running mkv blu ray rips no problem.
scl23enn4m3 is offline
post #21 of 71 Old 01-24-2012, 09:30 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I have seen Boxee boxes advertized for about $100 before the holidays. That will be your way of getting the hardware on the cheap.
If not, then find the original Ion board with Atom 330 on the secondary market. They were $100 when they were new. Should be $50 now. Add a cheap $30 miniITX case with PSU, and a small SSD for $50 to run OS, or just a SD or Cf card with OS loaded via card reader.
Another option is to scour slickdeals.net I just built a $100 PC from SD to replace the aging Pentium D 805 that I have been using since 2006.
$20 mobo, $20 for 8 Gb of DDR3 RAM, $50 Phenom II X4 processor, $10 for Win7 from the University computer store, re-used everything else. All parts were bought separately over time as the deals came up.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #22 of 71 Old 01-24-2012, 10:32 AM
idividebyzero's Avatar
Quoted: 42 Post(s)
If theres an official Hulu app on the Apple TV then most good hulu+ shows arent supported on TV devices and only work in free quality.
idividebyzero is offline
post #23 of 71 Old 01-24-2012, 10:36 AM
erickotz's Avatar
Liked: 30
My concern is that the OP listed a bunch of web streaming things, along with an etc - hardware acceleration can be iffy on web-based things, so a slow CPU like an Atom may be too slow for his desires (even aside from the fact that a HD + OS pretty much burns through his budget...)
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #24 of 71 Old 01-24-2012, 11:04 AM
Quoted: 93 Post(s)
Liked: 160
Good point. I am not sure if this is still an issue with the E-350 but it was so some research is warranted.
post #25 of 71 Old 01-24-2012, 12:01 PM
squeakybirnbaum's Avatar
Quoted: 26 Post(s)
Liked: 26
Originally Posted by NewOrlnsDukie View Post
$200?
Lolololol
Dude it's not that crazy. I just built another HTPC for around that.
I bought:
- Motherboard - ASRock H61-GE $58 from superbiiz
- CPU - Celeron 430 - $43 from superbiiz
- PSU - Corsair cx430 - $25 from newegg after rebate
- Ram - already had an extra stick but 4GB is like $20 I think
- HD - 120 GB gamestop xbox 360 drive - $29 - (took it out and reformatted it)
- OS - had that already but if you are actually buying windows 7 yeah then it's impossible
- Case - already had one but that's $175 so far so $25 for a cheap-ass case.
All those deals might not still be around now but it you don't need it immediately you can always get deals on stuff.
squeakybirnbaum is offline
post #26 of 71 Old 01-24-2012, 12:02 PM
GreenEyez's Avatar
XBMC uses DXVA for any of the 2 streaming plugins the OP mentioned, both Youtube and Hulu/Hulu+ , so the E350 is fine.
post #27 of 71 Old 01-24-2012, 03:32 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Not bad! $19 for 4GB of DDR3@1333Hz (AMD) Free Ship and you would have yourself a nice HTPC. You could even throw a couple of USB HDTV dongles on it - http://www.meritline.com/mygica-hybr...--p-35677.aspx
And get some local HD broadcast, uncompressed like with Cable/Sat. I've found a streaming plug-in for MythTV but as far as I know development has stopped - http://home.kabelfoon.nl/~moongies/streamtuned.html
Thanks Star, I sort of wanted a cheap box I can experiment with...
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #28 of 71 Old 01-24-2012, 03:37 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Hey do you think I could dual boot MythTV/XBMC and Puppy Arcade (Puppy Linux stripped down for emulation of consoles and DOS games)?
I have Vista 32-bit still and 4GB would be plenty for that... Hmmmm
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #29 of 71 Old 01-24-2012, 05:41 PM
melodic's Avatar
i just built an htpc for around that price range. here is what i built.
cpu - intel g620 - $55
motherboard - ASUS P8H61-M - $80
case/psu: compucase htpc case w/ 300 w psu $65 http://www.newegg.com/Product/Produc...82E16811121100
ram: kingston hyperx blu 2x2gb - $25
total : $225
i already a western digital green and OS.
melodic is offline
post #30 of 71 Old 01-25-2012, 07:13 AM
whiteboy714's Avatar
I agree 1080p flash will probably struggle with a weak cpu.
total : $225
Thats very nice. Much better then some lame atom or E350.
You could easily knock 30 bucks off the price with the mobo. Something like this.
http://www.newegg.com/Product/Produc...82E16813157241
You must have got the cpu on sale thats what the celeron goes for right now. Which I think is still fine.
whiteboy714 is offline
Reply Home Theater Computers
