With the new 48 and 60 fps movies. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 52 Old 01-24-2012, 10:34 PM - Thread Starter
H8nXTC's Avatar
So the Hobbit is being filmed in 48 fps, I'm wondering what things I'll need to upgrade to run them at full resolution when they come out on Blu-Ray? Low end video card (at 48 or 60 fps at 1080p)? TV? Projector? How about if they're filmed in 3D?
http://news.yahoo.com/jacksons-hobbi...162203308.html
H8nXTC is offline
post #2 of 52 Old 01-24-2012, 10:44 PM
audio/videoman's Avatar
I believe the sequel to avatar is being filmed at 48 fps as well.
This means that pulldown judder will be an issue for both 60 and 120 hz tv sets. An upgrade to 240 hz tv's will be necessary to avoid pulldown judder.
Resolution will be unchanged: it will still be at 1080p for blu ray.
audio/videoman is offline
post #3 of 52 Old 01-25-2012, 03:57 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Blu-ray does not support 48p, you'll most likely still get 24p on the Blu-ray discs.
Blu-ray also doesn't support 60p, the best they could do is 60i.
Nevcairiel is offline
post #4 of 52 Old 01-25-2012, 06:01 AM
jeffkro's Avatar
Yup BR is going to be the limiting factor for new formats like 4K. Unfortunately we are going to need another new media format.
By the way the new OLED TVs from LG don't have the motion blur problems of LCD panels. So 24fps should look better.
PS the thing I don't get is 30fps is known to be the minimum for smooth fast action so why did they make the standard 24fps?
jeffkro is offline
post #5 of 52 Old 01-25-2012, 06:27 AM
Theresa's Avatar
Liked: 51
24fps is a hold over from film. It is archaic. I've always been bothered by flicker when watching movies in the theater. Hopefully they will go to p60 eventually.
Theresa is offline
post #6 of 52 Old 01-25-2012, 06:35 AM
tman247's Avatar
Quoted: 56 Post(s)
Liked: 50
I believe a 4K version of BR is in development. It will use multi-layer discs, but you will need a new player to output at that resolution. Not sure if a standard player will downscale to 1080P or not though.
tman247 is offline
post #7 of 52 Old 01-25-2012, 07:00 AM
icstm's Avatar
Out of interest - Is 48p 48 or 47.952?
Also:
"By the way the new OLED TVs from LG don't have the motion blur problems of LCD panels. So 24fps should look better. " But there is inherent motion issues in 24p content as 24frames is too slow for motion (either action or panning). Purists used to call that the beauty of film...
icstm is offline
post #8 of 52 Old 01-25-2012, 07:04 AM
Theresa's Avatar
Liked: 51
60p playback is more important to me than 4k which would provide no benefit for me since I have "only" a 50" plasma.
Theresa is offline
post #9 of 52 Old 01-25-2012, 07:22 AM
jeffkro's Avatar
I'm with you, I won't be getting rid of a perfectly good 1080p TV to buy 4k, 60fps, or 3D. That being said when you are in the market for a new TV it makes sense to get the one with all the new features.
PS - pretty sure plasma doesn't have the motion blur issue of LCD either. Plasma has the better picture but LCD has other advantages.
jeffkro is offline
post #10 of 52 Old 01-25-2012, 07:52 AM
knutinh's Avatar
I am willing to bet that once "48p" is touted as the new video format, our existing tvs, receivers and disc players will have to be upgraded to support it fully, even though they are capable of 1080p60 today.
It ought to be possible to "bake" 48i into existing 24p formats. Might not be ideal, but given good de-interlacing, it might be a better compromise between spatial and temporal resolution once 48p Hollywood sources are available.
Seems to me that the industry bakes in minimal future proofing in their products, hoping that people will purchase minor respins of the same functionality again and again...
-k
knutinh is offline
post #11 of 52 Old 01-25-2012, 08:10 AM
whiteboy714's Avatar
Is there even such a thjing as a true 240hz tv? Very few are even 120.
whiteboy714 is offline
post #12 of 52 Old 01-25-2012, 08:14 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
No (even remotely affordable) panel today can really refresh at 240Hz, getting them to 120Hz was already a challenge, which is why true 120Hz TVs are so rare as well. Don't believe in the "120Hz", or "240Hz", or even "600Hz" marketing terms they use to advertise their interpolation features
Its more likely that they'll add either a 48Hz mode or 96Hz mode to the TVs.
post #13 of 52 Old 01-25-2012, 10:03 AM
walford's Avatar
What you say is true for Plasma panels but it is not true for LCD panels.
walford is offline
post #14 of 52 Old 01-25-2012, 11:01 AM
khollister's Avatar
Quoted: 22 Post(s)
I believe the Sony HX929, for instance, has a native refresh rate of 240 Hz. The Sony spec sheet lists the panel frequency as 240 Hz.
Emotiva XMC-1 & XPA-5, B&W CM9s2, CM8s2, CMC, Hsu VTF-15, Sony BDP-S790 & HX929, Auralic Aries, Apple TV
khollister is offline
post #15 of 52 Old 01-25-2012, 12:05 PM
knutinh's Avatar
As long as it does not support 48fps over HDMI, there is no trivial way to exploit that 240Hz for 48fps content.
-k
knutinh is offline
post #16 of 52 Old 01-25-2012, 03:23 PM
ericbsmith's Avatar
Quoted: 13 Post(s)
Yup. Goes back to the day when film footage was expensive, and 24fps was the minimum you could get away with and still have reasonable looking motion. By reducing the frames by ~6fps they were saving lord knows how many feet of film that would have to be cut and shipped to every theater in the country.
Eric B. Smith
The future keeps telling us what the past was about. You make the past mean different things by what you do with the time that comes after.
ericbsmith is offline
post #17 of 52 Old 01-25-2012, 03:34 PM
ericbsmith's Avatar
Quoted: 13 Post(s)
You have to keep in mind that the industry has to serve many masters. Europe is still using 25/50Hz TVs, while America uses 30/60Hz. No matter what frame rate they choose to shoot movies in somebody is going to have troubles. I'm guessing that 48fps was chosen because it can be downsampled to 24Hz interlaced on existing Blu-Ray/DVD players and time converted to 50Hz without too much trouble (this is what they do with movies anyway - they speed up 24Hz movies to 25Hz so they are compatible with the TVs; speeding up 48Hz to 50Hz is by the same aspect no big deal).
Eric B. Smith
post #18 of 52 Old 01-25-2012, 03:39 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by ericbsmith View Post
24Hz interlaced
What's that? Looks even worse than 24Hz progressive (24 fps).
renethx is offline
post #19 of 52 Old 01-25-2012, 04:21 PM
salacious's Avatar
I could be wrong but I believe that in the cinema, film was 24 and slowed to 23.976 on BR. So it should be 48 and 60Hz. I'm not sure on the switch to digital if things changed
__________________________
Blu-Rays 100
HD DVDs 65
DVDs 300+
salacious is offline
post #20 of 52 Old 01-25-2012, 09:50 PM - Thread Starter
H8nXTC's Avatar
I think the article states 60fps.
I've noticed some HDMI cables/products are listed with 4K already.
H8nXTC is offline
post #21 of 52 Old 01-25-2012, 11:21 PM
NTNgod's Avatar
The standardization of frame rate at 24fps - roughly around the dawn of the sound film - was arrived at in large part because it was determined that was the average speed theaters were actually showing the movies at - for scheduling, not technical, reasons.
Prior to standardization, the typical framerate most films were actually shot at - and intended to be shown at - varied around the 16-22fps range.
NTNgod is offline
post #22 of 52 Old 01-26-2012, 12:11 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
He probably means 48i, which is encoded as 24 full images (48 fields). It can be argued if full temporal resolution is better then full spatial resolution... I would probably prefer the real 24p over some 48i bastardization.
However, this is not allowed in the Blu-ray standard anyway.
What they could do is speed it up slightly to get 50i, which is a supported format (Think PAL speed up), however i doubt they would because alot of US TV sets probably lack good 50Hz support.
Wonder if they'll come up with some form of Blu-ray Plus or something that just adds support for 4K and higher progressive frame rates.
If you take 3D into account as well, we'll also need a new HDMI, which is being worked on, but who knows when there will be widespread implementation.
post #23 of 52 Old 01-26-2012, 04:37 AM
undermined's Avatar
48fps has been proposed since cameras and projectors used for cinema can already handle it and the added fps will reduce judder as compared to just 24fps.
60fps is being pushed by James Cameron for its greater ability to handle motion and again, cameras can do it already and video already being 60fps so rolling it out will sorta fit into workflows.
and HDMI 1.4a can do 4K, but is limited to 3840x2160@24fps
I personally want displays that can take 4K input signals @60hz or at least 1080p@120 and not just the same 60hz we have now.
It is stupid to think a given panel is native 120hz or even 240hz and the highest i can feed it from a PC is 60Hz.
Display port 1.2 can handle the increase already and technically could allow direct addressing of the pixels from the GPU but most displays only have HDMI without even a option to do 120hz from a PC.
Gaming GPUs can already handle 4K and and if the industry want early adopters to but 4k displays it is kinda stupid to think they should only give us displays that will just upscale everything and we'll be happy with that versus allowing native format from a PC since no other source is out there .
undermined is offline
post #24 of 52 Old 01-26-2012, 04:47 AM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
-k
Though it could be possible to fudge a "48p via 60p" HDMI system (by repeating frames to pad out the signal by 12 frames a second and then discarding them again)
sneals2000 is offline
post #25 of 52 Old 01-26-2012, 04:48 AM
sneals2000's Avatar
Quoted: 241 Post(s)
Liked: 127
Presumably 8k @ 120Hz (aka Super Hi Vision) is pushing both resolution and frame rate requirements for future formats?
Be interesting to see what the Olympics stuff in SHV looks like later this year.
post #26 of 52 Old 01-26-2012, 06:14 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Doubtful this would ever make any kind of standard, its just too hackish.
Its not too far fetched to just get 48p out of a HDMI signal, they support 1080p60 already, 48 is even lower, so the bandwidth is there - just needs a TV to accept such a refresh rate.
post #27 of 52 Old 01-27-2012, 10:08 AM
icstm's Avatar
where will you be getting that? I beleive the BBC will be using that for their outdoor broadcasts, but did not realise that it was being beemed into people's homes.
icstm is offline
post #28 of 52 Old 01-27-2012, 07:42 PM
ymarker's Avatar
Quoted: 27 Post(s)
8k ~ Imax
ymarker is offline
post #29 of 52 Old 01-27-2012, 10:12 PM
jeffkro's Avatar
Originally Posted by ymarker View Post
8k ~ Imax
Is Imax digital now or are they still shooting on film?
jeffkro is offline
post #30 of 52 Old 01-27-2012, 10:27 PM
pokekevin's Avatar
Liked: 102
I thought it was still film than scanned
pokekevin is offline
Reply Home Theater Computers
