Weird case content - what is this? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-26-2012, 12:50 PM - Thread Starter
ITemplate's Avatar
Hi,
Just got my SST GD04. Inside the case I find this:
What is that? It is made of rubber and the side facing up contains some sticky stuff. Might look like it could contain a harddrive in size. But nothing in the manual so it seems..?
Werner
ITemplate is offline
post #2 of 5 Old 01-26-2012, 01:28 PM
mrjinglesusa's Avatar
That piece connects to a HD at the end with the connections. It is for the HD that is located over the power supply on the HD bracket.
Take a look at pages 3, 14, and especially page 15 of the manual. You can see it attached to the HD bracket.
http://www.silverstonetek.com/downlo...D04-Manual.pdf
mrjinglesusa is offline
post #3 of 5 Old 01-26-2012, 01:28 PM - Thread Starter
ITemplate's Avatar
Alright, it must be the rubber which should help with airflow. It should have been attached to the drive bays:
http://ksstudios.com/silverstonegd04-html
See picture about 2/2 down. I guess the best would be to glue it back on the bay?!
Werner
post #4 of 5 Old 01-26-2012, 01:31 PM - Thread Starter
ITemplate's Avatar
Yes, now I'm sure too, thanks. I can see it in the PDF you linked to. But I can't see it clear in the manual . But according to the manual it is only there for airflow. It is not touching the harddrive as such...strange construct?
Werner
post #5 of 5 Old 01-26-2012, 04:03 PM
Werner
When I installed my HD in my case, the end of the HD (with the ports) pretty much fit in that rubber thing. Not sure why yours doesn't. I have a GD05B case.
Reply Home Theater Computers
