HTPC starting point? - AVS Forum | Home Theater Discussions And Reviews
Old 01-29-2012, 12:22 PM - Thread Starter
jefejt's Avatar
How would this be as a starting point for a computer? I'm looking to stream video and eventually use as a DVR. I have to do it all inexpensively and I can add components in time. My budget is $400-500 total.
http://www.tigerdirect.com/applicati...286&CatId=2628
jefejt is offline
Old 01-29-2012, 05:31 PM
scoyne88's Avatar
I think you would be better off choosing each individual part, it will save you money and allow you to get what you really need. Under $500 should not be to hard is four needs are just HTPC related. Take a look at assassins sticky there is lots of great info there.
Before you criticize someone, you should walk a mile in their shoes.That way, when you criticize them, you're a mile away and you have their shoes.
DIY Speaker Cables
http://www.seancoyne.org
scoyne88 is offline
Old 01-29-2012, 06:30 PM
Paul E. Fox, II's Avatar
Agreed...read Assassin's thread and then BUY THE GUIDES! You will not regret it!
Paul
Paul E. Fox, II is offline
