24ps from HTPC - AVS Forum | Home Theater Discussions And Reviews
Old 01-30-2012, 02:53 PM - Thread Starter
CHRIS650's Avatar
I have been using HTPC (both Windos and Mac) for a long time. Recently upgraded computer connection to my TV from VGA to HDMI. All my DVD and Blu-ray are stored in ISO format for maximum information retention.
One day, by accidental comparison, I realized that the play back from my Blu-ray player is much smoother than the computer. Both of them are HDMI connection. Upon further examination, I saw the my tv was taking 24ps from Blu-ray player and naturally 60hz from my computer.
My question is:
1) since I retained the maximum information by ISO, is it possible to somehow transmit original 24ps from my HTPC's to TV?
2) I don't want to convert and process all my ISO files to mkv
3) What do others do?
CHRIS650 is offline
Old 01-30-2012, 03:14 PM
JMGNYC's Avatar
I use SetDisplayFrequency which is part of AnyDVD HD. It changes the refresh rate of the HTPC (if your video card supports it) to 23.976 for BD ISO and DVD ISO if you set it up. It works perfectly with PDVD11 within 7MC for me.
JMGNYC is offline
Old 01-30-2012, 03:57 PM
lockdown571's Avatar
Quoted: 36 Post(s)
Liked: 87
Where is this setting? I'm having trouble finding it.
lockdown571 is offline
Old 01-30-2012, 04:16 PM - Thread Starter
CHRIS650's Avatar
So you use AnyDVD HD to play back Blu-Ray ISO?
I use PowerDVD... I don't know there is such a setting.
CHRIS650 is offline
Old 01-30-2012, 04:26 PM
JMGNYC's Avatar
It's in the setting application. It's under External Program.
JMGNYC is offline
Old 01-30-2012, 04:29 PM
JMGNYC's Avatar
I use PDVD also for playback. AnyDVD HD is not a playback program. It removes copy protection. So what happens with an .iso is that it get's mounted as a disc. AnyDVD HD sees the new "disc" and changes the refresh rate of the video card. Then PDVD plays it back. It's all pretty seemless. It also works if you insert a physical disc into the disc drive.
JMGNYC is offline
Old 01-30-2012, 08:09 PM
xzener's Avatar
Quoted: 30 Post(s)
Liked: 38
Does it work with folder rips?
Xzener
xzener is offline
Old 01-30-2012, 09:45 PM
JMGNYC's Avatar
I don't believe so. It's meant for disc/.iso playback. I haven't tried though so it might be worth a shot. There may be more info over on the Slysoft forums.
JMGNYC is offline
Old 02-05-2012, 09:36 AM - Thread Starter
CHRIS650's Avatar
It worked well with my PowerDVD for playing back BD. However, its 24hz causes overscan. How do you guys deal with it?
CHRIS650 is offline
Old 02-05-2012, 09:47 AM
GreenEyez's Avatar
What GPU? For ATI you need to set that damn overscan for each resolution back to 0 for example.
GreenEyez is offline
Old 02-05-2012, 10:06 AM - Thread Starter
CHRIS650's Avatar
you mean each time i play BD, i need to go to graphic card setting and redo the setting?????
CHRIS650 is offline
Old 02-05-2012, 12:55 PM
mcantu1's Avatar
try the picture size setting on the tv itself before changing overscan settings on the video card
mcantu1 is offline
