*Official* PowerDVD 12 Thread - Page 9 - AVS Forum | Home Theater Discussions And Reviews
post #241 of 265 Old 01-31-2013, 03:28 PM
pan2013's Avatar
Finally upgraded from my 6 year-old TV, and joined the world of 3DTVs for the first time with a "Panasonic TC-P65VT50".
When I play a 3D Blu-ray through PowerDVD 12 Ultra (thru my Core 2 Duo + Geforce GT610 HDMI 1.4a HTPC), the VT50 never detects a 3D signal and never prompt me to switch to 3D.
If I press the "3D" button on the Panasonic Remote, then the TV will then give me two options as,
"2D -> 3D"
"2D"
I suppose that means I will be using the TV's abilities to convert 2D into 3D?
The ironic part is that if I play a 3D MKV file that I download from the Internet (with two video images side-by-side) using PowerDVD 12 Ultra, then the TV would detect a 3D signal and prompt me to switch to 3D.
Any idea what I could be doing wrong here?
pan2013 is offline
post #242 of 265 Old 01-31-2013, 04:10 PM
babgvant's Avatar
Liked: 30
"2D -> 3D"
"2D"
Did you enable 3D output in the Geforce config utility?
babgvant is offline
post #243 of 265 Old 02-03-2013, 10:26 AM
metropole's Avatar
Quoted: 48 Post(s)
I just run into some issues with a Netflix "Total Recall" BlueRay.
I have PowerDVD11. Is there any advantage upgrading to 12?
I am using it just for BlueRay playback, streaming audio directly to the receiver - so I am not using any audio decoding.
metropole is offline
post #244 of 265 Old 02-03-2013, 09:31 PM
pan2013's Avatar
That was exactly it!!
Went though Nvidia's Stereoscopic 3D wizard in Nvidia's Control Panel, and all the 3D Blu-ray works like a Charm in PowerDVD 12.
Thanks babgvant!
pan2013 is offline
post #245 of 265 Old 02-04-2013, 06:13 AM
babgvant's Avatar
Liked: 30
Thanks babgvant!
Np.
NVIDIA GPUs prioritize gaming use cases over media consumption, so depending on your setup you may need to toggle the setting to play 3D BD in 3D and 2D BD in 2D.
babgvant is offline
post #246 of 265 Old 02-10-2013, 10:11 AM
natas777's Avatar
Is there a way to get powerdvd 12 to ask to switch to 24fps for m2ts files? When I play blurays it ask me to switch but my m2ts files do not. The m2ts files play at the refresh rate windows is currently in.
natas777 is offline
post #247 of 265 Old 02-12-2013, 11:13 AM
mejinuf's Avatar
Hi guys,
Anyone getting flashes during 1080p playback with Powerdvd 12 ultra?, its only with full HD content the rest is perfectly fine. Im using a Gtx570, 8 gb ram, I5-760 @ 3.6ghz connected to a Panasonic plasma & Denon Avr 1912 through Hdmi 1.4a, thanks.
mejinuf is offline
post #248 of 265 Old 03-25-2013, 08:16 PM
andretiton's Avatar
Hi,
My PowerDVD 12 works perfectly, except for subtitles in 3D. Subtitles appear separate, as if the movie always stay running side by side, without turning the 3D effect!
Any solution?
andretiton is offline
post #249 of 265 Old 04-02-2013, 07:57 AM
lakoros's Avatar
lakoros is offline
post #250 of 265 Old 04-02-2013, 07:59 AM
andretiton's Avatar
Originally Posted by andretiton View Post
Hi,
Any solution?
Somebody help?
post #251 of 265 Old 04-02-2013, 08:13 AM
SamuriHL's Avatar
Originally Posted by lakoros View Post
PowerDVD 13
Yea, I bought it this morning. The new audio delay option allowed me to fix the audio sync problems that have plagued me since I got my new TV in January. The speed is really impressive. WAY faster than any other version. I like it so far but I've only used it for an hour or so.
SamuriHL is online now
post #252 of 265 Old 04-02-2013, 05:06 PM
Barry C's Avatar
Quoted: 290 Post(s)
Liked: 173
Does anyone know whether Power DVD 13 will play 3d video clips from 3d camcorders at their native frame rate- 60i for the JVC TD1? The big problem with Power DVD is that it will only play clips at 24p which means clips shot at higher frame rates can be choppy. It would be great if they fixed this problem in version 13.
If anyone knows the answer to this, who has 13, could you please post it?
Barry C is offline
post #253 of 265 Old 04-03-2013, 02:03 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
30-day working trial is available (it won't mess up your existing version). Or if you post a short clip somewhere, I am willing to test it.
Update
Never mind. I found 4 clips here shot by JVC GS-TD1:
- MTS AVCHD 3D (1920x1080i60 AVC, Side by Side (Half)) TXP / TSP
- MP4 (1920x1080i60 MVC) THR / TSR.
I set "3D display" to "HDMI 1.4 enabled 3DTV (720p60)". All files played just fine in 3D. I also tried to play them back with PowerDVD 12 and TMT6, but failed.
renethx is offline
post #254 of 265 Old 04-03-2013, 10:27 AM
kevin_y's Avatar
While playing a 3D Blu-ray in PowerDVD 12 Ultra in 3D mode, if I press time seek (PgUp or PgDn key), I'm instantly kicked out to 2D mode. Has anyone experienced this? Can anyone try to see if they can duplicate this? Pressing FF and REV does not cause this problem. But I prefer to use time seek.
I'm using PowerDVD 12 Ultra, latest update 3/18/13, build 2625, and Nvidia 3D Vision 2 latest driver 3/25/13, version 341.22. I use Windows 7 64-bit Home Premium, EVGA GTX 480 graphics card, and ASUS VG278H 3D 27" monitor.
kevin_y is offline
post #255 of 265 Old 05-29-2013, 01:39 AM
TitanFan's Avatar
I'm using PowerDVD Ultra, and can't figure out how to get the chapter forward/back navigation to work. I have an MKV file that has several chapter markers, and I can navigate to them using VLC, but how do I navigate to the chapter marks using PowerDVD??
TitanFan is offline
post #256 of 265 Old 05-29-2013, 04:27 AM
Batiatus Rules's Avatar
Quoted: 31 Post(s)
Liked: 35
I'm been setting up a HTPC to run XBMC 12.0 and experimenting with both TMT6 and PowerDVD12 as the external player to playback full HD 3D Blu-ray ISO files. Both programs give me 2 issues that I need to figure out how to resolve before I actually purchase 1 of them.
First, the auto play. What a pain in the butt! I mainly put discs into the BD drive to rip them, not to have them automatically launch TMT5 of PowerDVD12. Annoying and thus far I've not found the option that will kill this annoying feature.
Second, HD 3D playback works after doing some testing, but the video is scaled down at least 10% of the screen. I can not find the option to sort this out. I'm running a Radeon 6670 GPU with AMD 3DHD drivers and Catalyst Control installed in Windows 8.
I need to resolve both of these problems, for either program but the more I read about TMT6 the less I like, and the sooner the better as the projector arrives next week!
Batiatus Rules is offline
post #257 of 265 Old 05-29-2013, 07:07 AM
acejh1987's Avatar
You should be able to stop the Autoplay through Windows Control Panel.
Control Panel > Hardware and Sound > Autoplay > Change to required setting for a Blu-ray movie (Take no action)
Batiatus Rules likes this.
acejh1987 is offline
post #258 of 265 Old 05-29-2013, 07:12 AM
Quoted: 31 Post(s)
Liked: 35
Thank You!!!!!
And now I've fixed my scaling issue. Almost there!
post #259 of 265 Old 06-25-2013, 03:51 PM
jeff lam's Avatar
Has anyone experienced choppy video playback during blu ray disk playback? I built a new HTPC with an i3 3225 HD4000 graphics. 8GB Ram, LG 10x blu ray drive. I'm bit streaming HD audio to my Denon receiver and while the audio is fine, I'm getting slight video choppy playback. It's subtle but definitely noticeable. It doesn't always occur but mostly happens every 10 min or so during a show or movie on blu ray. pausing briefly then resuming, or skipping chapters will fix it temporarily till it happens again a few minutes later. Any ideas?
jeff lam is offline
post #260 of 265 Old 06-25-2013, 04:26 PM
PeterTHX's Avatar
Quoted: 477 Post(s)
Liked: 341
Last time I had that problem it was the drive.
lespurgeon likes this.
My opinions do not reflect the policies of my company
PeterTHX is offline
post #261 of 265 Old 06-26-2013, 06:25 AM
babgvant's Avatar
Liked: 30
I've had that problem (the drive was spinning down or something similar IIRC) too.
babgvant is offline
post #262 of 265 Old 06-26-2013, 01:18 PM
jeff lam's Avatar
Thanks for the input. I currently have an LG 10x blu ray drive and it seems to work fine for everything else I do. Maybe I'll try a brand with better support and firmware updates. What is the choice brand for blu ray playback these days?
jeff lam is offline
post #263 of 265 Old 06-27-2013, 12:39 AM
TitanFan's Avatar
Any ideas?
TitanFan is offline
post #264 of 265 Old 06-27-2013, 09:35 AM
PeterTHX's Avatar
Quoted: 477 Post(s)
Liked: 341
I've had really good luck with Pioneer's BD drives. I haven't even thought to look for a firmware update for it in quite a while.
PeterTHX is offline
post #265 of 265 Old 02-12-2014, 04:35 AM
kevtech's Avatar
How to Solve PowerDVD 12 bluray playback stutter / judder using ReClock - this is a guide on how to setup PowerDVD12 + Windows 7 + ReClock to remove or substantially reduce Stutter & Judder during Bluray playback http://hometheatre.ie/how-to-solve-powerdvd-12-bluray-playback-stutter-judder/ .
kevtech is offline
Reply Home Theater Computers
