Corel WinDVD11 thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 69 Old 11-28-2013, 03:19 PM
cybrsage's Avatar
Liked: 154
AnyDVD (HD) 7.3.7.3 beta
7.3.7.3 2013 11 26
- New: WinDVD 11.6.1.4 is now supported by AnyDVD's unique Cinavia fix
Safe to start using WinDVD 11.6
cybrsage is offline
post #62 of 69 Old 11-28-2013, 09:42 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Originally Posted by cybrsage View Post
Why should it have BDMV folder support? Why? Why sMedio should support BDMV folders?
It should have BDMV folder support if Corel wants to sell more copies. I would consider the player if it did.
lespurgeon is offline
post #63 of 69 Old 11-28-2013, 10:20 PM
kokap's Avatar
BTW sMedio has not released any update yet. The latest WinDVD version from sMedio is still 11.5.0.61. frown.gif
kokap is offline
post #64 of 69 Old 11-29-2013, 08:24 AM
cybrsage's Avatar
Liked: 154
The Corel update works on both, afaik.
cybrsage is offline
post #65 of 69 Old 11-29-2013, 08:25 AM
cybrsage's Avatar
Liked: 154
Why do you use BDMV folders?
cybrsage is offline
post #66 of 69 Old 11-29-2013, 08:28 AM
kokap's Avatar
No, versions are different - btw I have both versions.
kokap is offline
post #67 of 69 Old 12-04-2013, 05:05 AM
kokap's Avatar
You are right, I'm wrong. Corel WinDVD SP3 (i.e. v11.6) can be installed over sMedio v11.5. I 've done this without problem. And sMedio logo have been changed to Corel logo. smile.gif
P.S. I have never received any message about updates from sMedio. BTW sMedio WinDVD doesn't have "Check For Updates" button (Corel WinDVD does).
kokap is offline
post #68 of 69 Old 12-04-2013, 05:20 AM
cybrsage's Avatar
Liked: 154
It really is a confusing relationship - what is the difference between the two groups selling the same software? Check the installation folders too, I bet it moved. Very odd...
cybrsage is offline
post #69 of 69 Old 12-04-2013, 05:41 AM
kokap's Avatar
kokap is offline
Reply Home Theater Computers
