Why don't more people use XBMC? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 115 Old 02-21-2012, 08:13 AM
ncarty97's Avatar
Quoted: 77 Post(s)
Liked: 43
Originally Posted by assassin View Post
Still very limited, unfortunately. Looks like you can't access anything that is copy once protected.
Looks like WMC is unfortunately still the only answer for people wanting to replace cable/satellite.
I wonder if it will record the copy-once content, but just not play it? Maybe set it up to launch 7MC for the copy-once programs?
Carty Custom Builders, LLC
ncarty97 is offline
post #92 of 115 Old 02-21-2012, 08:59 AM
ser_renely's Avatar
I have been mainly using XBMC. I do want to try the others. I like the XBMC a lot, some parts of it are annoying, but its has a lot of options.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
post #93 of 115 Old 02-21-2012, 04:20 PM
kegobeer's Avatar
Originally Posted by gonzo90017 View Post
Could you explain your car setup? I was thinking about this very issue last night.
I'll send you a PM so we don't divert this thread away from the HTPC world and into the carpc world.
kegobeer is offline
post #94 of 115 Old 02-23-2012, 08:04 PM
dj4monie's Avatar
Quoted: 37 Post(s)
Liked: 25
Originally Posted by Gary Quiring View Post
You mentioned Linux a lot in your comments and I just to clarify that XBMC also run on Windows and OSX. The Windows version is much easier to deal with than any Linux distro and no AMD issues. What's also cool is XBMC can be installed on a $99 Apple TV.
I have been using Second Run TV for some content and Macro Tube for You Tube and TwIT. I know both XBMC and Boxee are both Linux based but have been compiled to run on a Windows OS.
Linux is so small (well Mint 11 isn't, fully loaded its a DVD iso) that the advantage of Linux for single use hardware is better than using Windows IMHO.
If XBMC had TV Tuner support (full support), then would be a viable option for me at least.
XBMC can be installed on Rasberry Pi... ARM processor based, I hope to order one for another project at the end of the month.
A. Thomas
PSN - DJFourMoney
dj4monie is offline
post #95 of 115 Old 02-24-2012, 06:25 AM
Mntneer's Avatar
Quoted: 40 Post(s)
I use WMC simply for the convenience, and the ability to watch and record channels like HBO without having to jump through a bunch of hoops.
It, combined with My Movies does all I need.
Mntneer is offline
post #96 of 115 Old 02-24-2012, 06:37 AM
Theresa's Avatar
Liked: 51
One reason I don't use XBMC more is that the scroll wheel on my mouse sometimes fast forwards and reverses unintentionally. Is there a way to disable the scroll wheel when using XBMC? I've tried the Logitech app to disable it but that hasn't worked.
Theresa is offline
post #97 of 115 Old 02-24-2012, 06:45 AM
Gary Quiring's Avatar
Quoted: 14 Post(s)
I have mapped a few keys in XBMC to do different things. It's very flexible with the keymap and mouse files. Read this post it should help:
http://forum.xbmc.org/showpost.php?p=810916&postcount=4
noop
noop
Gary Quiring is offline
post #98 of 115 Old 02-24-2012, 06:52 AM
Quoted: 14 Post(s)
It refers to a "keymaps" folder that isn't present on my machine.
Every XBMC has a keymap folder but you probably don't have the file. Keymaps is under userdata.
Use this doc to help locate your settings location:
http://wiki.xbmc.org/index.php?title=Keyboard.xml
post #99 of 115 Old 02-24-2012, 07:29 AM
Theresa's Avatar
Liked: 51
Found it, thank you. Messed up the mouse settings first so had to reinstall XBMC but was able to modify the mouse settings on my second try.
Thank you all.
Theresa is offline
post #100 of 115 Old 02-24-2012, 08:12 AM
GreenEyez's Avatar
In XBMC, in Settings -> System -> Input Devices -> Disable mouse and touch screen support (uncheck the option). That`s the easy way
GreenEyez is offline
post #101 of 115 Old 02-24-2012, 08:43 AM
Quoted: 14 Post(s)
I don't think they wanted to disable all mouse functions, just the wheel.
post #102 of 115 Old 02-24-2012, 08:55 AM
Theresa's Avatar
Liked: 51
Yes, just the wheel.
Theresa is offline
post #103 of 115 Old 02-24-2012, 09:08 AM
Lars99's Avatar
After using both extensively, for me I prefer XBMC. I found it less intuitive to set up but significantly more flexible and customizable once done so.
Among the features of XBMC that I enjoy over the WMC/MB setup is the ability to create a single database for all of my HTPCs and then pause/stop in one room and resume in another.
Additionally, the iOS integration and Airplay make the systems far more entertaining to use.
I also enjoy how much cheaper XBMC is to set up (lower hw requirements, no Win 7 license, etc).
Lastly, I find the XBMC community larger and more responsive so I believe help is easier to come by and updates are pushed out with greater ease.
There are a few things I miss with WMC/MB that I don't believe will ever be fully implemented in XBMC.
I'm curious what changes the WMC/MB community will have in store once Win 8 is released.
Ultimately, it will be user preference of course. I encourage anyone interested to give both an honest try and evaluate based on your needs and desires.
Lars99 is offline
post #104 of 115 Old 02-24-2012, 09:55 AM
Ferrino's Avatar
What is the state of native XBMC support for streaming and recording live television (i.e. with a guide etc...)? Is it in the works? I just picked a HDHomeRun and at the moment I'm looking at a WMC/MB setup, but I think I'd prefer XBMC if it could do TV!
Ferrino is offline
post #105 of 115 Old 02-24-2012, 10:28 AM
Quoted: 14 Post(s)
There is a forum dedicated to PVR but I have not followed it so I don't any details.
http://forum.xbmc.org/forumdisplay.php?f=136
post #106 of 115 Old 02-24-2012, 02:05 PM
dale7344's Avatar
Because it won't play bluray disc or work out of the box with my TV tuner.
Otherwise it looks quite nice.
Currently using mediaportal, which at least does the TV Tuner bit.
dale77
dale7344 is offline
post #107 of 115 Old 02-24-2012, 02:35 PM
Defcon's Avatar
Quoted: 1166 Post(s)
Liked: 615
It would be great if we had a Metro version of XBMC, installable and upgradeable from the app store, but I think that will be a significant effort and would not be able to share code with other XBMC versions. It would almost have to be a separate product.
Defcon is offline
post #108 of 115 Old 02-24-2012, 04:50 PM
kegobeer's Avatar
Nothing plays BD out of the box - to get full BD support you need TMT or PDVD. However, XBMC Eden does play BD rips "out of the box" - it picks the largest file and plays it, which sometimes is the right one and sometimes is the wrong one, but at least it works. And you can launch TMT/PDVD from XBMC, just like WMC does.
kegobeer is offline
post #109 of 115 Old 02-24-2012, 05:59 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Originally Posted by Murilo View Post
Out of curiosity i have been meaning to ask why people use htpc cable cards instead of the companies dvr?
Is it because of storage? I can add 3tb to my satellite dvr.
It always just seemed like more work..
I must be missing something.
You are.
It's about versatility. You can do much more with a HTPC including steaming to multiple rooms. Storing. ect....
Mfusick is offline
post #110 of 115 Old 02-24-2012, 06:00 PM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
You are.
Not to mention in the long run its much cheaper. And if you are going to own a HTPC anyway then its a no brainer.
assassin is offline
post #111 of 115 Old 02-24-2012, 06:14 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
What do you think is the best option for recording cable TV?
Mfusick is offline
post #112 of 115 Old 03-05-2012, 08:05 AM
Quoted: 14 Post(s)
Originally Posted by TheTinkerer View Post
Yes you have to restart or force an update. Not smart enough to autoscan.
That is one way but it also supports a timer like function similar to media browser.
Here are the screen shots:
post #113 of 115 Old 03-05-2012, 10:10 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
If you meant with CableCARD, then the only option for PC is Windows Media Center.
ilovejedd is offline
post #114 of 115 Old 03-05-2012, 10:15 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Originally Posted by ilovejedd View Post
if you meant with cablecard, then the only option for pc is windows media center.
+1
assassin is offline
post #115 of 115 Old 03-05-2012, 10:24 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 414
No, copy-once contents are encrypted coming out of the Cablecard tuner. Only WMC is certified and capable of decoding it.
Since most of the programs I watch are copy-once, XBMC is not for me.
Foxbat121 is offline
Reply Home Theater Computers
