On Commercials... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 02-13-2012, 06:31 AM - Thread Starter
Norsican's Avatar
An Observation I've made over the weekend:
It's seems there are fewer Commercials on OTA broadcasts. Maybe it's me, or maybe they put more breaks with fewer slots in them or something, but it seems that the commercials are different on OTA stuff.
I rarely watch these things. They offend me as some deep level. I tend to watch the people fumble and fart around trying to sell me something that I will see at the hardware store on the "AS SEEN ON TV" end cap in the red tag section rather than pay any attention to the product they are peddling.
I'd like to do away with commercials altogether. That is, I'd like to not have to Fast Fwd through the ads at all. I've seen some solutions out there with respect to some scripts or addons etc but would like to know what people here are using if anything at all?
I'm currently on WMC7 and will likely implement Media Browser once I get to that point in a couple of weeks.
THERE IS NO NORSICAN, THERE IS ONLY ZUUL
Norsican is offline
post #2 of 18 Old 02-13-2012, 07:58 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
I think this might be what you're looking for:
http://www.hack7mc.com/2009/08/setup...-skipping.html
I use it and it works great. Keep in mind that no commercial-skipping app is 100% accurate, but I find that ShowAnalyzer works correctly about 80% of the time. You can also fine tune it for specific shows.
captain_video is online now
post #3 of 18 Old 02-13-2012, 08:17 AM - Thread Starter
Norsican's Avatar
Thanks, I'll have a look at it.
Question:
What happens in the other 20% of the time it doesn't work as intended?
Norsican is offline
post #4 of 18 Old 02-13-2012, 11:33 AM
Quoted: 510 Post(s)
Liked: 336
Question:
If it doesn't properly detect a commercial break it will skip past it to the next marker. You can hit the left arrow button on your remote, if you're using the default key assignments, and it will return to the spot where you skipped from. You can then fast forward past the commercial manually. Occasionally you'll get a recording that indicates no commercial file was created and you'll be prompted to create one. If the file doesn't exist, chances are the recorded program has some issues that caused ShowAnalyzer to terminate when trying to map it. Saying yes to the prompt doesn't usually work if this occurred.
You can configure ShowAnalyzer to skip past the commercials automatically without any intervention from the viewer. This is great until you run into a situation where the commercial mapping isn't correct. Pressing the left arrow key won't necessarily return you to the previous spot with the autoskip feature on, which is why I prefer to do it manually. You can turn autoskip on and off using the down arrow button.
The bottom line is that the program works well most of the time. Broadcasters don't always leave dead space between the commercial and the program being aired, which is what most commercial skipping apps look for when mapping the breaks. If you have to skip past it manually, it's not that much of an annoyance.
post #5 of 18 Old 02-13-2012, 12:46 PM
linguica101's Avatar
I use a combination of comskip and dvrmstoolbox +dtbaddin for wmc7
if you donate to the creator of comskip ($10) you can get a version that can work directly with the .wtv file instead of having to convert to dvr-ms first.
Hope this helps.
linguica101 is offline
post #6 of 18 Old 02-13-2012, 01:05 PM
bryansj's Avatar
Quoted: 1123 Post(s)
Liked: 555
I couldn't get automatic commercial skipping working well enough to keep up the WAF. I eventually uninstalled it.
bryansj is offline
post #7 of 18 Old 02-13-2012, 02:21 PM
Quoted: 510 Post(s)
Liked: 336
Hope this helps.
You don't have to convert wtv files to dvr-ms for use with ShowAnalyzer. It works fine with straight wtv files with no conversion required.
You might want to check out the ShowAnalyzer School feature to customize it for individual programs. The automatic skipping feature is hit or miss, which is why I choose to do it manually. If the commercial isn't mapped properly I just FF through it to get to the next show segment. Otherwise it's a simple press of the right arrow to skip the commercial. Apparently there's also a 29-second skip feature when using the next chapter button on your WMC remote, but I haven't tried it yet.
post #8 of 18 Old 02-13-2012, 02:53 PM
bryansj's Avatar
Liked: 555
I used ShowAnalyzer with DVRMS. If I have to tweak the program for each show then that'll mean downtime on my HTPC which means less WAF. Teaching the wife multiple FF techniques isn't going to work either.
I've adjusted the skip fwd and rew times so that it skips easier using the registry edits. I just can't get the automated skipping working well enough to let it work on its own. It also appears that development has stopped on ShowAnalyzer.
bryansj is offline
post #9 of 18 Old 02-13-2012, 03:25 PM
I realize that ShowAnalyzer works directly with .wtv (so does the donator version of comskip...which i believe is cheaper than ShowAnalyzer?)
Also, I've read that support of ShowAnalyzer is obsolete or non existant at this point. Comskip is still going strong and the developer is very good at providing support over at his forum.
post #10 of 18 Old 02-13-2012, 03:56 PM
ghostlobster's Avatar
I use Show Analyzer in conjunction with DVRMSToolbox and the DTb add-in for automated commercial skip. Is it perfect? No. Does it work great? Yes! Sometimes it fails to skip a commercial set, but that's really no big deal to me. Did I have to mess with settings for individual shows? Hell no! Just import the profile from the show analyzer forum and let 'er rip! Just the one main profile, mind you, not individual profiles for individual shows. I use DTb's file watcher as opposed to Show Analyzer's as I found it far more stable. And the DTb add in for automated commercial skipping just plain works. Check the wikis and forums for each individual product for install and config instructions, but once it's set up' it works great. I've been using babgvant's applications since 2005, and I have to say, Andy is one of the best developers out there, hence DTb works so well, and does so much!
Ray
===Ghostlobster===
ghostlobster is offline
post #11 of 18 Old 02-13-2012, 04:22 PM
i have the same setup, just substitute ShowAnalyzer with Comskip (I guess it boils down to preference). I think it works great as well. And if it is off or doesn't mark the commercial exactly (which is rare mind you) I simply turn it off via the dtb addin controls, so I never lose any of my recording. it just works!
post #12 of 18 Old 02-13-2012, 05:55 PM
Quoted: 510 Post(s)
Liked: 336
You don't have to tweak it for every program, but it's an available option if you want to use it. You either hit the right arrow to skip or use the FF button to pass thru the commercial. Where are you coming up with multiple FF techniques?
post #13 of 18 Old 02-13-2012, 06:05 PM
Why FF/skip forward at all? Install the DTb add-in and you don't have to lift a finger, or thumb. Awesome automated laziness.
Ray
===Ghostlobster===
post #14 of 18 Old 02-13-2012, 07:27 PM
bryansj's Avatar
Liked: 555
There have been multiple FF techniques mentioned in this very thread, see post 4. I have used SA with DVRMS and had the DTb add-in installed and it skipped automatically.
However, sometimes it didn't and the time that it overskipped and went to the end of the following commercial break is when it failed. At the end of the show I hit delete and then my wife mentioned not seeing such and such part of the show. So we could have realized that the program screwed up, but we didn't. I didn't feel like jumping through all the hoops to make profiles for shows it fails to detect. And then telling my wife that it skips automatically (high WAF), but sometimes it doesn't so pay attention. When it skips too far then hit this button to skip back, then this button to disable autoskip and then skip the commercial normally, then turn auto skipping back on (way low WAF).
If it was just me then I'd be all over it, but the way it is now it just isn't going to work. If Comskip plus DVRMS works a lot better then I might try it again. I'm all for the idea, but just warning that there is the possibility for low WAF.
bryansj is offline
post #15 of 18 Old 02-13-2012, 09:38 PM
gorthocar's Avatar
I convert my wtv files to ts files with remuxtool. Then I use a ts editor to clip out the commercials before I actually watch the show. I do it manually, which means I typically correctly get everything important and none of the commercials. It usually takes me less than 3 minutes per hour long show, approx. 5 or 6 segments of the show. They certainly cram in a lot of commercials in OTA shows. The one I just finished watching was slightly under 40 minutes after removing the commercials, which means that 20 minutes (1/3rd) was commercials.
Bazinga!
gorthocar is offline
post #16 of 18 Old 02-14-2012, 05:01 AM
Quoted: 510 Post(s)
Liked: 336
The average 1-hour network broadcast show is typically about 42 minutes long, leaving 18 minutes for commercials. Skipping past the commercials takes less time than converting, editing, and remuxing. It's just not worth it to me unless I plan on archiving the show.
post #17 of 18 Old 02-14-2012, 06:30 AM - Thread Starter
Norsican's Avatar
Great suggestions. This is the type of discussion I was hoping for.
The Idea here is to make it easy to everyone involved at the house. this includes the wife, and 2 young daughters. It needs to be easy and it needs to work. When I say that I mean those involved would rather have to FF through a commercial than miss a part of the show.
The more automated the better.
Norsican is offline
post #18 of 18 Old 02-14-2012, 08:19 AM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 911
FWIW when I want to keep something from my stand alone HDD DVD recorder I just put chapter marks at the end of the commercial blocks. Then you can just hit 'Next Chapter' on the remote and miss the commercials. It's sometimes also kind of neat to see the news bumpers from the night the show was recorded.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Reply Home Theater Computers
