Help! Video Card over HDMI will not sync with monitor. No Signal. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-13-2012, 09:35 AM - Thread Starter
mkedda's Avatar
SETUP
HTPC ----> HDMI ---> ROTEL PROCESSOR --> HDMI --> MONITOR
If I boot up the HTPC with everything on, it's perfect! Detects monitor and outputs properly at 1920x1080, as you would expect.
If I turn off the Projector and/or the Rotel Processor OR switch inputs, I can come return to the HTPC and displays fine.
If I reboot the computer or resume from standby without the processor and monitor turned on, I CANNOT get an image.
I know the computer is connected because I can access files and remote desktop into it.
I have tried several things but I cannot get it to work, it seems to be a limitation of either windows or the GT430.
I have tried to set the monitor type to 1920x1080p flat panel instead of Generic PnP Monitor - NO GO
I have created both a Projector INF and a Rotel Processor INF using moninfo and set that up as the default monitor - NO GO.
Only solution that works is turning everything (rotel and proj) ON and REBOOTING the HTPC.
PLEASE HELP!!!
mkedda is offline
post #2 of 4 Old 02-13-2012, 06:50 PM - Thread Starter
mkedda's Avatar
Is anyone else experiencing this... Is it windows specific? Brand Specific?
mkedda is offline
post #3 of 4 Old 02-13-2012, 07:18 PM
erickotz's Avatar
Liked: 30
If you take out the processor, does the problem go away? Also try updating your video card to the latest drivers, your display to the latest firmware, and your processor to the latest firmware.
My next thought would be one of those devices that remembers the EDID info and spoofs it when it was off (I think it was called DVI detective?)
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #4 of 4 Old 02-20-2012, 02:05 PM - Thread Starter
mkedda's Avatar
what would the processor have to do with it?
video drivers are current version.
would rather not buy a device to fix what seems like an os problem.
mkedda is offline
Reply Home Theater Computers
