Configured MediaBrowser to start automatically on boot, but now Media is gone - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-14-2012, 12:59 PM - Thread Starter
dykz34's Avatar
Hey guys,
I followed this link:
http://community.mediabrowser.tv/per...-media-browser
and this link:
http://community.mediabrowser.tv/per...indows-startup
....to have WMC startup automatically and load into MediaBrowser upon boot.
The startup sequence is working perfectly, however, when MediaBrowser opens to the Media page it is blank. In fact, it doesn't appear than MB is able to find any of my data. I have "refreshed" via the Configurator as well as turned off "autovalidate" (in hopes that it was my unRAID server not being spun up). Both changes made no difference. Prior to the startup changes, I was able to access, view, and play all of my Media through MB.
Does anyone know what's wrong?
dykz34 is offline
post #2 of 6 Old 02-14-2012, 01:12 PM
Shark007's Avatar
Quoted: 81 Post(s)
Liked: 73
possibly .. a usb storage device or external hardrive is causing the drive letters to change.
such as, when you setup mediabrowser, all your stuff was on 'f' drive, and now, its all on 'g' drive
Use Shark007 Codecs and retain your sanity.
Shark007 is offline
post #3 of 6 Old 02-14-2012, 03:28 PM
Josh3693's Avatar
Question, are you using mapped network drives (Z: ) or UNC paths (//SERVER/media/...)?
Josh3693 is offline
post #4 of 6 Old 02-14-2012, 04:39 PM - Thread Starter
dykz34's Avatar
Mapped network drives. Is that the correct way or should I use UNC?
dykz34 is offline
post #5 of 6 Old 02-14-2012, 04:42 PM
Josh3693's Avatar
The media browser team recommends using UNC paths. Try replacing the mapped drives with UNC paths in the media browser configurator then running a refresh from the media browser service.
Josh3693 is offline
post #6 of 6 Old 02-14-2012, 08:29 PM - Thread Starter
dykz34's Avatar
I changed to UNC paths and refreshed the data - it works again. Thanks for the help!!! I'll try again tomorrow, when the unRAID server is spinned down to ensure that everything will wake up correctly.
dykz34 is offline
Reply Home Theater Computers
