HTPC case smaller than 5 3/4" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 02-16-2012, 11:29 AM - Thread Starter
bogdatov's Avatar
I'm looking for HTPC case which would blend with my environment. Almost bought Silverstone GD05B (which seems to be ideal for me) but it turns out this case is 5.91" tall, which I can have only 5 3/4"
Any ideas for the case?
bogdatov is offline
post #2 of 15 Old 02-16-2012, 11:44 AM
BLOCKMONSTER's Avatar
What about Silverstone LC02 (http://www.silverstonetek.com/produc...id=67&area=en)? About 4" tall but it has its quirks you proabably have to do workarounds to make it suitable for you.
EDIT: ML03 what renethx suggested is MUCH better and only around 60$. Cant believe I forgot about that one.
BLOCKMONSTER is offline
post #3 of 15 Old 02-16-2012, 11:46 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
post #4 of 15 Old 02-16-2012, 12:11 PM - Thread Starter
bogdatov's Avatar
Thanks guys.
This ML03
http://www.silverstonetek.com/produc...id=283&area=en
I understand I can fit SSD + 3.5 HDD into it.
What about DVD/BR - do I need to go external ?
When description says: Expansion Slots: 4 low profile +1 utility
What does that mean ?
I'm planning to put i3 into it. Not sure if build-in Video will be enough. And if not - can you recommend Video card which will fit ?
And for CPU cooler - any recommendations ?
bogdatov is offline
post #5 of 15 Old 02-16-2012, 12:28 PM
jeffkro's Avatar
Originally Posted by bogdatov View Post
Thanks guys.
This ML03
wow, cool case
jeffkro is offline
post #6 of 15 Old 02-16-2012, 01:55 PM
tkole's Avatar
Moncaso 312. Slickest HTPC case on the market, IMO.
http://www.newegg.com/Product/Produc...82E16811280014
tkole is offline
post #7 of 15 Old 02-16-2012, 02:07 PM
jcruse's Avatar
Liked: 27
My HFX Mini disagrees...
http://www.kustompcs.co.uk/acatalog/info_1301.html
jcruse is offline
post #8 of 15 Old 02-16-2012, 04:33 PM
rockytt's Avatar
As does my silverstone LC19
rockytt is offline
post #9 of 15 Old 02-16-2012, 04:50 PM
ToddUGA's Avatar
Quoted: 36 Post(s)
Liked: 29
Thanks guys.
This ML03
That is the case I use. You should be able to fit a 3.5" drive and an SSD in it. May have to get a little creative with the mounting but it shouldn't be too hard.
I use the stock CPU cooler on my i3 and it works fine. I did add a couple of fans to the side of the case to help with heat.
The built-in Intel HD graphics are more than adequate for running an HTPC unless your planning on doing some high-end gaming.
I have an internal Blu-ray drive installed in mine. Here's a pic...
ToddUGA is offline
post #10 of 15 Old 02-16-2012, 05:28 PM
Sandy B Ridge's Avatar
Wow - Ugly!
Mmmmm - Nice!
Sandy B Ridge is offline
post #11 of 15 Old 02-16-2012, 06:04 PM
gorthocar's Avatar
I like my Lian-Li PC-C37B. There are many other nice low profile cases out there. Some of them only fit Micro-ATX form factor, so don't try to jam a full ATX motherboard into them.
Also, be careful with these cases only fit low profile cards. Some video cards and TV tuner cards have a short board, and come with both a normal height bracket and a low profile bracket, but you have to shop for them in particular.
The Core i3's integrated video is quite capable of HTPC duties, but its 24p is slightly off the ideal 23.976 fps most Blu-rays are encoded with. Only you can answer if a frame drop every 5 minutes is within your viewing tolerances with its 23.973 fps, or a duplicate frame every 42 seconds if you set the refresh rate to 24.0 fps. If you are going to use a discrete graphics card instead of the Core i3's integrated video, there are some AMD 6450 and 6570 cards that are low profile. I'd recommend going with the integrated video first, and if you don't like it, add an AMD graphics card.
Bazinga!
gorthocar is offline
post #12 of 15 Old 02-16-2012, 06:43 PM - Thread Starter
bogdatov's Avatar
tkole
Sure this Moneual case is nice, but $210 for the case alone ? That is too much for me.
ToddUGA
Thanks for the pics. Looks nice. How is noise level ? Also which PSU did you choose ? I read that some PSU over 140mm depth may give problem.
Any problems with watching youtube, netflix, etc ?
gorthocar
I will try integrated video 1st, thats for sure. Anyways I mostly watch downloaded video. But I may want discrete video later, and if so, I need to get proper PSU.
Anybody using WiFi in those ? If so, do you use USB stick or MB with WiFi or ?
bogdatov is offline
post #13 of 15 Old 02-16-2012, 08:15 PM
ToddUGA's Avatar
Quoted: 36 Post(s)
Liked: 29
tkole
ToddUGA
Noise level is good, although I added a couple of fans to the side of mine to make sure my Ceton tuner stayed cool. Probably unnecessary, but I'm a bit of a worrier. With normal TV volume at around seven feet away I can't even hear the fans.
Here's the power supply I'm using...
http://www.newegg.com/Product/Produc...82E16817371029
Perfect fit, although hiding some of the extra power plugs was a bit of a challenge.
Youtube, Netflix, etc. work just fine. The Intel HD graphics handle anything I can throw at it, including 3D Blu-ray. Using PowerDVD I get almost perfect playback. Like gorthocar said above, I may see a frame skip every 5 minutes or so but I rarely ever notice it.
ToddUGA is offline
post #14 of 15 Old 02-17-2012, 10:52 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
nMedia PC 1080P is 3.9" high
http://www.nmediapc.com/htpc1080p.htm
Takes full size PSU, and ODD, as well as room for 3 HDDs and SSD.
Oh, and Newegg has it for $40 shipped here and there.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #15 of 15 Old 02-18-2012, 03:19 AM
Mike99's Avatar
Quoted: 133 Post(s)
Liked: 63
I would like to build a DVR for HD OTA recording & playback. Will most of these low profile cases, such as the ML03 accommodate 2 tuner cards and a graphic card? Hopefully a graphic card will not be needed, but for some reason it's needed it would be nice to fit it in.
Mike99 is offline
Reply Home Theater Computers
