Official OrigenAE thread - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #91 of 112 Old 10-21-2014, 08:31 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Originally Posted by V_J View Post
I have the S16t with IR310.
The problem with the iMon drivers is that I cannot turn of that round window that shows the status: it is always there, even if I switch it off in the settings (I believe they call it the "magnetic window").
I didn't play with settings for long time, but I have unchecked magnetic window in my Wesena e7. I also set "Run FrontView" to NEVER. I have clean screen and the only info popping out is a Touch Frame confirmation when I touch the screen.
I'm running the preview of Windows 10, so that may be the issue,
I don't think so. Please check settings in iMON manager step by step.
but the iMon drivers haven't been updated in a long time, which is a bit worrying.
EventGhost has a plugin to allow input from iMon, but it also needs the drivers. LIRC (under Linux) seems to have direct support, without the drivers, but WinLIRC does not.
Check Soundgraph forum, please.
Regards
Zygmunt
Perfect Home Theater
Zygmunt is offline
post #92 of 112 Old 10-21-2014, 09:31 AM
V_J
Quoted: 47 Post(s)
It is the setting "display IR indication".
Now to start enjoying it...
V_J is offline
post #93 of 112 Old 12-01-2014, 04:51 AM
V_J
Quoted: 47 Post(s)
I had a small issue with the case: the front USB3 connector was quite unstable. I suspect it was caused by the blue cable that connects to the mainboard (it had a kink in it, like it got squeezed somewhere - not even sure it was not my fault). As the warranty procedure was a too mush hassle, I contacted OrigenAE and just ordered the replacement part (S-FRIO-P6). With hassle, I mean that I would either have to ship out the case to Germany (no pc for several weeks, I have no spare case) or the part to Korea (opening/closing of the case). It just arrived, and I plan to install it on Saturday (I have to remove the case, and plan to make some order in the cable mess behind it, so I need enough time).
Zygmunt: Is the S-FRIO-P6 part difficult to screw in: any pitfalls to be aware off; particular tools needed? Any suggestions to have the least issues? I suspect removing the ODD holder would give enough access.
Jörg
V_J is offline
post #94 of 112 Old 12-01-2014, 11:45 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Jörg
No particular tools at all. Just screwdriver philips #2 . Remove ODD to have full access to this board. Pay attention to USB cables, connect them in the same way.
Regards
Zygmunt
Zygmunt is offline
post #95 of 112 Old 12-01-2014, 11:54 AM
V_J
Quoted: 47 Post(s)
Ok, thanks!
Jörg
V_J is offline
post #96 of 112 Old 12-05-2014, 02:48 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Hi Guys
I have S21T since 2007 and my cables connecting 12" monitor to S-THUB-P2 broke. Unfortunately I was checking these cables with computer ON so I fried S-THUB-P2 and damaged video card connected to it.
When you have a problem with picture on 12" monitor, check cables with computer OFF!
I ordered several sets of cables. If your S21T is older that 2009 or you move your screen up and down frequently - order cables now.
I will get S-FRIO-P6 board and couple of cover plates for S chassis. Anybody interested? (KMD, I remember about your S16V-B)
Regards
Zygmunt
Zygmunt is offline
post #97 of 112 Old 12-08-2014, 04:26 AM
V_J
Quoted: 47 Post(s)
Small question... I'm not too fond of the iMon system: big delays on keypresses, bad software, and I wonder if there are alternatives... Origen used to have IR110, which is IRTrans compatible, they also had some other modules that are now discontinued...
Are there alternatives that can be installed inside an S16t, that work e.g. with WinLIRC or IRTrans?
The only module I see on Origen website is IR100, which says it does not require drivers and works with all Windows. Is this a viable alternative?
V_J is offline
post #98 of 112 Old 01-07-2015, 04:54 AM
Kitlope's Avatar
I'm interested in a S16T and was wondering if you ship to Canada, or where can I get one from that does. I have checked Perfect Home Theater but in the FAQ it says Origen S series doesn't ship worldwide... but since Canada is so close to the US (and most US companies ship to Canada even though they may not anywhere else) I'm wondering if they ship to Canada and it's just not communicated very well.
Anyway, thanks for a response.
Kitlope is offline
post #99 of 112 Old 01-07-2015, 07:26 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
In FAQ? Where ? I didn't find it. Actually we ship to Canada and Mexico and there is even advice for Canadian customers.
Probably. I have to correct it.
Regards
Zygmunt
Zygmunt is offline
post #100 of 112 Old 01-07-2015, 03:45 PM
Kitlope's Avatar
Thanks for the prompt response.
On the home page, when you click on "AV Equipment", you get a link that says "Before you place an order please check this info first". Within it there's some shipping details to different countries and such but it's a little vague. Point #2 makes it sound like you don't ship any 'S" series anywhere worldwide.. might want to correct it for future sales.
Also the link you gave me didn't work, could be a temp thing but the rest of the site is working fine.
Anyhoo, great news about the chassis shipping to Canada
Kit
Kitlope is offline
post #101 of 112 Old 01-08-2015, 02:15 AM
thestocky's Avatar
S16V first power up
Hi, I've just powered up my newly built S16V with no OS installed yet, but was wondering if the VFD should display anything pre-OS?
I only get the blue power button light (and fans etc), so am slightly worried as had a bit of a wire melting issue on first power up due to a loose plug to the little power button board... (fingers crossed the no VFD with pre-OS is normal!)
thestocky is offline
post #102 of 112 Old 01-08-2015, 04:19 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Small question... ......................
Yes. According to OrigenAE IR100 will work with S16T.
Regards
Zygmunt
Zygmunt is offline
post #103 of 112 Old 01-08-2015, 04:24 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
No. You have to install driver.
Rergards
Zygmunt
Zygmunt is offline
post #104 of 112 Old 10-25-2015, 09:01 AM
Liked: 0
Origene VFD/IR not working
Rergards
Hi,
I just setup a HTPC by using Origene S16V and unfortunately neither the VFD nor the IR is working!! I did install the iMon manager from Origene website (listed as VF310(iMon Version) VFD/IR software
) and i believe the connections are made according to the manual. When i check the status of the application (imon) from the task bar, it says hardware disconnected. I am pretty sure the USB cable to the front panel is connected and functioning as i could read a USB stick from that port.
Appreciate if any the friends here can help me on this. Also please let me know if any if you come across any step by step installation or video. The one listed in their website is not very clear and misleading as the screenshots are different from the current version they offer!!
Please help... really look forward to see my HTPC fully functional :-)
Sony.
sonyj912@gmail.com is offline
post #105 of 112 Old 10-26-2015, 12:03 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Originally Posted by sonyj912@gmail.com View Post
Hi,
Sony.
Hi
It is weird. Did you buy it used?
Regards
Zygmunt
Zygmunt is offline
post #106 of 112 Old 10-26-2015, 09:52 PM
Liked: 0
It was absolutely a new box which I purchased from their sole agent in Hong Kong.
Sony.
post #107 of 112 Old 11-02-2015, 04:32 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Sony.
If you are in that area contact OrigenAE directly. They should help you.
Are front lights work properly? (Blue/Orange)
Zygmunt
Zygmunt is offline
post #108 of 112 Old 12-21-2015, 12:12 PM
halfordb's Avatar
Need new M10 PSU
Hi Zygmunt,
I know you are travelling right now. I have an M10 that has been working great for a couple years, but just stopped. It looks like the power supply board has gone bad. It is this one: https://www.shop.perfecthometheater....PX-150-P2.htm/
I am wondering if you know when they might be back in stock, or otherwise where I might be able to order a replacement.
halfordb is offline
post #109 of 112 Old 12-21-2015, 09:17 PM
halfordb's Avatar
Zygmunt - thank you for the quick reply email. Looking forward to doing business with you again.
-Bill
halfordb is offline
post #110 of 112 Old 02-08-2016, 12:32 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Important info for owners of OrigenAE S21T chassis:
If your display is looking for DVI signal and goes blank, you have to switch it back to VGA input. To do it, press menu button for 5-10 seconds and it will switch back to VGA input.
Zygmunt
Zygmunt is offline
post #111 of 112 Old 03-30-2016, 11:56 PM
brandon_k_w's Avatar
For future buyers of the Origen S16V, I was able to fit a [dual slot] 980ti graphics card in my case. I had to dremel just a few millimeters off the hard drive bay as shown in the picture, but the card does barely fit with the bay still attached. Look at the thumb screw on the top hard drive bay lid, it hovers over the 980ti by about 1 millimeter.... whew.
My card is an EVGA 980ti with the reference cooler as this cooler has smaller dimensions than third party cooling, and thus, was able to fit with the bay and two hard drives installed. The motherboard I have is the Gigabyte Z170MX-Gaming 5. I chose micro ATX because it seems the very top slot for micro ATX is pcie x16, whereas full ATX has a pcie x1 slot at the very top, and the card definitely would not fit with the pcie slot moved down one row.
ID:	1349802   Click image for larger version
ID:	1349810   Click image for larger version
brandon_k_w is offline
post #112 of 112 Old 04-07-2016, 02:31 AM
Liked: 0
OrigenAE M100 IR100 and Windows 10
Can anyone advise if they have managed to get the remote control too work with Windows 10. My device is not shown as an MCE remote in Device Manager but does operate to some extent in KODI and in general Windows operations ie Sleep, Shut Down, close program, etc. I would like to edit the 'key' actions but unaware of where these will be in Windows 10. Any help appreciated.
jak8 is offline
Reply Home Theater Computers
