Official Wesena thread - AVS Forum | Home Theater Discussions And Reviews
post #1 of 89 Old 02-16-2012, 02:52 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
I think that it would be a good idea to have one place where I (and eventually others) can answer questions about Wesena chassis.
Instead of answering individually questions by e-mail - I will answer all questions here.
No other brands here, please.
Regards
Zygmunt
Perfect Home Theater
Zygmunt is offline
post #2 of 89 Old 02-23-2012, 08:27 PM
BLOCKMONSTER's Avatar
Im waiting until the ITX5 come out. Is Wesena releasing anything new? Maybe one without a slotloading optical (but a slim or a regular one)?
BLOCKMONSTER is offline
post #3 of 89 Old 02-24-2012, 07:39 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Nothing new right now, except what is already published on my site.
Regards
Zygmunt
Zygmunt is offline
post #4 of 89 Old 02-24-2012, 08:23 AM
grumbledook's Avatar
Would a 100w processor in the mini itx7-2 case be feasible with 2x 80mm fans added and a decent cpu cooler?
grumbledook is offline
post #5 of 89 Old 03-01-2012, 06:00 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Do you mean ITX7 or ITX2?
I think that 100W CPU in ITX 7 without 3.5" HD should be fine. (Use short cables)
100W in ITX2 - is too much IMO. ITX2 is too compact and only one 40mm fan will not be enough to cool it IMO. I didn't try so I have no experience.
Zygmunt
Zygmunt is offline
post #6 of 89 Old 03-01-2012, 06:26 AM
I meant the itx7, but it's called itx7-2 on the site (http://www.wesena.co.uk/product.php/6/2/itx7_2)
Glad to hear this, it is a beautiful case.
post #7 of 89 Old 03-02-2012, 12:15 PM
TheTick077's Avatar
I was looking at the Intel I3-2100t but I fell in love with this case and it is more expensive than the case I budgeted for so, I was thinking of going AMD. But, I was wondering if the stock AMD heatsink & fan would fit in the ITX6 case...If not what heatsink/fan would you suggest for the A4-3400?
BTW, love the case, and honestly trying to fit it in the budget and basically build around it. I search high and low for a clean case with an expansion slot and this is by far the best looking one I have found.
TheTick077 is offline
post #8 of 89 Old 03-02-2012, 12:57 PM
josh_parker123's Avatar
I finally ordered the itx2 or the streacom F1C as it seems to be in the uk, any general help people could give me would be great regarding parts etc, i guess the main things i want to get right is the case fan (preferably as quiet as possible) and a good quality pico psu. Also can anyone tell me if the case can accommodate 2 HDD's ? as im looking to fit a SSD for the OS and another drive for dvr? as i said any general help would be great as this is going to be my first build
josh_parker123 is offline
post #9 of 89 Old 03-02-2012, 04:42 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Please remember that total space for Mobo, cpu and HS is 40mm if you are going to use 3.5" HD. If you can live with only 2.5" HD you can bend or cut off two blades (bracket for 3.5" HD) and than you have 64mm = 2.5" space.
Please look here:
Zygmunt
Zygmunt is offline
post #10 of 89 Old 03-02-2012, 04:54 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Yes, if you install very low profile HSF and memory. Total space in ITX2 is 45mm, so if you install second HD under bracket, you space go down to 37mm.
Zygmunt
Zygmunt is offline
post #11 of 89 Old 03-02-2012, 04:58 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Guys, what do you thing about such color for ITX chassis? (You have to have calibrated monitor to see correct colors)
Zygmunt
Zygmunt is offline
post #12 of 89 Old 03-02-2012, 04:59 PM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
Its not for me personally. But to each their own. I want a case that blends in.
I think what would be cool is the ability to change LED color or intensity in a black, silver or gunmetal case.
assassin is offline
post #13 of 89 Old 03-02-2012, 05:14 PM
TheTick077's Avatar
Please look
Good pics, and I know the stats, I just don't know the real world applications...like how much of that 40mm is taken up by the mobo risers (if it has any). Plus I didn't know if you or anyone else could suggest a low profile fan that would fit in the case. Still trying to decide between AMD and Intel...Using only integrated GPU so am leaning a little toward the AMD, but with the added cost of a heatsink might lean right back to the intel.
post #14 of 89 Old 03-03-2012, 12:55 AM
Okay thanks does anyone have any recommendations for a heatsink(the quieter the better) iv seen this one http://www.quietpc.com/gb-en-gbp/pro...-silence-iplus and memory please ? im going to be using an ASRock H67M-ITX/HT. Also is 40mm the right size for a case fan?
post #15 of 89 Old 03-03-2012, 12:07 PM
The scythe kozuti is 40mm tall and apparently not too noisy if you don't run it at max.
http://www.silentpcreview.com/article1209-page1.html
post #16 of 89 Old 03-06-2012, 08:06 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
........like how much of that 40mm is taken up by the mobo risers ...............
None.
The distance 40mm or 45mm is between mobo risers and the lowest part of bracket. In ITX6 or ITX7 it is a distance between risers and blades for 3.5" HD. If you don't use 3.5" HD, some elements may fit between blades.
Zygmunt
Zygmunt is offline
post #17 of 89 Old 03-06-2012, 09:27 AM
StardogChampion's Avatar
Quoted: 93 Post(s)
Liked: 160
A few questions:
1) Do you know when/if the ITX-1 is coming back in stock?
[Edit: just noticed this on the front page: "Arriving in the USA by end of April"]
2) Has anyone successfully built with this case using SandyBridge components such as (this is what I have available) the ASUS P8H61-I motherboard and SilverStone NT07-1156 cooler? It appears it will fit height-wise but I am concerned with the motherboard interfering with the front panel as several did in this review: http://www.missingremote.com/review/...tx-sff-chassis
"Both the Intel DH61AG and D525MW mini-ITX motherboards were not compatible with this chassis due to the location of the CPU near the front headers"
I see a concern here with my picoPSU interfering with the front panel. I am unable to find a top-down view of the ITX1 or ITX2 to compare against.
3) From the product page: "Maximum height of motherboard with everything installed on it is: 1,75”, ~45mm with one HD installed." What if I have 2 x 2.5" drives installed (one SSD, one HDD?)
StardogChampion is offline
post #18 of 89 Old 03-06-2012, 10:32 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Originally Posted by StardogChampion View Post
A few questions:
They didn't ship it yet. Two weeks delay.
Did you look here? I just bent pins and solved this problem in my built.
Not a problem. Look at above link.There is a problem however with bracket in ITX6/7. Check info in "Technical support".
3) From the product page: "Maximum height of motherboard with everything installed on it is: 1,75, ~45mm with one HD installed." What if I have 2 x 2.5" drives installed (one SSD, one HDD?)
In ITX2 one HD must share space with mobo because space for second HD is under ODD bracket. in ITX1 however there is no ODD so second HD can be installed on the top of the bracket, just in space for ODD. If you check above link and tech support - you will have better idea how to build your system.
Zygmunt
Zygmunt is offline
post #19 of 89 Old 03-06-2012, 11:34 AM
Quoted: 93 Post(s)
Liked: 160
Excellent. Thanks for the quick response. I look forward to the ITX1 being available again. I am getting a lot of interest in very SFF builds so I am hoping the ITX1 and ITX2 fit the bill. For my own purposes though, I need the ITX1 which will make a good prototype.
Somewhat related, I would think the new D2700 boards would be a great match for the ITX1/ITX2.
post #20 of 89 Old 03-06-2012, 01:29 PM
Quoted: 93 Post(s)
Liked: 160
Do you have a list of available slot-load DVD burners that are compatible with the ITX-2? Specifically, burners that have the button lined up with the ITX-2 button? Hopefully something reliable, not just from eBay and not $100.
post #21 of 89 Old 03-06-2012, 02:45 PM
wyen78's Avatar
I like the red not the magenta so much. I think a case with just that color would be too much though. Perhaps 2 tone with black or white or silver in it as well could look pretty sharp depending on the design. Or maybe just have a face plate that could come in different colors to match the color of your optical drive.
wyen78 is offline
post #22 of 89 Old 03-08-2012, 07:36 AM
Quoted: 93 Post(s)
Liked: 160
Looking at the ITX-2 on the UK Wesena site, it seems the eject hole for the slot-load DVD is located to the middle-right. The majority of slot-load DVD players available these days have the button there, especially the more reasonably priced and commonly available ones.
Is this version available? Where is the eject hole exactly?
post #23 of 89 Old 03-13-2012, 09:49 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Models with eject button on the right were ordered by GB dealer for GB market. However European distributor and his resellers still offer models with eject button on the left. All Wesena models in the USA have eject button on the left.
In the future I may order models with eject button on the right if there is such demand.
Zygmunt
Zygmunt is offline
post #24 of 89 Old 03-15-2012, 01:32 PM
scoyne88's Avatar
You can, http://slicksolutions.eu/ledsdriver.shtml
Before you criticize someone, you should walk a mile in their shoes.That way, when you criticize them, you're a mile away and you have their shoes.
DIY Speaker Cables
http://www.seancoyne.org
scoyne88 is offline
post #25 of 89 Old 03-15-2012, 02:34 PM
Quoted: 93 Post(s)
Liked: 160
In searching for slot-load ODDs I've noticed most of what I've found have the button on the middle-right.
post #26 of 89 Old 03-24-2012, 05:41 AM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
If this is a trend, we will build chassis with eject button on the right. So far I have access to slot BluRay drives with button on the left, so I didn't consider changes in design.
Zygmunt
Zygmunt is offline
post #27 of 89 Old 03-24-2012, 06:01 AM
assassin's Avatar
Quoted: 155 Post(s)
Liked: 261
As a builder sourcing slot loading drives is a royal pita,btw. Very expensive as well.
assassin is offline
post #28 of 89 Old 03-24-2012, 10:34 AM
Quoted: 93 Post(s)
Liked: 160
It'd be better to either have no button or a button on the middle/right. At least on the middle/right there are more choice like the Sony Optiarc drives which seem to be plentiful and not too bad in price ($36.99 for a DVD-RW) and available from respectable sellers like Amazon.
post #29 of 89 Old 03-26-2012, 04:32 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
OK. When I order next cargo of chassis with slot ODDs they will be with eject button on the right.
Zygmunt
Zygmunt is offline
post #30 of 89 Old 03-26-2012, 04:45 PM - Thread Starter
Zygmunt's Avatar
Quoted: 23 Post(s)
Liked: 34
Wesena makes e series chassis with flat surfaces sanded, and corners sand blasted.
They consider make chassis sand blasted on flat surfaces also. I think that their models are unique because of this combination, but this is my opinion
What do you think, guys?
Zygmunt
Zygmunt is offline
Reply Home Theater Computers
