ripped bds do not get DTS master audio, why? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 02-17-2012, 06:41 PM - Thread Starter
ser_renely's Avatar
I rip a BD and select DTS master audio, but when I play the movie back my receiver only shows it as DTS, not DTD Master audio
I have made sure I am ripping correctly.
Any ideas? Receiver being picky?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
ser_renely is offline
post #2 of 38 Old 02-17-2012, 07:33 PM
Seegs108's Avatar
Quoted: 4961 Post(s)
Liked: 2478
What player are you using? It could be extracting the DTS core from the DTS HDMA file. You should be using software that can bitstream the audio correctly. ie FFDShow, LAV Filters or software like PowerDVD or Arcsoft Total Media Theater.
Seegs108 is offline
post #3 of 38 Old 02-17-2012, 07:35 PM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
List all hardware involved.
List all software involved.
List all codecs involved.
That would be a good start.
assassin is online now
post #4 of 38 Old 02-19-2012, 05:36 AM - Thread Starter
ser_renely's Avatar
Sorry silly of me not to.
-Using DVD fab to rip BD disc to MKV file.
-Use XBMC or VLC for playback, both same result
-HDMI from HTPC(i3-2100, gigabyte mobo z68ma)to Pioneer Elite SC-27 AVR
How do I figure out which codecs are being used?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #5 of 38 Old 02-19-2012, 06:04 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2693
proBABLY not ripping the movie with DTS-HD MA track...
That's my guess.
Can you confirm your video file contains this track before we trouble shoot other stuff?
VLC is a rather simple and excellent player.. and it auto plays DTS over the digital out.
If your using a current version of VLC the problem is not in your player.;
It's in how you making the video file or the video file itself.
Mfusick is offline
post #6 of 38 Old 02-19-2012, 06:21 AM - Thread Starter
ser_renely's Avatar
That's my guess.
DVD fab shows I do have the DTS master selected. I will try again though and let everyone know.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #7 of 38 Old 02-19-2012, 06:46 AM
CountryBumkin's Avatar
Quoted: 218 Post(s)
Liked: 55
I use JRiver and have to copy the file dtsdecoderdll.dll to the Windows Sys32 folder (or its equivalent folder for x64 systems) to get DTS-HD MA playback. I believe this file is needed with other players too.
DTS-HD MA will only decode the DTS "core" (which usually is 5.1 48Khz) unless you supply the dtsdecoderdll.dll, which then enables full decoding of the HD lossless parts.
You can get this file from the "trial" version of Arcsoft TMT. Or serach this forum for "dtsdecoderdll" and there may be a link/copy of it.
CountryBumkin is offline
post #8 of 38 Old 02-19-2012, 06:46 AM - Thread Starter
ser_renely's Avatar
I just ripped another. Made sure DTS-HD track was selected in DVD fab.
I believe I am ripping correctly....? I don't check the 'remove HD audio'.
I opened the file in Handbrake afterwords and it shows only DTS. I thought there was a DTS-HD option if the audio file had it?
Sean
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #9 of 38 Old 02-19-2012, 07:07 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
VLC or XBMC (except for a certain build) does not support HD audio bitstreaming. Use a DirectShow player (e.g. MPC HomeCinema) with LAV Filters.
MediaInfo tells you what tracks are in the file.
renethx is offline
post #10 of 38 Old 02-19-2012, 07:15 AM
assassin's Avatar
Quoted: 132 Post(s)
Liked: 254
Correct. You have to use hardware AND software that BOTH support HD Audio bitstreaming.
post #11 of 38 Old 02-19-2012, 07:20 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Your hardware (Core i3-2100, Pioneer SC-27) is OK. You just need to use a correct player and a source that includes HD audio track.
renethx is offline
post #12 of 38 Old 02-19-2012, 08:02 AM
MlNDBOMB's Avatar
Quoted: 18 Post(s)
Liked: 83
i dont think movies come with just dts as the main track.
in my experience, it is always dts-hd ma, truehd+ac3, ac3, or lpcm.
MlNDBOMB is offline
post #13 of 38 Old 02-19-2012, 11:35 AM - Thread Starter
ser_renely's Avatar
Thanks for the help.
I downloaded MPC-cinema and CCCP.
When I look at media info audio it says its only DTS.
So why is DVD fab not ripping with DTS-HD even though it lets me select DTS-HD as an option?
I am guessing that is what the issue is at the moment?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #14 of 38 Old 02-19-2012, 11:55 AM
steelman1991's Avatar
Quoted: 249 Post(s)
Liked: 140
Not for 'bitstreaming' to the receiver which I think is what the OP is trying to achieve.
Is this method not just required where the user wants the player to decode the audio track?
steelman1991 is online now
post #15 of 38 Old 02-19-2012, 12:00 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I recommend MakeMKV (or BluRip+AnyDVD HD).
MPC HomeCinema and LAV Filters (and madVR) are all what you need (check the sticky thread "Advanced MPC..."). In general you'd better stay away from a codec pack.
renethx is offline
post #16 of 38 Old 02-19-2012, 12:01 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
dtsdecoderdll.dll is necessary to *decode* DTS-HD to LPCM. For bitstreaming, you don't need it.
renethx is offline
post #17 of 38 Old 02-19-2012, 12:16 PM - Thread Starter
ser_renely's Avatar
Hmmm, I just bought dvdFAB BD Ripper. Should it not be able to rip DTS-HD?
I am going to uninstall the CCCP. I am getting a bit ahead of myself.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #18 of 38 Old 02-19-2012, 12:17 PM - Thread Starter
ser_renely's Avatar
I am bit streaming, correct? As my receiver is decoding...
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #19 of 38 Old 02-19-2012, 12:21 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Yes, you are bitstreaming HD audio. You receiver decodes HD audio.
MakeMKV is free (as long as it is beta), so try it anyway. This is the simplest program to rip BD in MKV with all video/audio/subtitle tracks intact.
renethx is offline
post #20 of 38 Old 02-19-2012, 12:29 PM - Thread Starter
ser_renely's Avatar
MakeMKV tells me the evaluation period has expired and I need to purchase an activation key.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #21 of 38 Old 02-19-2012, 12:34 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Read: Can't get beta working? or MakeMKV is free while in beta
renethx is offline
post #22 of 38 Old 02-19-2012, 03:51 PM - Thread Starter
ser_renely's Avatar
Ahhhh, that makes more sense now.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #23 of 38 Old 02-19-2012, 04:51 PM
Zagor's Avatar
Install this version of XMBC. It supports bitstreaming of DTS-HD and TruHD.
Zagor is offline
post #24 of 38 Old 02-19-2012, 09:15 PM
Knight_2000's Avatar
I have a similar problem riping BD discs into mkv using makemkv. If i play the BD DISC with Powerdvd it will show DTS-HD MA however if i rip that disc into mkv, and i do select the DTS-MA track, when playing it shows a different name on the information tab, it will say DTS 7.1. But i know its playing HD content because of the bitrate, which is around 6k on avg. So my guess is that there is an issue with the way the audio tracks gets tagged when it gets converted to mkv.
P.S: I tried DVDFAB also and did the same thing.
Whenever there is any doubt, there is no doubt.
Knight_2000 is offline
post #25 of 38 Old 02-19-2012, 09:58 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
PowerDVD 11 supports only DTS core in MKV. PowerDVD 12 supports DTS-HD in MKV.
renethx is offline
post #26 of 38 Old 02-20-2012, 05:49 AM - Thread Starter
ser_renely's Avatar
I got it to display DTS-MA on my receiver with the CCCP pack and MPC when I used and MakeMKV. It also worked in the DVDFAB rips I did as well, but it was real slow - un-watchable - that was odd.
When I deleted the CCCP pack and followed the directions to install MADVR and LAV filters from the sticky thread I could not get DTS MA to display on my receiver. Seems pretty simple to me, but I just can't get it to work.
How do I check the bit rate of the audio?
I feel like an idiot. Seems like it should be so basic
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #27 of 38 Old 02-20-2012, 06:00 AM - Thread Starter
ser_renely's Avatar
ahhh I will try that as well, thanks.
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #28 of 38 Old 02-22-2012, 09:18 AM - Thread Starter
ser_renely's Avatar
Well, it seems that if I play DTS-HD on MPC it will only work with FFDshow, and I cannot get it to work with LAV audio filters. No idea how or why.
On top of that, it seems that if I rip with Makemkv I can get DTS-HD audio. If I rip with DVDfab the video skips all around and does not play correctly when I try and get DTS-HD.
So one of my question is this, if my receiver says I am getting DTS-HD am I really getting it? How can I check?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
post #29 of 38 Old 02-22-2012, 09:26 AM
Nimo's Avatar
You have to select .mkv pass through in the profile pain.
With the newer versions it's a lot easier to make blu ray 3d to .mkv's. I just ripped POTC Stranger Tides and the file size is only 10gigs for 3D even with the lossless.
Nimo is offline
post #30 of 38 Old 02-22-2012, 09:50 AM - Thread Starter
ser_renely's Avatar
Thanks. I think I have the newest version, 8.1.6.3?
Where exactly is the "profile pane"?
B&W cm5
Pioneer Elite SC-27
Panasonic 50" GT50
HTPC - i5, ATI 7790
Crappy Klipsch sub
Reply Home Theater Computers
