Which video card has NO HDCP/Hanshake issues - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-21-2012, 07:16 PM - Thread Starter
mkedda's Avatar
Help!
I have the nvidia gt 430 video card. If the computer boots up without the monitor turned on it cannot sync without a complete reboot.
Which video card can sync / handshake without needing to have the monitor powered on during boot?
mkedda is offline
post #2 of 13 Old 02-22-2012, 05:58 AM - Thread Starter
mkedda's Avatar
Does this mean there are no?
Originally Posted by mkedda View Post
Help!
mkedda is offline
post #3 of 13 Old 02-22-2012, 06:00 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Depends on the other components (AV recevier, HDTV, etc) in your chain. I don't think there is one universal card that has no issues no matter what the setup.
assassin is offline
post #4 of 13 Old 02-22-2012, 06:04 AM
Heuer's Avatar
Only reliable and easy option is HDMI Detective:
You could have a look at the EDID hack thread but it depoends how you value your time!
Heuer is offline
post #5 of 13 Old 02-22-2012, 08:45 AM
Zon2020's Avatar
I think for about 90% of people, these things work without any need for such complications. Most people have no need of an HDMI Detective.
Zon2020 is offline
post #6 of 13 Old 02-22-2012, 03:01 PM
kegobeer's Avatar
That's a last resort option. If you need to buy one, you'll figure it out after a bunch of testing. I have several HTPCs, and only one of them needs the HDMI Detective Plus - the other two have no issues at all.
kegobeer is offline
post #7 of 13 Old 02-22-2012, 04:33 PM
walford's Avatar
I am surprised that you expect a video card to sync with a monitor that is not turned on. My monitor is in standby when it is not fully turned on and the boot process causes it to fully power on(wake up) and then sync. I also have it set to wake up if the keyboard is used or if the mouse is moved. The settings for waking up are in the system BIOS and are not tied to the graphics card.
walford is offline
post #8 of 13 Old 02-23-2012, 11:41 AM - Thread Starter
mkedda's Avatar
the video card should be able to remember the edid of the last device it connected to... i hated paying nearly 100 for the hdmi detetive...
i ran out to the store and purchased a zotac nvidia gt 545 and dropped it into the box, it works perfectly, it syncs to the monitor with the device powered off.
mkedda is offline
post #9 of 13 Old 02-23-2012, 11:46 AM
assassin's Avatar
Quoted: 171 Post(s)
Liked: 276
Some will. Some won't. Only way to know is to test every single option out there on your specific setup.
Again, there is no universal answer here.
assassin is offline
post #10 of 13 Old 02-23-2012, 01:33 PM
walford's Avatar
There is a big difference between setting the power button to off (which is normally standby) and actually unplugging a system.
walford is offline
post #11 of 13 Old 02-23-2012, 07:02 PM
Bignickfly's Avatar
I hope this helps...
I have one HTPC that has the 450GTS, I can boot up with the LCD on standby, I have not tried it with power off.
Sony 40" LCD connected via HDMI.
PS I have had various other HTPC's with ATI card's that cannot do this.
Bignickfly is offline
post #12 of 13 Old 02-23-2012, 07:06 PM
Acesfullup's Avatar
I reboot my Win 7x86 XBMC Eden Beta 3 every night with my Toshiba Regza monitor off. I have never had this issue.
Acesfullup is offline
post #13 of 13 Old 02-24-2012, 09:37 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I am using onboard Radeon 4250, and NEVER had any HDCP issues. It boots with or without the TV on.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Reply Home Theater Computers
