Help with extender and back up software - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-22-2012, 11:37 PM - Thread Starter
ComptonHPD's Avatar
I want to be able to back up my BD/DVD to my new HTPC and use it as my media server for the time being. Right now I have an XBOX 360 and am looking to get another extender possibly.
I am looking for a software suite that can take a dvd or BD and back it up to my HTPC in a 1080p with 5.1 format that can stream to my xbox. I know with xbox right now it can only be done with WMV. Currently I am using MakeMKV which is super easy and simple. I love it. But...it obviously doesn't stream to an xbox.
Does anyone have some good recommendations for an all inclusive software?
Right now I am looking at dvdfab rippers
WMV (VC-1) support
The Xbox 360 console supports the following for WMV:
File extensions: .wmv
Containers: ASF
Video profiles: WMV7 (WMV1), WMV8 (WMV2), WMV9 (WMV3), VC-1 (WVC1 or WMVA) in simple, main and advanced up to level 3
Video bit rate: 15 Mbps with resolutions of 1920 × 1080 at 30 fps
Audio profiles: WMA7/8, WMA9 Pro (stereo and 5.1), WMA Lossless
Audio max bit rate: No restrictions
ComptonHPD is offline
post #2 of 5 Old 02-23-2012, 07:19 AM - Thread Starter
ComptonHPD's Avatar
Never mind, I got a solution. It's amazing how you can always do it on your own once you post in a forum.
post #3 of 5 Old 02-23-2012, 09:42 AM
tkole's Avatar
what did you come up with for your solution?
tkole is offline
post #4 of 5 Old 02-24-2012, 05:33 PM - Thread Starter
ComptonHPD's Avatar
keep the 360 on the main TV and get some a WD live or Boxee so it doesn't matter how I decide to rip them. So really I can stick with MakeMKV and Handbrake if I want.
post #5 of 5 Old 02-24-2012, 05:46 PM
Sammy2's Avatar
Quoted: 535 Post(s)
Liked: 255
That's one solution I guess.
I have a Patriot Box Office that's been hacked with Medi8tor firmware to playback HD Audio for that. I might let it go as it isn't being used right now.
Sammy2 is offline
Reply Home Theater Computers
