Routing my HTPC to two different rooms, same content - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-23-2012, 06:56 PM - Thread Starter
LucasBuck's Avatar
Currently I run an HTPC using WMC, a Ceton tuner, and Sony DH810 Receiver. It's just run to one TV. It's like to setup a second TV in the bedroom, just as a duplicate.
Could I just setup my video card to run them as dual\\duplicate monitors? And is there a way to split the output from the Sony receiver so I can have surround sound setup in both rooms, and just play in one or the other?
Or am I an idiot and thinking about this the wrong way, and just need to an Xbox extender? If I did it that way, would I just be limited to the TV audio output, or have to buy another receiver? Thanks for any input for a newbie.
LucasBuck is offline
post #2 of 10 Old 02-23-2012, 07:00 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I just split a buddy's HTPC to his 1080p projector and 720p workout room LCD with no problems.
I used a monoprice HDMI splitter. This way allowed me to use HDMI to both and the LCD TV can control the volume.
assassin is online now
post #3 of 10 Old 02-23-2012, 07:46 PM - Thread Starter
LucasBuck's Avatar
Thanks for the reply! No loss in signal? That sounds like a good idea, but is there a way I can also split the output from the Sony receiver? IE, have a surround setup in each room, just swap which is getting the signal?
post #4 of 10 Old 02-23-2012, 07:56 PM
assassin's Avatar
Quoted: 78 Post(s)
Liked: 241
I guess you could try to split the HDMI signal coming out of the receiver instead of out of the HTPC.
Haven't tried that one.
post #5 of 10 Old 02-23-2012, 08:36 PM - Thread Starter
LucasBuck's Avatar
Actually, I don't run my sound through the HDMI. I run an optical cable from my PC to the receiver, then it runs straight to the surround sound speakers.
post #6 of 10 Old 02-23-2012, 11:07 PM
fitbrit's Avatar
Quoted: 54 Post(s)
Liked: 50
If you can get another receiver, then you can have surround sound in both rooms with the same source. Or you can get a number of cheap monoprice speaker selectors- one each for the front LR, surround LR, Centre, and, if applicable, surround backs. Could be done for as little as $70 or so. You may be better off getting a cheap optical capable AVR from Craigslist though.
fitbrit is offline
post #7 of 10 Old 02-24-2012, 10:25 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Splitting HDMI may or may not work. It may mess up your HDCP handshake to the point that most stuff will be unplayable.
Just get a media center extender off ebay, or xbox. Newegg has recertified 4 Gig XBOX360 for $150 shipped. Ebay is full of XBOXes with busted up ODD, or banned ones. Either of those will work as extender.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #8 of 10 Old 02-24-2012, 10:32 AM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
http://www.newegg.com/Product/Produc...82E16814125358
would something like that work? thats kind of what I was thinking I might do when I get a 3D tv so I could send one to the receiver and one to the tv
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #9 of 10 Old 02-24-2012, 03:44 PM
DAVE2's Avatar
Its hit or miss with splitting or using a hdmi matrix. Also having two different monitors has issues as well with timings, resolution, overscan, ...
Still have not seen Avatar in 3d.
DAVE2 is offline
post #10 of 10 Old 02-24-2012, 04:15 PM
Darin's Avatar
I've been using HDMI distribution amps ("splitters") for a while, without any significant issues. Pretty much all the common ones avaialable these days report EDID info back to the source that is a "worst case" to prevent a signal being sent to a device that it can't handle. So the caveat here is that if you have, for example, one display that can handle 1080p, and one that can't, the end result is you won't be able to send 1080p to either of them (unless you add in another device to spoof it).
My dual Rythmik Servo sub project (actually quad now, need to update page)
HDM format neutral thanks to the pricing wars of the '07 xmas shopping season :)
Darin is offline
Reply Home Theater Computers
